Question about Comdial 8324S-PT Corded Phone
Making the date and time show after the phone rings.
I have the date and time set. I know how to display that.
Feature 6 9 and hit go.
When the phones rings it displays Line 1 incoming ---1 UDC
When I pick the phone up it shows ICM. There is no green light showing on the phone.
After I pick the phone up again it shows a Red light at the top of the phone. (101)
  • 4 Answers
Sounds like you have several issues here...Time & date is set by entering the DB Administrator, then using the code 08-14. Feature69 defaults a set, not the time. The incoming display is normal, as you are a member of the first UCD group. When you pick up the phone, it shows ICM because you are in intercom mode. There are 3 different ITCM modes: green, red, blank. Your extension button lights red because it's an indicator that you are on the phone.
Posted on Apr 13, 2009
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
How do I change the Date and Time displayed?
You log into the Phone administrator settings, Go to General, Select Date and Time and correct them for the entire phone system.
To Log Into System Programming:
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
3. Press: NEXT Display will read: "B. General Admin"
4. Press Show
5. Select Date and Time and Press Show Correct Date and Time then press release. Let me know if you have any other questions.
May 16, 2011 | Meridian M9316 Corded Phone
How to set the time and date
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316. The 4 top line/feature keys are now used for programming.
the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Oct 25, 2010 | Nortel T7316E 2-Line Corded Phone
Trying to set the time on the phone but i dont know the password
Try feature **8463 (time) or feature **266344 (config). Either way, changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 8 4 6 3" or "* * 2 6 6 3 4 4"
7.- Select AM or PM
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
16.- Enter month
19.- Enter day
Aug 16, 2010 | Nortel T7316E 2-Line Corded Phone
Directions for time change are misplaced. Do not know feature code.
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Mar 15, 2010 | Nortel T7316E 2-Line Corded Phone
Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Sep 21, 2009 | NorStar M7208 Corded Phone
No ring for some phones after power outage- dks 930 phones
Press feature key then dial #* password 000000 next, go to sets, hit show, hit next till ringing assingment is display hit show and change from n to y on line ringing assingment. do this for each set and line that need to ring.
Dec 24, 2008 | Southwestern Bell Landmark DKS930 Corded...
Telephone ringing problem
Okay first you'll need to know the 2 digit "Set" number for your Phone.
Press "Featire" *0 then Intercom to get the 2 digit number.
Okay Now we need to configure:
Press "Feature" **CONFIG or **266344
Press: Next until "Sets" appears "press Show" Top Right Button
Enter 2 digit "Set Number"
Press Next Until You Get Ringing Lines
Hit the "Change" Button to Turn the Line to "Yes" to ring
Do this for each Line you have that you want to ring.
Done, Please Rlease.
May 27, 2008 | NorStar M7310 Corded Phone
How to change the time on screen
generic for all phones... the standard way to change the time and show it on screen is simply going to the settings and look for time settings... in here, you can actually change the time, the date , and the year and you can also change the time format form 12 hour to 24 hour.
Apr 08, 2008 | Lands Phones
Set time and date
hit the feature button (gray, looks like a globe on it) under the display, under the 3 gray buttons in a row.
then **8463
password is 23646
follow prompts :)
hit the hang up (phone with arrow underneath) when fone.
Jan 22, 2008 | Lands Phones
Comdial 8324S-PT Corded Phone Logo
260 people viewed this question
Top Comdial Lands Phones Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
