Question about Maytag M7Y15F2A Air Conditioner
No power to the pannel or unit
I plugged the unit in; it ran then it just turned itself off. I checked the plug, the breaker box and its all working and have power. I have tried to unplug, wait 3 minutes and plug it back in but I get no power on the display. Is there something that might need to be reset on the unit, and if so were it located.
I have the same unit and it started to act funny then eventually would not turn on. Suspect circuit board for controls.(I removed the board and played with the connector and checked the components ) All was good and unit is working again still need to find new board Part #cor182k
Posted on Jul 11, 2007
6ya staff
SOURCE:
We have a 2001 presidential 5th wheel it is hooked up and plugged and everything works but the lights. Is there a separate switch to turn these on?
There is probably a breaker box in the bedroom closet behind a panel. Look elsewhere if not there and check the breakers when you find it. You may have a short circuit somewhere and the breaker opened. Or maybe even a failed breaker. Check for voltage at the breaker itself. Don't assume the breaker is getting power.
Feb 03, 2017 | Holiday Rambler 2010 Presidential 36RET
TV wont switch on
Check plug for power. Make sure that plug has adaquit power. These TV's take a lot of power make sure breaker pannel is OK. Check fuse in TV. Good luck.
Dec 11, 2011 | Televison & Video
I have a bathroom Broan 504/505 vent fan. This model just stopped working. I have power to the unit but for some reason it wont work. I pulled the fan plug from the fan housing & used an extension...
the motor is prob rated for 120-140 volts if your only getting 110 there is the problem see what the breaker is putting out at the box the light will still work but the motor needs enough amps to start sounds like a voltage drop issue
Aug 06, 2011 | Heating & Cooling
I purchased a SUPRA 32 LED TV FULL HD Model No SLED32OT9001R from UAE 3 months back and from the last few days TV is not working even the power led at the front pannel doesnt shows power.
Be sure the power cord is plugged in to the a/c outlet fully. Take a table lamp and plug in the same outlet to verify power is good. If no power, check for circuit breaker tripped in main breaker box.
If problem seems to stay with tv, I would contact seller. You should have at least nine months of warranty left.
May 17, 2011 | Televison & Video
Just put air conditioner back in for the summer.. plugged it in and ran a test on it then nothing... any suggestion why it wont turn on..
Could have quite possibly tripped the circuit breaker. If it is a 230volt unit, there will be two breakers, they are usually joined together and probably 20 amp. Trip them all the way back and then all the way forward. If it is a smaller 120 volt unit there will only be one breaker, more than likely a 15 or 20 amp. Hope this works. Also, on newer models the plug may contain a reset button. It will be right on the head of the plug itself.
May 13, 2011 | Haier hwr10xc6 Air Conditioner
My Heat Surge was working fine, then it just went out. It is plugged in, but when I tried to start it again, it wouldn't light. HELP!
Tirn the Master ON/OFF switch to OFF. Unplug the unit for 12 to 15 minutes. This should allow the unit to reset itself. Plug the unit back in and turn the Master Switch to ON. If it reset itself, it should work normally. If it doesn't test the wall outlet it's plug into to make sure it still has power. Unplug the heater and plug in a lamp to see if it works. If it doesn't the circuit breaker in your homes breaker panel has been tripped and needs to be reset. More than likely, your Heat Surge Heater tripped the breaker, because of a malfunction.
Hope this helps solve your problem.
Mar 15, 2011 | Heating & Cooling
Just bought it from a catalogue and it will not turn on
Check Fuse on Socket plug ..Model with cigarett lighter the fuse blow sometime... Also check Accesory Pannel Fuse Box.....
Look for reset on the unit itself...
Sep 24, 2010 | Garmin nuvi 205 GPS Receiver
A/C runs for 10 min then throws breaker
the 30amp breaker is bad but when running on a 20 which is good its not enough of amps to support thats why it ran for 2hours before it ..so try changing that breaker to a new one
May 15, 2010 | Coleman Mach III Air Conditioner
I've an alram in my carrier chiller model 30XA1202 which reads (electrical thermostat interlock or electrical box failure) and as aresult the chiller does not start. please advise
TURN OFF THE BREAKER TO THE UNIT AND UNPLUG IF
POSSIBLE...WAIT 10 OR 15 MIN. AND TURN THE BREAKER
ON THEN PLUG THE UNIT IN....IF THIS DOESN'T WORK YOU MAY HAVE TO REPLACE THE BREAKER OR TRY A DIFFERENT
OUTLET AND WHILE POWER IS OFF CHECK ALL WIRE CASINGS
AND CONNECTIONS FOR GROUNDS OR SHORTS.
Apr 01, 2010 | Heating & Cooling
No power
If you already checked and replaced the brushes but it is still not turning then you do these:
Try to see if your unit have a safety breaker and reset it,most of power tools have also a fuse in the plug itself.
Also some have a thermostat fuse.,you can find it attached on the rewined coil.
Nov 19, 2009 | Dremel Variable - Speed Multipro Rotary...
Maytag M7Y15F2A Air Conditioner Logo
211 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
