Question about Carrier 38CKC042 Air Conditioner
Carrier electric furnace
Last year furnace shut down and a technician fixed the problem. He said if you turn thermistat below 64% it will turn off again. I forgot what he said and turned the thermistat down to 62 and it doesnt work. How do i fix it?
    New Friend:
When I turn on thermostat the heater wont turn on but theres power coming out from main box but no power to electric panel or tranformer what do I do to fix it
Posted on Dec 26, 2014
    Problem Solver:
  • 5 Answers
What are you talking about. Turn the thermostat back up. It shouldn't matter what you set the thermostat too because it is just a switch that tells the temperature.
Posted on Jan 17, 2009
Carrier 58STA/STX furnace false starts even when off or temperature set lower than current.
Is it possible the drain is plugged? The newer furnaces have a moisture drain and will shut down if they are blocked., shutting them down and restarting will reset fault, but will come right back if not fixed.
Dec 24, 2014 | Carrier Heating & Cooling
In very very cold weather, our furnace is shutting down. Furnace is a lennox, about 17 years old The closest they've come to figuring it out appears to be that it's either overheating, or isn't starting...
I need a little more info I feel certain I can solve the problem I need to know a couple of things.
1- Model # of the furnace, take off the top door look to your right or left you will see a little metal data plate on the top of the plate you will see the model # If it is a horizontal furnace the data plate will be on the same side the controls are on .
2- Is the furnace a natural gas, LP gas, fuel oil or electric?
3- Does it do this when the temperature is above freezing?
4- If you could list the parts replaced it would be helpful.
A furnace properly maintained can last upwards of 25 years.
Dec 09, 2010 | Heating & Cooling
Gas Furnace will not start when outside temperature rises to 50F
There is a pressure switch near your draft inducer motor that needs to close when draft inducer motor is running. Verify that the switch is closing. If it is not closing, you might have a problem with either the switch itself, or there could be some sort of blockage in your flue. I would start with the switch first. This switch has to "prove" before it will allow anything else to happen. The loud click could be from your switch or your gas valve. If the switch is closing and nothing else is happening, it could be a problem with your gas valve or HSI.
Mar 12, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a Carrier 58RAV075 Gas Furnace. It appears
Make sure there is gas to the furnace, that the gas valve is on and that all electrical connections are tight. Look for any valve yhat may have been turned off.
Jan 11, 2010 | Goodman GMS90703BXA Heater
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Nov 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Auxilliary heat just started blowing cold air
SOund like you heating element has a open limit or the sequencer is bad. Another thing that it may be is the element wire has broken. Either way it sounds like you need a technician to come out and repair.
Jan 27, 2009 | Honeywell TH4210D1005 Heater
Code 32 when wind blows
Hi and welcome to Fixya. I believe that the wind is affecting the draft. What I would recommend is to install a cap on the flue that is similar to a weather vane in that it rotates to block the wind from creating a downdraft in the flue. Some times depending on the direction and strength of the wind it will come up over the roof peak and then down the flue. A regular fixed cap may work too. You should be able to purchase one at your local hardware store. Please let me know if this was helpful. Good luck.
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38CKC042 Air Conditioner Logo
152 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
