Question about Kuppersbusch EEB 6600.0 MX Stainless Steel Single Oven
Oven spare part
I have a Kuppersbuch EEB6600 single oven, the thermal overload as broken. Where can i get a new one from ?
I live near Manchester United Kingdom.
Thank you in advance
    Genius:
  • 2,920 Answers
You would probably have to order it through an appliance shop in order to get the right one. you could try ordering it online but your best way is to go to an appliance shop and have them order it for you
Posted on Jan 16, 2009
GE oven locked I cannot unlock
check continuity of the oven lock thermal switch located on the inside rear wall of the oven above the oven cavity near the fan,if under 177 degrees it should be closed and show continuity if good check pins an wires on pins 2 & 3 on the control board that connect this thermal switch
Mar 08, 2012 | GE JKP15 Electric Single Oven
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
Oven shut off - no power- checked circuit breaker no problem. oven came back on thye next day and is working fine. is this an overheat problem -is there a circuit breaker on the oven that resets? what...
This sounds like the thermal overload operated and turned the oven off. The overload is generally located in the top of the oven cavity. Remove the top cover and you should find it. Sometimes it open circuits the active supply and sometimes the neutral. Sounds like it may need replacing.
Feb 15, 2011 | GE Profile JTP18 Electric Single Oven
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
I recently put my oven through the self clean cycle then the next day neither the oven element or the broiler element will heat up. There is power to the control panel.
Probably the Thermal Overload Sensor burned out from the excessive heat during the cleaning cycle. It Is located on back side of oven.
Sep 29, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven has power; wont heat
It's mounted on the rear of the oven. First, turn off the circuit breaker, then the oven must be removed and the back panel taken off to access the TOD (thermal overload device). Its mounted right flat against the oven rear panel, with one large red wire attached on each end. If the TOD is open, that means the rear of the oven got too hot or the TOD failed (its a safety device). You can connect the two wires together and insulate with electrical tape, restore power and test the heaters to make sure the TOD is actually the problem. They haven't ever solved this problem...the most current answer is to replace the TOD with a new one, but bend the mounting tabs so that when the new part is installed, there is a space between the TOD and the oven sheet metal about the thickness of a dime. Then reassemble and reinstall the oven.
Apr 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
Oven cooks at 400 plus degrees when set at 350 degrees
If your problem is temperature do this;
Press "options" Then press "6". Then press "3" to increase or "6" to decrease temp.
Then press "start" to end the calibration.
If you recently used self-cleaning you could have a thermal overload fuse problem.
Feb 23, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven not working
I had the same problem. At the back of the stove is a plastic cover with thermal overload written on it.
Switch off your power.Remove the cover, pull out the two luggs and connect the two luggs straight to each other. Make sure the oven knobbs are in the off position. turn on the power. If your oven clock etc. comes on the thermal overload is faulty and needs to be replaced. It is fixed to the stove by a screw from the inside of the oven, so open the door and remove screw to remove thermal overload at the back of oven. Take sample to electrical shop and replace. DO NOT USE OVEN WITHOUT THERMAL OVERLOAD.
Dec 27, 2008 | Ovens
New world tgo 70 grill
I have a TGO 70 for sale in Doncaster
Aug 14, 2008 | New World G60m Gas Single Oven
Oven will work for about half an hour and then turns itself off.
it sounds like the thermal cut out is broken can be replaced quiet easy need to disconnect oven from mains remove outer cover and has four wires two blue two white all with spade connectors can be bought from e spares on the web
Nov 04, 2007 | AEG B4101-4 Electric Single Oven
Kuppersbusch EEB 6600.0 MX Stainless Steel Single Oven Logo
168 people viewed this question
Top Kuppersbusch Ovens Experts
ashburton
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Kuppersbusch Oven Expert? Answer questions, earn points and help others
