Question about SanDisk Sansa e250 MP3 Player
Changing from MTP mode to Autodetect mode from the computer?
My Sandisk sansa e250's screen is smashed, and I can't see anything... but I do want to use it as a portable harddisk. but unfortunately it's on MTP mode, so I need to convert all my files to the player and can't have anything else than music, pictures and videos on it. so what I need to do Is to switch from MTP to Auto detect mode, but since I can't see anything on the screen, I have to change it either by clicking the right buttons blinded or by changing it in some other way... anyone who can help me???
I actually have one of these I should be able to tell you the exact buttons to push to get there 1-click menu (of course) 2-push down 3 times 3-click enter 4-push up 2 times 5-push enter 6-push up/down ONCE 7-push enter That should do it!
Posted on Sep 29, 2007
You're pretty much screwed that way because the way to change the USB mode on the device is actually in the mp3 player's firmware, you'd have to navigate to the settings and somehow make your way to the USB setting. Sorry about your luck.
Posted on Sep 19, 2007
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
Sansa Fuze MP3
Disconnect the player, press and hold the power button till the player resets. Change the USB mode to MTP, then turn the player off and reconnect to computer. The computer should now recognize the player.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 05, 2009 | SanDisk Sansa e250 MP3 Player
Why won't my Sansa Media Converter recognize my Sansa e250 Mp3 player?
Mine won't read it in MTP mode. It works for me in MSC mode though.
Jun 27, 2008 | SanDisk Sansa e250 MP3 Player
E250
SETTING USB MODE
1. Select Settings menu in Main Menu.
2. Select USB
3. You can select AutoDetect or MSC mode.
Note: AutoDetect will default to MTP mode. The MTP mode supports Windows Media Player 10 only.
You must use the MTP mode to synchronize music files using Windows Media Player 10 for the optimal
system performance.
Mar 27, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
make sure the mode of the player is in MTP or if you have a version 2 player the default mode is MTP. If you are receiving an error about "Not Enough Space for Music DB please free 6mb" when turning on the player. Format the player using windows explorer and the mode should be in MSC.
Dec 07, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 drivers
Hi there , in the settings menu in your player if you go into usb you can change it to msc mode and it will read as a normal usb drive so you can transfer songs etc
Oct 20, 2007 | SanDisk Sansa e250 MP3 Player
Sansa mp3 player
If the player is in MTP/Autodetect you can just unplug the player from the computer. You can check this by going to the My Computer window and see if the player is listed and if it has a drive letter before it, if it dont have a drive letter then it means the player is in MTP/Autodetect you can just unplug the player from the computer.
Aug 13, 2007 | SanDisk Sansa e250 MP3 Player
Computer won't read mp3 player
Try checking for the mode the player is in, SETTINGS>USB MODE> choose MTP/AUTODETECT. It may be that the setting is in MSC that is why it is not being detected by your computer. If all else fails try updating your windows media player software.
Jul 23, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
121 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
