Question about Palm TX Handheld
Unable to set up blue tooth Hotsync to Palm Tx
Have added a virtual serial port using the add bluetooth com port tool in control panel of windows xp. Have ticked local in hotsync menu and setup the comport in the local tab in the setup menu. Device is able to able to hotsync using the USB port. Is there a patch/plugin I can download to enable this to take place (have intel processor) in computer.
    Brigadier General:
  • 8,619 Answers
Hi!
Are you unable to connect using both usb or bluetooth??
There are essentially three ways to connect your Palm to your PC via Bluetooth: Use PPP Software and a Bluetooth Serial Profile -- this uses a "virtual" serial port to communicate to the PC. MochaPPP and SoftickPPP allows the Palm to share the desktop's internet connection. This method works with the most Palm OS releases and versions of Microsoft Windows. It also sheilds you from details about IP addresses and such
Windows 2000/XP Internet Connection Sharing (ICS) and a Bluetooth LAN Access Profile -- this uses a direct connection to the PC. Windows 2000 and XP include a feature called Internet Connection Sharing (ICS) that allows the Palm to share the desktop's internet connection.
Windows XP Remote Access Server (RAS) and a Bluetooth Serial Access Profile -- This is an alternate connection method for Windows XP that is similar to #1 above in that it uses a virtual serial connection but doesn't require MochaPPP.
Ask for any clarifications
Posted on Jan 16, 2009
  • Rylee Smith
    Rylee Smith Jan 16, 2009
    You can also create another palm user identity on the TX already which has been hot-sync-ed before by bluetooth on previous computer. For this example, that TX user identity is called TXorigUser
    1. Install Belkin bluetooth software onto your pc or laptop. When prompted to create a bluetooth name for the laptop go ahead and make one up, [eg.pcnew]. From the services offered you will need to choose hot-sync[.tm], not active-sync,. I unchecked secure connections, as my sensitive data is already encrypted, and I didn't want to risk problems. A new port will be created [com4] [which Palm Desktop will later use when it creates a hotsync sys-tray button].
    2. These next 2 parts need to be done carefully on the TX as stated, not by double clicking the bluetooth button on the TX which will not bring up the right options. On the TX go to: Preferences / Communications / Bluetooth [switch it on if it isn't already, and make discoverable]. Create a bluetooth identity for the TX if there isn't one already, eg txblue.
    3. On the same screen, bottom centre, click on setup devices, next screen select: 'pc setup' click the second option 'bluetooth setup' and find your equivalent of pcnew in the nearby devices [assuming the pc has bluetooth switched on and is in discoverable mode].
    4. Pair the TX bluetooth identity with the laptop bluetooth identity, another name needs to be created for the pairing. [eg.PairTXnew]. The TX should prompt for a user-name and password for the computer which is your actual Windows XP [administrator] user-account [eg.MyXP and password].
    5. You will be prompted to create a unique password of between I think 4 and 32 characters for the pairing, probably first by the computer and then the TX will be requesting it too. The two devices will use it to automatically check identity before accepting the pairing.
    6. Before hot-syncing, click the computer's systray hotsync icon, Setup/local/com4, com4 is only available when the Belkin bluetooth dongle is in and live [bluetooth sys-tray icon blue/white].
    Thanks
    Rylee
  • 1,031 Answers
Ok, first, which COM is your Bluetooth Serial Port using?
Second, here's what you need to do for Palm Desktop 6.2:
  1. Double click on the HotSync Manager icon
  2. Select the Connections button on the left
  3. Check the Box next to Bluetooth.
  4. Click Done
    Brigadier General:
  • 3,614 Answers
Update for TX
  1. After downloading the file (above), double-click the file you downloaded; the Palm Install Tool will appear. If asked, select your Palm TX handheld's user name.
  2. Perform a HotSync operation to move the file to your handheld.
  3. Once you've synchronized, press Applications Unable to set up blue tooth Hotsync to Palm Tx - 650_app.gif.
  4. Tap on the application named TXCradleFix.
  5. The update will be applied to your device.
    President:
  • 2,110 Answers
Configure Bluetooth HotSync Now your desktop PC and Palm device will not need to authenticate each other before they connect. Once you've set up the trusted pair, you can tell your Palm device to sync with your desktop PC.
Depending on your device, you may see slightly different screens and options. The instructions below are a general guideline for setting up Bluetooth HotSync.
Unable to set up blue tooth Hotsync to Palm Tx - cccccc.gif On your Palm device, launch the Prefs application and select Bluetooth. Select Setup Devices. Select HotSync Setup¹ or PC Setup¹.
If asked, select Bluetooth HotSync.
The option you see may be slightly different; or you may not see this option at all.
13950_1.gif The nUnable to set up blue tooth Hotsync to Palm Tx - 13950_2.giftells you about the process you're abouUnable to set up blue tooth Hotsync to Palm Tx - cccccc.gifgo. Select Next. spacer.gif 13950_2.gif Next, your Palm device searches for available Bluetooth PCs. From the list, select your desktop PC and select OK. spacer.gif Unable to set up blue tooth Hotsync to Palm Tx - cccccc.gif"http://i.fixya.net/uploads/images/cccccc.gif" alt="cccccc.gif" class="h_mi" /> On your desktop PC, you'll need to create a virtual serial port. Follow the instructions that came with your desktop PC or the Bluetooth card to do this. After creating the virtual serial port on your PC, select Next. spacer.gif 13950_4.gif cccccc.gif LauUnable to set up blue tooth Hotsync to Palm Tx - spacer.gifc Manager on your desktop PC. Then .Unable to set up blue tooth Hotsync to Palm Tx - 13950_5.gif class="h_mi">
  • WinUnable to set up blue tooth Hotsync to Palm Tx - cccccc.gifIn the Windows System Tray, right-click on the HotSync Manager icon, and select Setup. Click on the Local tab. From the Serial Port menu, select the virtual serial port you created earlier. Click OK.
  • Mac: Click on Connection Settings. If available, select "bluetooth-pda-sync-port" or select the virtual Unable to set up blue tooth Hotsync to Palm Tx - spacer.gift you created earlier.
  • Unable to set up blue tooth Hotsync to Palm Tx - 13950_6.gifyour Palm device, tap Next. 13950_5.gif cccccc.gif On your desktop PC ...
    • Windows: Right-click the HotSync Manager icon in the system tray again. Make sure Local Serial is selected.
    • 13950_6.gif cccccc.gif On the next screen, there will be a button for Launch HotSync. As soon as you tap this button, your device will begin to sync with your desktop PC. Note: Once you've set up Bluetooth HotSync, your device will sync wirelessly whenever you press the HotSync button on the cradle or cable, or whenever you tap the HotSync icon in the HotSync application. This will happen even if your device is connected to a USB HotSync cable.
    • 679 Answers
    What software you are using to connect the device?
    • rockfixya
      rockfixya Jan 16, 2009
      please provide me some more information regarding Software.
      Thanks
    Unable to connect hotsync with desktop
    Palm 515 Hotsync unable to connect to Desktop - Expansys ...
    www.expansys-usa.com > Forums > Palm > Palm m515
    Jun 29, 2004 - 6 posts - ‎5 authors
    I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
    Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
    www.turbostats.com/support/hotsync.html
    Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
    unable to connect to computer to hotsync via network or cable
    forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
    Jul 30, 2008 - 10 posts - ‎6 authors
    i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
    Jan 24, 2011
    Hotsync problem - unable to establish desktop ...
    1 post
    Oct 19, 2004
    Unable to Hotsync - Identifying user? ' Brighthand.com ...
    Mar 16, 2004
    Unable to Hotsync Palm IIIxe with a USB connection ...
    Dec 18, 2002
    More results from forum.brighthand.com
    Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
    Unable to connect with desktop through usb cable
    Jan 24, 2011
    1 post
    Oct 19, 2004
    Mar 16, 2004
    Dec 18, 2002
    Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
    h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
    Jan 03, 2016 | Palm TX Handheld
    Unable to connect
    Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
    ... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
    db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
    www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
    I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
    Setting Up Your Palm Device's Internet Connection - For ...
    www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
    Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
    Bluetooth syncing problem ' Apple Support Communities
    discussions.apple.com > Support > Apple Support Communities Apple Inc.
    Bluetooth driver
    If you use windows XP or VISTA OR Windows 7 no need to driver for blue tooth configure.
    Only the driver need for 98.
    Follow the instruction with the link
    http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html#e2
    Windows XP Bluetooth Device Setup
    Windows XP comes with a Bluetooth configuration utility that you can use to help define a new device that we can connect to. We will use this utility to set up a virtual serial port that we can use to communicate with the Bluetooth enabled Garcia.
    This configuration utility can be found under the Windows Control Panel, then launch the Bluetooth Devices application.
    Click the "Add" button to begin configuring the virtual serial link as shown in the following image
    1. just enter your Bluetooth in your pc.
    2. when the icon show your task menu bar just
    3. double click on icon
    4. add>check on my device >next(ensure phone Turn BT on )
    you can see the phone model which Bluetooth on.
    just select the device >choice any ask code >I will advice you, please select, let me choice> type any 8 digit >next >now the same number > in your mobile >finish
    For dial up go r click on my network>properties>create a new connection> connect to internet>next >set up manually>connect using dialup>select your mobile modem>next >type any name >type the exact name and number eg: for Airtel=*99#>next >no user name and password just next >check on add short cut>and finish.
    Just double click on the icon, it will connect soon.
    Or
    you can install PC suit and set it through the following step.
    Setting> Setting >participate tic on yes .Double click on phone icon >next>tic on Bluetooth connection >next >select yes the phone mobile>next
    Remember always set the mobile for connection select the yes.
    Hope it will help you.
    Regards
    Shibuda
    Jan 05, 2011 | Computers & Internet
    I am using Windows 7 and want to Hotsync my 1000s of Memo Notes from My Palm Treo 650, I got the latest Palm Desktop and Hotsync Manager but My Computer cannot Hotsync or even detet my Treo 650....Pls...
    Palm Desktop compatibility with Windows 7 and 64-bit editions Palm Desktop 6.2 was designed for 32-bit editions of Windows XP and Windows Vista. You may be able to use this software with other versions of Windows.
    Windows 7: Many users have successfully installed and used Palm Desktop 6.2 with Windows 7. Palm has not done thorough testing with a range of third-party equipment running Windows 7, therefore Palm cannot guarantee compatibility.
    64-bit editions of Windows: USB HotSync is not supported. Instead, synchronize through a Bluetooth wireless connection: set up Bluetooth HotSync.
    http://kb.palm.com/wps/portal/kb/common/article/49229_en.html
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
    Dec 18, 2010 | Palm Treo 650 Handheld
    Is there a way to use ique 3600 with windows 7? ique does not syc.
    I am using Windows 7 Ultimate 64 and the iQue did not work. There is no USB driver and as far as I know there isn't going to be one. However, I did get it working by installing Windows XP mode and the Windows Virtual Machine on my XP system. You need to check if your computer can run XP mode and there are Microsoft tools to do that. After you get XP mode installed and running, there will be a virtual XP window on your desktop. Plug the iQue in its cradle and plug it in to the USB port. Use your iQue setup CD to install the Palm desktop in XP as you normally would. At some point, you have to tell XP to attach your iQue to the USB port. Near the XP title bar, there is a USB pull-down menu. Use this to attach the device. It will ask for a driver. Just say to use the Garmin-supplied driver. Wait until this finishes successfully. Before trying a sync, open the Palm desktop and go to Hotsync/custom and change everything you can to "handheld overwrites desktop" and save this. Push the hotsync button on the cradle. If it doesn't connect, go to the USB pull-down and click attach. It should work!
    Dec 08, 2009 | Garmin iQue 3600 GPS Receiver
    Hooking a Palm TX to internet on bluetooth cell phone
    6620 blue tooth is supported on Palm TX. Im not sure about Gzone. It does have limitations to it when using you TX to connect to a bluetooth cell phone for data service.
    You can try the GPRS cell phone setting and see if it recognizes it that way.
    Oct 08, 2008 | Palm TX Handheld
    HotSync Problem!!
    You have at least one application that is attempting a serial connection with the PC and is triggering hotsync instead. Many palm apps that allow live updating to your device when cradled or over blue-tooth can cause this type of error. I would take inventory of any software you added recently to your device or port settings you may have changed, especially regarding direct connect and cradle settings.
    Sep 28, 2008 | Palm Treo 500 Centro
    Imate jam PC synch
    dear abid, connecting the i-mate to computer using bluetooth is a good and a fast way and give you the an option to connect more than one device, you can connect through bluetooth with this procesure : step one: set up a bluetooth COM port : 1- Open the Bluetooth Devices Control Panel. On the Options tab, select Turn discovery on and Allow Bluetooth devices to connect to this computer. 2- On the COM Ports tab, click Add. 3- Select Incoming (device initiates the connection) and click OK. 4- Note the number of the COM port that was added. The COM port number must be no higher than 20. 5- Click OK to close the Bluetooth Devices Control Panel. step two: 1- In ActiveSync on the PC, on the File menu, click Connection Settings. 2- Select Allow connections to one of the following. 3- Choose the COM Port with the number you noted in Step 1 Set up a Bluetooth COM port. 4- Click OK. Step 3 Start Bluetooth sync from your device: In ActiveSync on the device, tap Menu, then tap Connect via Bluetooth. that's all... and i am waiting for your replay
    Jul 27, 2007 | i-mate JAM Pocket PC
    I Mate Jam Blue Tooth sync
    dear sir , when you try to connect using bluetooth you have to define the COM port from the control panel >> bluetooth devices then you add a new port and remember the number of it . then open Activsync. click on file >> connection setting then check this option : allow connections to one of the following .. then choose the COM that you just add it from the control panel. it will works now
    Jul 03, 2007 | i-mate JAM Pocket PC
    Palm TX Handheld Logo
    73 people viewed this question
    Top Palm Computers & Internet Experts
    Michael Vincent Cruz
    Don Eagan
     steve
    steve
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
