EMachine T6534 Ram Issue
Ok so i've had 1gb (2 x 512mb) of ram for a while now and i've decided to upgrade it. I went online and did the research and found the ram and bought it. I got two 1gb sticks, I went to install them and my computer would boot up to the windows xp screen and after its done loading the screen went blank. So I took out all of my sticks and just put my new ram in (the 2 x 1gb) and the computer booted. Now the config of the ram goes green(ch1) purple(ch1) green(ch2) purple(ch2) in that order away from the cpu. I can fill up the first three, the two 1gb are in the green channels and one of my two 512mb sticks are in the first purple. My computer will boot perfectly like this. Once I put the last 512mb or any stick (because i've tried it with the 1gb too) the computer will not boot fully. I have a K8NGM2-H motherboard and says something about a north bridge setup not allowing 4gb if you use a 1gb stick in each slot, I did not think this would apply to 3gb when you fill up all of the slots.
If you could help me with this problem it would be appreciated!
Thanks!
  • treasujm Jan 16, 2009
    According to the MSI webiste if I put 4x1gb sticks in it will only read up to 3gb.
    "Due to the South Bridge resource deployment, the
    system density will only be detected up to 3+ GB (not full 4GB) when
    each DIMM is installed with an 1GB memory module"
    http://www.msicomputer.com/product/p_spe...
    Problem Solver:
  • 7 Answers
Did you try putting 4 1g stick . instead 2 1g and 2 512?
Posted on Jan 16, 2009
  • ironclaw Jan 17, 2009
    Any 32 bit OS will only read 3G . but you trying to run in dual channel mode , you need matching memory sticks.that is why I suggested you put four 1G sticks. in dual channel you can run 4- 512 sticks or 4 -1G sticks . if you run 2-1g sticks and 1or 2 -512 sticks you will be running in single channel mode
I have an eMachine desktop/tower 3230. I need bios upgrade for extra Ram ...
Hello visit emachine here:
http://support.gateway.com/us/en/emac/default.aspx
And select your pc model by number.
Remember to select the right model, because flashing the bios with a wrong one will destroy the mainboard.
I have newer heard that a bios upgrade was necessary to upgrade the ram.
Some mainboards do have a limit of 2gb ram, and the bios upgrade does nothing to that.
Try to clean the pc out for dust, and renew the the cooling paste between the cpu and the cooling element.
One of the ram modules could have a defect.
Try to test one module at the time.
If you get the blue screen of death, the problem is elsewhere like power supply, or harddrive.
Good luck
Jan 17, 2013 | MSI 6714 i845GL Chipset 400/533FSB...
Dnt have enough ram to install internet. how do i update my bios so new ram will work on emachines 400i3.
I did a little research on this model, and sadly it may be time to put it to pasture. It uses Win 98 with a 4GB drive. This tells me it just can't handle today's media rich internet. Let alone finding a BIOS upgrade.
GL
Jan 09, 2013 | FSP Emachine eTower 400i3 Power Supply...
My laptop will show light on the board but not displaying on the screen. It went off while trying to upgrade the ram size.
Isolate the problem by putting the old ram back in and see if it works like it did before you upgraded the ram. if it does, you know you've got an issue with the ram.
If it does not work with the original ram, then either your lcd screen or the video card might have issues.
May 11, 2012 | NEC Computers & Internet
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
I have ACERT EMACHINE 250 NETBOOK THAT BROWSE VERY SLOW AND I AM USING WINDOW 7..PLS WHAT COULD BE THE POSSIBLE PROBLEM AND HOW CAN I RESOLVE IT. THANKS
In that case you should upgrade your Ram,memory and graphics card.If you are using 1gb Ram then upgrade it to 3gb by adding 2gb Ram.Then you can see the difference.You can also upgrade your memory like that.If you are using 500gb Memory then upgrade it to 1tb Memory.Then you can see and feel much difference.Upgrading graphics card is an optional thing.If you upgrade it you can see difference in gaming and in your system graphics.
If you do all this things surely your system will improve it's performance.
Apr 07, 2011 | Computers & Internet
Emachine E725, RAM is 1GB can i upgrade it to 2 GB
Bijay, Each mother board is capable of taking certain amount of RAM. Please check your User Guide. If not available there then you can try it out at the dealer's place. Unless you have a deal with him to take back the RAM if it does not work.
Jun 13, 2010 | Acer eMachines E7254520 Notebook PC
MEMORY/RAM problem, system won't acknowledge both slots of memory
You might have on-board VGA card which take 8 Mb (shared) in memory taken from extended memory card.
My suggestion, use exactly similar memory card ( same PC clock, either 400/533/667/etc. If this won't work, try to clean the memory slots with brush.
Apr 10, 2010 | Computers & Internet
BIOS will not expand to 2GB RAM
try each ram one by one. if there is prob in ram it will show only 512 instead of 1 GB.. Second check for memory shared in bios
Sep 30, 2009 | E-Machines eMachines Desktop PC
Emachine T5212 Ram Issue
Check the e-machine website for its frequently asked questions and troubleshooting sections on you make and model of computer. Someone may have had the same problem and had a answer posted. Also check for the types of memory recommended for use in you model, check this list out with the type you are using. IF all that fails purchase a recommended memory pair and see if they work. If not you may indeed have some problem with the memory slots. Try cleaning the slots with spray on instant dry contact cleaner and a small brush like a toothbrush or horse hair brush. See if this improves the connections enough to let the unit use both memory sticks.Hope this helps you with your problem.
May 09, 2009 | E-Machines eMachines Desktop PC
Upgrading RAM
Incompatible RAM could be the problem. The new RAM may be too fast for your motherboard. Hope this helps.
Dec 27, 2008 | Dell (E210882) Motherboard
Computers & Internet Logo
675 people viewed this question
David Payne
David Payne
