Question about Kenmore 22422 Top Load Washer
Water fill valve on Kenmore series 90 top fill washing machine
Need suggestions on how to remove water fill valve and test it to see if ok.
  • Kenmore Master
  • 8,220 Answers
To get into the machine read THIS first.After you have accessed the innards then you can easily remove and check the water valve. . Hook the water up to the valve. Get a suicide cord and apply 120 vac to each of the coils and see if they open.
Posted on Jan 21, 2009
Kenmore 90 series washing machine wont go into rinse cycle.
if it will just not fill try it on warm rinse if water comes in hot the water valve on the cold side could be plugge usualy repaired by removing the hose and screen and cleaning if the screen is clean you may need a new valve.
Mar 08, 2011 | Kenmore Washing Machines
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Kenmore washer 90 series will not fill up with water
You can shut off the water, then remove the hoses to see if the screens on the fill valve are gunked up. This is much easier to do than to replace the valve. I think you'll have sucess on that route :)
Aug 09, 2009 | Kenmore Washing Machines
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Ont stop filling with cold water
Hi. the pressure sensors in the water valve assembly appear to be damaged. you will need to replace the inlet water valve assembly in this case asap.
This is solenoid failuer. (basic water valve failure this case)
May 31, 2009 | Kenmore Washing Machines
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
HELP ME WITH MY PROBLEM
if water stops when knob pushed in raise console (probably screws under each end cap just pull caps toward you to remove )remove screws lift console ck small hose going to water level switch to be sure it is pushed on ..if water will only shut off when faucet turned off replace fill valve
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Just a trickle of water during rinse cycle
HI thanks for your question. the cold water valve either has a clogged screen or a faulty water valve. remove the cold water hose and clean out the screen, try again. could be all you have to do. if its acting the same. replace the water valve. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Kenmore 24902 Top Load Washer
Kenmore 22422 Top Load Washer Logo
767 people viewed this question
Sal De
fordexpert
Robert Rankin
