Question about Ricoh Aficio 2018D All-In-One Laser Printer
Have a misfeed error B that we cannot get to go away
We have looked everywhere we can and do not find any more pcs of paper stuck in the copier. there is also a red lightning bolt and an arrow pointing down into a box. we have also tried turning the machine off and back on but the message is still there. is there some way to reset the machine to make this message go away? do you have any suggestions on where else to look for stuck paper?
  • 1 more comment
  • financehuman Jan 19, 2009
    i'm not sure what you mean by it might have made some device to mislocate
    have tried all you suggested and we still have the problem. can you suggest anything else?
    we have used all the suggestions you gave us but that still has not fixed the problem. we need additional info to fix this error message.
    Sergeant:
    Scholar:
  • 199 Answers
The B is saying there is a jam in the right hand side of the machine. You may have fuser stripper fingers popped out of place causing it to jam or you may have a torn off piece of paper stuck between the registration rollers. Try spinning the black and silver rollers by hand and see if any paper comes out.
Posted on Jan 19, 2009
    Sergeant:
  • 378 Answers
Check out removing all the assessable trays that is there any paper jam in the lower area of the machine.also for a tiny small piece of paper.
  • 744 Answers
The paper might have not got stuck but it might have made some device to mislocate
  • Prakash Ram
    Prakash Ram Jan 19, 2009
    the papers that got stuck would have made some device to malfunction.
I try to print and it gives me a blinking j and then a 2
this error is a transport misfeed of the paper check there is no paper stuck in the machine it could be that the paper exit sensor pc2 is fault or the registration clutch is sliping or no good you can take the clutch apart and clean it but it is best to replace it the following parts are involved with the transport misfeed
registration clutch cl1 high voltage unit hv1 master board pwba
check pc2 sensor first then work your way down the list above
Jan 18, 2011 | Minolta EP1031/1031F CS/PRO Copier
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
I cannot clear the misfeed indicator light. i have check for misfeeds and i don't see any paper stuck anywhere but the light won't go away. i can't print anything with this light being on and none of the...
Your problems is the senssor actuators,change the actuator,see the first paper misfeed,if in the exit check the sensors and the actuators ,if in the vertical transport unit check the actuators,clean the rollers,if in the horizontal unit clean the trenasport roller and the syncron roller,and check aor change the transport or syncron actuator.
May 15, 2010 | Office Equipment & Supplies
Paper misfeed indicator light continues to blink even after paper
some machines will want all covers to be opened, then closed, for good reset. if you are having jams in the adf, then open all adf covers, and lift the adf upward, if it allows. also, try turning unit off, then back on. some jams only clear that way.
Apr 02, 2009 | Sharp AL-1641CS Laser Digital Copier
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
MISFEED ERROR AFTER POWERING DI 2510 PHOTOCOPIER
look for small black levers, and see if they have a piece of paper on it, or if stuck
Jan 22, 2009 | Minolta DiALTA DI2510F All-In-One Laser...
Misfeed
there is most likely a small piece of paper on a sensor/
remove paper tray and look inside, is there paper behind the tray? look at the tires are they bald and sniny? replace. Look at the tires and see if there is any scrap of paper there.
open right door and look down towards the paper tray, do you see any pieces of paper? there is a small black lever there, it's the sensor is it stuck?
look into the fuser (where it gets hot) ,you may have to remove it the paper sometimes gets crumbled like an accordion there, htere is also a small black lever there see any paper is it stuck?
Sep 15, 2008 | Sharp AL 1631 Copier
Misfeed and PDF failure
Thewre could be even a small piece of paper stuck. Try looking even closer, and even open a close the access lids to reset the triggered switch. Even a minute pice of paper in the wrong location can cause a sensor to be triggered and until it is reset it will not work.
Mar 31, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Sep 16, 2007 | Sharp AR-M455N Copier
Ricoh Aficio 2018D All-In-One Laser Printer Logo
57 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
