Solution #2
posted on Sep 13, 2009
Rank: Wiz
Expert
Rating: 84%, 145 votes
Xerox 5350, 5352, 5760
Code
Description
00-009, 030, 031, 032, 033
A door was opened while paper was being fed
00-047
Paper in duplex
00-1
Auditron
00-2
Diagnostic error
00-3
Faults error
00-4
Ric error
00-5
Job manager system error
00-6
LLM interface
00-7
Standby error
00-8
Communications error
00-9
Xerographic error
01-300
Front interlock
01-310
Right upper interlock
01-315
Left upper interlock
01-320
Left lower interlock
01-325
Fuser interlock
02-910
Key counter missing
02-920
Wrong combination of accessories
03-302, 321, 322, 326, 327
LLM to ISIL communications problems
03-328
IOT communications problem with duplex or tray 4
03-330
IOT communications problems with HCF
03-335, 336
LLM communications problems with edit
03-340
NVM memory
03-341-347
Communications problems between IOT and sorter
03-350-354
Communications problem with LLM and user interface
03-363, 364
Communications problem between LLM & optics
03-370-03-373
Communications problem between LLM & DADF
03-380, 384
03-416-422
RAM memory problem
03-424, 426
NVM memory problem
03-430, 432
Billing problem
03-439
GRAIB communications problem
03-440
RIC communications problem
03-441
RIC NVM problem
03-442
Modem
03-443-458
RIC problems
03-460
Serial communications processor problem
04-300
Main motor or drive problem
05-100-108
DADF registration sensor
05-110
DADF exit sensor
05-115, 120
DADF jams
05-305
DADF document drive
05-310, 312
DADF document sensor
05-316
DADF registration sensor jam
05-325
DADF exit sensor
05-335, 341, 345
DADF interlock switches
06-300-310
Scan problems
06-315
Scan drive
06-320A, 320B, 320C, 325
Scan problem
06-330
Lens drive
06-340
Exposure control problem
06-342
LLM CPU problem
06-344-350
Exposure cvontrol problem
06-352
IOT CPU problem
07-300, 315, 330, 345
Tray faults
07-360-370
HCF problems
07-375, 380A, 380B
Duplex problems
08-100-110
Feed problems. Lead edge of copy paper is late getting to feed sensor of tray 1
08-115-162
Feed problem. Lead edge of copy paper is late getting to registration sensor
08-165
Paper jam at registration sensor
08-310-370
Paper at a sensor when power is turned on
08-330
DADF nudger sensor
08-380
Registration side to side problem with home position
08-390
Nip
09-300
Copy cartridge finished (drum unit)
09-310
Add black toner Add color toner
09-320
Add color toner
09-330
Wrong copy cartridge (wrong drum unit)
09-340
Drum cartridge not installed properly
09-350
Waste toner full
100
A fault has occurred
10-100
Exit jam
10-105
Exit jam
10-110
Vertical sensor jam
10-120, 122, 125
Duplex jam
10-150, 155
Too much or not enough paper in duplex tray
10-300
Fuser thermistor
10-302
Low fuser temperature
10-304
Bad fuser temp
10-308
High fuser temperature or open thermistor
10-310
10-312
Fuser not up to temperature after energy save
10-314
Fuser problem
10-320
Fuser web finished
10-330, 335, 340
Exit switch, vertical sensor switch actuated when power is turned on
11-100-116
Sorter jam
11-150-176
Sorter auto stapler jam
11-310, 314, 316
Sorter interlock
11-325A,B,C,D,E,F,G
Sorter index
11-352, 354, 356
Sorter auto stapler interlocks
11-365A,B,C,D,E
Sorter auto stapler bin
11-370,371,372A,373A,373B,374
Sorter auto stapler staple failure, staple home problem or tamper home problem
11-385A,385B,390A,B,C,D,E,396A
301
Fuser web must be replaced
302
Copy cartridge (drum unit) must be replaced
501
Tray 1 must be rebuilt
502
Tray 2 must be rebuilt
503
Tray 3 must be rebuilt
504
Tray 4 must be rebuilt
505
HCF must be rebuilt
506
Bypass must be rebuilt
507
Duplex unit must be rebuilt
508
Replace black developer
509
Replace red developer
510
Replace green developer
512
Replace brown developer
513
Copy cartridge (drum unit) will need replacing soon
514
Fuser web will need replacing soon
515
DADF belt should be replaced
516
DADF feed rollers should be replaced
517
Replace exposure lamp
518
Replace suction filter
519
Replace ozone filter
520
Replace optics filter
521
Replace particle filter
522
Replace upper fuser roller
523
Replace fuser pawls
524
Replace pressure roller
525
Replace pressure roller pawls
900-905
Key operator calls
