Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Sending Inverted Image
Brother Intellifax 4750e is sending inverted images. Receiveing fine, just sending and confirmation are basicly inverted.
  • carmella450 Feb 17, 2009
    I tried cleaning the drum contacts but it still does not work. Sent faxes are black background with white image.
Actually I read something about static being a problem....I unplugged the unit for about a half hour. When I tried it after that...it worked...coincidence?? not sure, but it's still working.
Thanks!
Posted on Feb 18, 2009
  • 215 Answers
Cleaning the drum contacts will do no good when it pertains to SENT faxes. chances are, your CIS is either dirty or is bad. lift up your control panel and look closely. you will see a piece of glass under the panel, about 1.5" wide and runs left to right . clean the glass real good with windex or alcohol and rag. look above the glass and you will see a white bar/plate. clean that as well. if that doesn't do it, then most likely the CIS, which stands for contact image sensor, will need replaced.
hth,
razors
  • Ray M. Feb 19, 2009
    cool. i've not heard that, but its good to know. thanks.
    razors
    Champion:
  • 320 Answers
Do you mean that the blacks are white and the whites are black? do they look like a negative. if the aswere is yes it siund like you have dirty drum contacts when you take the drum unit out look on both sides of the drum cavity for contacts and clean with a pencil eraser. then clean the drum unit grid,
brother tech
Posted on Jan 16, 2009
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
Turn off error correction mode for Brother 4750e
I found this video I have embedded below which claims to instruct you on how to achieve this.
Mar 13, 2015 | Brother Intellifax 4750e Laser Fax Machine
Speed Dial Setup on Brother IntelliFax 4750e
pdf.textfiles.com/manuals/FAXMACHINES/Brother%20Fax%204750e-5750e%20User%20Guide.pdf
Apr 03, 2009 | Brother Office Equipment & Supplies
Can't find info - comfirmation
Its called "Transmission Verification Report"
Press Menu, 2, 4, 1
Select ON or On+Image
This will come with every fax you send.
If you want to customize, see owners manual under, "Printing Reports"
Oct 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax Confirmations
1) Menu/set
2) 2
3) 4
4) 1
5) Press + or - "ON" or "ON+ IMAGE" to have confirmation with a preview image of the first oage you sent
6) Menu/Set
May 01, 2008 | Brother IntelliFAX 2800 Laser Fax
You need to open the front cover, then press the "Clear" button, and then press "1". This will reset the drum counter.
Mar 27, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
114 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
