Question about Samsung HLP5067W Television
I NEED THE PART NUMBER TO REPLACE THE COOLING FAN IN MY HL-P5067 swAMSUNG TV.
    Champion:
  • 240 Answers
If your hearing a loud fan noise it 99.9%
not the fan but the colorwheel assembly part number is Bp96.00674a
regards,
daniel.
Posted on Jan 16, 2009
Will not turn on and says "check 2nd fan"
Thats indicating that the number 2 fan needs replacment. You can get the fan for your model from www.tvrepairworld.com under the Samsung cooling fan category.
Aug 20, 2011 | Samsung HL-S5087W DLP TV
CHECK NUMBER 3 FAN WARNING. THEN TV SHUTS OFF
Hello
The set gives you protection warning. One amoung or all cooling fans are not working. Its system control IC detected the fault and displays it to you and shuts off the system to protect it from further damage. Check the fans for proper working. If anyone found defective replace it. Do not switch ON the set until this fault has been rectified. OK.
Jun 27, 2011 | Samsung DLP HL-P5663W 56" TV
Cooling fan is loud on initial start up and calms down after a couple hours use. Can I change out the fan and what is the part number on the HL-P4663W?
This tv internal curcuitries and manchanical design have a colors wheel in it.The tv have loud squiling noises,motor noises,black&white or colors flickers and fating.All the effect of the tv colors wheel is dying and spinning off of it motor axis.Cooling fan make noises for a couple hours,calm down,no way.The fan would have stop functioning,way before that.
Jul 21, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
How to replace faulty lamp cooling fan on HL-P6163W TV
A more likely candidate is the color wheel,unless your sure it's the fan
Dec 01, 2009 | Samsung HL-P6163W 61" TV
Have lamp cooling fan noise on Samsung HLP5063W - 50 when I turn on TV and screen is distorted. Noise on TV is gradually getting worse and now does not go away and I essentially have no picture. Do I need...
the problem with your tv is the color wheel
not the fan let me know if you need help to take it apart...
I do repairs for samsung tv and I fixed a lot of them before..
Jul 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Cooling fan motor is making loud humming noise
You will have to pull out the light engine. That will consist of 4 or more screws and disconnecting some plugs. The the whole unit slides out where you can get to the fan housing.
Unless you're mechanically inclined, you should not try it as you could damage the assembly.
I don't know the part number off hand and some of those have newer part numbers as replacement for the original. Just do a google search to come up with a part number.
May 18, 2009 | Samsung HL-S5087W DLP TV
Cooling fan buzzing
Yes,don't do it yourself,and you need to have repair tech. asap,cause if the cooling fan is not working properly,that could trigger other parts in the tv to be malfunction.
Hurry,just it fix!
solutiondoct
Nov 01, 2008 | Samsung HL-R6167W 61" HDTV
Fan Noise
there is a cooling pan inside... replace the cooling fan inside..
Oct 05, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLP5067W Television Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
