Question about Frigidaire FEX831C Stack Electric Laundry Center
Frigidaire Laundry Center (top load) dryer stopped working
I have the Frigidaire FEX831C Laundry Center (electric/top load) and just the other night after finishing a load of laundry, I went to tumble my clothes in the dryer to get wrinkles out and the dryer would not turn on, and still will not. I thought maybe the circuit breaker in our house had popped but after resetting all of the switches it still will not work. The washer, however, does work. It will wash a full load of laundry from beginning to end. I thought maybe there was no power getting to it, but then realized that the washer and dryer share the same power source and power cord. Is there a circuit breaker inside of the dryer that may have popped?
Dryer tub loose
Posted on Aug 23, 2009
How do I replace the dryer belt?
Hello Philip, I appreciate your inquiry!
Based off the information you have provided you need help with replacing the belt on your Frigidaire laundry center. In order to access the pulley you would need to disassemble the laundry center. I would recommend seeking assistance from a professional technician for proper disassembly of your laundry center. Incorrect disassembly could cause personal harm or future issues within the laundry center. Best of luck! -Matt
Dec 15, 2015 | Frigidaire FFLE2022MW Electric...
WONT STOP FILLING
there is a clear hose running up the left front of your machine that goes to a pressure switch, either the hose is clogged, has come loose , or the pressure switch is bad
Dec 21, 2014 | Frigidaire FEX831C Stack Electric Laundry...
READ FRIGIDAIRE ERROR CODES
Hello Rob Olsen, I appreciate your inquiry!
I understand that you would like to have information upon reading error codes for your Frigidaire laundry center. I was able to locate a manual that has information regarding error codes for your laundry center. I hope this information is helpful to some degree. -Matt
Frigidaire Manual Search Results
Nov 09, 2014 | Frigidaire FFLE1011MW White Washer/Dryer...
How to reseat the dryer on a fgx831cs dryer
Hi Amy, this is AP!
I understand you want to reset your Frigidaire gas laundry center, model FGX831CS. For this particular model laundry center I would recommend turning the breaker to the appliance off for 5-6 minutes, and then turn the breaker back on. This action will reset the laundry center completely for you. If you can provide additional information describing the malfunction or symptoms you are experiencing with your laundry center I may be able to provide more useful troubleshooting or an explanation.
Thanks,
Apr 03, 2014 | Frigidaire FGX831CS Top Load Stacked...
Can the wash tub be replaced? Where can I buy a new tub?
yes the tub could be replaced here are the part numbers
INNER TUB 131370400
OUTER TUB 131557201
it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
Aug 14, 2011 | Frigidaire FEX831C Stack Electric Laundry...
Dryer is making a high pitch squeak, sounds like a rusty swing. possible bearings
You probably have dry bearings from all the heat over the years. Unplug the unit and remove the back to expose the bearing and shaft. Using a light oil such as 3-in-1 squirt oil into the bearing and let it soak in. Do this several times and keep a rag under the bearing to catch any excess oil. Odds are that with a little lubricant the dryer will quiet down and work fine for many more years. This would also be a good time to clean any lint and dust bunnies out of the unit. Reassemble and test. You should be good to go. Let me know if I can be of anymore help.
hardrocko
Thanks for using FixYa
Feb 20, 2010 | Frigidaire FEX831C Stack Electric Laundry...
Washing Machines Logo
460 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
