Question about AT&T Blackberry Curve 8300 Smartphone
Blackberry curve won't turn on...
After I charged it the red light was flashing on the top. Phone won't turn on and screen will light up and show an hour glass tumbling for about 2 seconds and then go dark...please help
  • 7 more comments
  • nic_87 Jan 31, 2009
    I have the same problem, the hne comes on for a couple of seconds, shows the same symbol and then goes black. this keeps on happening every couple of seconds!!!!
  • Anonymous Feb 14, 2009
    blackberry curve won't turn on - hour glass just rotating
  • Anonymous Feb 18, 2009
    Exact same as above. I've ordered a new phone for tomorrow. This will be my third blackberry in 2 months. Great phone but i'm hearing about and experiencing to many daft problems!!!!
  • breezii hone Feb 19, 2009
    the phone will come on for a couple of seconds and the red LED light will blink, show the same symbol and
    then the screen will go blank. this keeps on happening every couple of seconds.
  • kdmaz Mar 02, 2009
    Red light flashing and screen flashing with hour glass but won't turn on
  • Anonymous Mar 05, 2009
    Mine wont even turn on it just flashes red. But it happened when I was updating the software..
  • Anonymous Mar 16, 2009
    white screen/hourglass for 10 seconds. Black with red flashing LED for 6 seconds. Consistant.
  • Anonymous Mar 25, 2009
    I have the same problem. Of coarse it happens as I am traveling.
  • Anonymous Apr 12, 2009
    my phone alternates between the flashing red light and an hourglass on the screen.
    Brigadier General:
  • 7,752 Answers
You need to try and reflash the OS
When your device fails to start, it show one of these symptoms:
1. Totally dead.
2. Trying to restart, LED activity only.
3. Failed to start, a white screen with an error message.
__________________________________________________ ________
1. Physical damage, water is the worst enemy of delicate electronic device. Try drying it with a desiccant and replacing the battery. If there is no activity, you can still try the last ditch technique, nothing to loose anyway.
2. Your device is not able to start, something has gone wrong and the OS is corrupt.
3. Geeks call this an "Uncaught exception error". That is a polite way of saying, the last thread has terminated, the OS has halted because it is corrupt.
In many cases, the Application Loader can be used from Desktop Manager or Windows.
If that fails to connect, there is one final solution. Go Old Skool ...
The good news, starting from scratch, you will be back in service in a couple of hours. blackberry curve won't turn on... - biggrin.gif
Note: Windows 7 beta is not compatible with these instructions.
1. ...
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
We are about to venture into the bowls of the beast. Windows is not suitable for this job, we are going to invoke the Command line interface with an option switch.
Windows XP: Start / Run... / Command
Posted on Feb 04, 2010
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
May 12, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Blackberry won't turn on
there is any Red Light blinking at your phone ?
if yes,you have to Flash/Upgrade Firmware your blackberry.
and How to Upgrade frimware Blackberry,you can see and Searching at YOUTUBE or you can Found in :
http://www.gsm-forum.eu/furious-gold-tutorials/1851-how-flash-blackberry-phone.html
or in :
http://srimeenakshimobiles.com/forums/blackberry/11578-blackberry-guide-how-unlock-flash-8xxx-9xxx.html
and for the Firmware you can search and Download in http://www.zylone81.indonesianforum.net/forum/
or you can search at Google.
Jan 08, 2012 | RIM BlackBerry? Curve 8330 Cellular Phone
Been on charge all night. wont turn on and has rotating black clock in centre of a blank screen
my blackberry curve went dead and when i placed it to charge for the entire night i tried to turn on the phone and it wont turn on but there is a red light on the phone for a few minutes .... what can i do?
Nov 05, 2009 | RIM BlackBerry Curve 8520 Smartphone
Blackberry Curve 8330 won't turn back on
Pull the battery out and put back in. Then hit the reset button on back panel.
Sep 05, 2009 | AT&T Blackberry Curve 8300 Smartphone
try this method
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version. This is not supplied on your BlackBerry CD, Ref: 3 links to BlackBerry's download pages.
Windows Vista: Start / Command (type this into 'start search')
Jun 15, 2009 | AT&T Blackberry Curve 8300 Smartphone
Doesn't turn on, Red LED light stays lit
Try restoring the blackberry using the blackberry firmware update utility, if the problem persists, it's a logic board issue. there are blackberry repair websites that show you how to do the replacement yourself, otherwise here is a service that can repair any Blackberry Bold, Storm, Pearl, Curve, 8800 for screen, lenses,
track balls, usb ports, waterdamage etc.
The website is: Blackberry Repair
May 31, 2009 | RIM Blackberry Curve 8300
My NEW Blackberry 8310 won't charge! Red light flashes just once.
get a message saying my USB is not sufficient enough to charge phone ???? It works on other computers just not the one I need it to work on.
May 09, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
My blackberry won't turn on.
I have a brand new blackberry put it on charge and there is no red light at all indicating its charging is that a faulty charger or phone?
Apr 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Wipe it to start over. Sometimes when you change or add something like a THEME or a download it HOSES the BB completely. So delete what was on there and don't download a theme or any other wacky add-on.
To Sanitize or Clear out all the information in a Blackberry Device
Scroll to select the OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY and press [Trackwheel] to select.
On some units you may have to select GENERAL SETTINGS before getting the next menu.
Press [Trackwheel] again to access the Menu screen for the security.
Scroll to select the WIPE HANDHELD and press [Trackwheel] to select.
Scroll UP to select CONTINUE and press [Trackwheel] to select.
Type blackberry on keyboard to confirm the action press <-| key.
System responds with ERASING INFORMATION.
Mar 19, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
App error while on a call
Might have water damage or to much charge could damage da phone n battery
Sep 29, 2017 | RIM BlackBerry Curve 8310 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
2,109 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
