Question about E-Machines (308714) Motherboard
Emachines t6522 i replaced our motherboard and there are three wires to the power....red/white, black/white and green/white. can you tell me in what order they go in when looking down at the motherboard. i can get the fan to come on but no other power
    President:
  • 2,351 Answers
Hi birm,
I can tell you that most likely the white wire is the ground wire. The others are positive. The two manual found on eMachine's site does not provide enough of detail.
In this manual see;
Replacing the front I/O Panel (Pages 168, 170 see number 5).
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The information is not specific enough, my guess is the front panel connections is the cable to the far right. (Looking at the picture).
You can try by looking at the picture & hooking the cable as shown.
The white colored wire seems to face to the right. Than try the power on button. If system does not come on, turn the connector 180 & reconnect. Try the power on button on the case.
Listed at the bottom of the link below you can either chat with a tech or call tech. (Main site for the T6522)
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6522
User guide T6522;
http://downloads.emachines.com/userguides/Desktop_UG_Nexgen2_3_en.pdf
Good luck birm!
I wish I could be more specific.
Mike
Posted on Jan 16, 2009
T6216
There should be 2 rows of pins in parallel usually around the bottom edge of the motherboard. The markings for which is which should be next to them on the board. HDled+, HdLed-, PwrSw, PwrLed, or something similar.
If you do find them but the hard drive Led does'nt come on it's because the plug for it needs to be turned around the opposite way, Led's only work one way as they are diodes. Same for the Power Led.
If there are no letters near the pins then you would have to find the motherboard manual.
Jan 28, 2012 | E-Machines eMachines Desktop PC
I need to know where 3 wires go
The wires should be labeled HDD,POWER, and i think RESET or somthing, just look on the motherboard within cord reach and you should see all three labeled on the motherboard all grouped together.
Oct 26, 2009 | E-Machines eMachines Desktop PC
Motherboard installation
Just download manual and check configurations:
http://www.opendrivers.com/driver/265244/emachines-c6415-user-guide-free-download.html
May 16, 2009 | Computers & Internet
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
Mar 05, 2009 | E-Machines eMachines T3830 PC Desktop
Emachines t6522
I assume you are trying to connect the wires from the faceplate to the motherboard. Get a magnifying glass and see if the board is marked as to Power, Speaker, HDD LED, Reset, etc. Trace the wires to the faceplate and note what the function of each pair of wires is and attach to motherboard as necessary.
Jan 17, 2009 | E-Machines eMachines Desktop PC
No power to emachines t6522
The final set of connections are the front panel leads that attach to the motherboard. This includes the LEDs for hard drive activity and power status, the case speaker, and most importantly, the power switch.
eg:
You should consult your motherboard manual to find out where to plug these in. The power one is obviously the most important.
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | E-Machines (308714) Motherboard
Motherboard wiring
Green/wht normally = Reset or Power LED
Red/wht normally = HDD LED
And is the third red/BLACK?
There should be a label on the black pin jumper at the end of each wire.
Does it say anything?
Jan 16, 2009 | E-Machines eMachines Desktop PC
Problem with power connections on emachine T2596
Take a peek at this link,
http://www.duxcw.com/faq/mb/frontpanel.htm
it may assist you in your problem
Dec 17, 2008 | eMachines Computers & Internet
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
EMachine no power
Ok for a start the power switch is not green and white that is the power led, you need to look for a red and black wire normally marked on the connector and motherboard as pwrsw or pswitch.
if you believe it to be the switch unplug the connector and jump the connection on the motherboard using the reset switch or a jumper, or not recommended but have done this myself many times using a flat blade screw driver very carefully and touch the 2 pins to complete the circuit.
if it doesnt power on then its more than likely it is the power supply but the motherboard being faulty could also cause this to happen.
the problem i have found with emachines is that its difficult to get replacement power supplys
Nov 30, 2007 | E-Machines eMachines Desktop PC
E-Machines (308714) Motherboard Logo
603 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
