Question about Sony UY-S100 Film Scanner
Computer not readimg scanner.
I'v loaded the driver's and checked all the connections and still thew copmuter give's me "Scanner connection error-check scanner connection and power supply". Can you help me? Andrew
  • Anonymous Nov 20, 2007
    please i have the same problem, i don´t know ohw solve this problem
It is SCSI device, not USB !!!
Posted on Mar 11, 2008
    Genius:
  • 2,985 Answers
Unload all software, and delete all drivers. Disconnect the scanner. Restart the Computer. Go to Control Panel/system/Device Manager/Hardware and check the staus of the USB connecvtions Any Yellow markers? Assume no. Re instal software from CD from Scratch. only connect the device when told to do so. Come back with the rsult
Posted on Jun 19, 2007
SOURCE:
I cant get the scanner to work it just comes up error loading
See that all cables etc are properly connected and that the scanner has up to date drivers. You may have to go to the Epson site and download them for the correct model.
Mar 08, 2015 | Epson CX5900/CX6000/DX6000
It gives me this message: Scanner not connected I install, the neat scanner, check everything is connected correctly but nothing. Please help me. thanks
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
Jun 03, 2011 | Computers & Internet
I have Daewoo Takuma 2002. It is not going to start now. I have checked many mechanics but all in vain. All the circuits and fuses are in good condition. Could you help me in sorting out the problem. ...
You can buy a bluetooth scanner on line for 20USD. Use a smartphone or tablet and find OBD2 free app to connect to the computer through the scanner. Retrieve DTCs from car's computer and post here for assistance troubleshooting your vehicle.
Sep 28, 2017 | 2002 Daewoo Lanos
Hooked up scanner but the wizard cannot find the hardware/software to connect to...what am I missing?
If you have the install cd do not connect the scanner until the install prog asks you to.
Jan 06, 2011 | Computers & Internet
We have missed the setup of scanner now we need new set up to run scanner please give us free driver and setup to run the scanner.+
Hello lati662,
The 1st thing you should do is to check the operating system of the computer which you will connect the scanner and then go to the website of the manufacturer of your scanner and download the right driver for your installed Operating System
Aug 03, 2010 | Computers & Internet
Scanner is not communicating with computer
Dear,
First of all, check All desire cable is connected to computer.
Power cable of Scanner and data cable (USB, COMM) connect to computer.
Install Driver of the Scanner,
if u not have a scanner driver, search on the Internet with the scanner model.
for further instruction
Contact with me.
Dec 11, 2009 | Symbol Office Equipment & Supplies
I try to scan a document and it says that I am not set up on pc. I use just the scan button and it still won't scan. Help please!!!
Verify cables connected properly to the back of the scanner
If the scanner is a parallel port scanner it is likely it has two available connections on the back of the scanner. Verify that the cable coming from the computer is connecting to the IN, Computer IN, computer, or similar connection.
Ensure that the scanner is getting power
If your scanner is not getting power it is recommended that you check the connections ensuring that they are connected properly to the back of the computer and from the scanner to the wall. If you have the scanner connected to a power strip and or surge protector it is temporarily recommended that you connect the scanner directly to the wall.
If the computer scanner is getting power, you should notice the inside light come on when the power is first received by the scanner.
After checking the connections you still get no power to the scanner, it is recommended you contact the manufacturer of the scanner.
Additional parallel port scanner troubleshooting
If you have another device connected in between the scanner and the computer, turn off the computer and temporally disconnect the devices connected to or from the scanner. If, after disconnecting these devices, the scanner works, it is likely that another device may have issues or may be unable to work with other parallel devices.
PC Windows users verify no TSRs are running in the background
Press CTRL + ALT + DEL and end task all currently running software except explorer and systray and attempt to scan again. If this resolves your issue it's a possibility that an application in the background such as a virus utility is preventing your scanner from scanning.
Verify the LPT port mode
PC users ensure that the LPT port mode within the computer BIOS is set to either EPP or bi-directional mode and/or try alternating between these two modes.
Update the drivers
Verify that the latest drivers are installed for the operating system being used on your computer. A listing of computer scanner manufacturers and links to the drivers pages can be found on our scanner drivers page.
Nov 19, 2009 | HP LaserJet 3055 All-In-One Printer
Loading HP scanjet 4800 onto vista
Hi there from Germany - English isn't the best but got the same problem solved so give it a try:
- first connect scanner to computer without having the drivers already installed
- next computer claims driver cd put in yours from XP or select downloaded XP-driver
- reboot
- try if scanner works - sometimes they do already
- if not head over to System management or system control what it's called in english
- choose add device and choose scanner
- now Windows tries to install a xerox-driver - allow this
- reboot
- and now it should work - if not sue hp! (But buttons for direct printing etc. might not be working anymore - except via the software itself - no more via the buttons
Hope I could help
Dec 20, 2008 | HP Scanjet 4400c Flatbed Scanner
Need driver for Artec e+48u compatible with vista
I've used this scanner on both Windows Vista and 7 by running the driver installation from the original disk in Windows XP compatibility mode and then plugging the scanner in to the computer.
Dec 14, 2008 | Visioneer 4400 Flatbed Scanner
Sony UY-S100 Film Scanner Logo
350 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
