Question about Sony KP-53V75 53" Rear Projection Television
No TV Reception
Is there a digital tuner in the Sony KP-53V75?
This TV is in a church basement meeting area - no cable.
It is mainly used to show DVD presentations - but want to use it for a youth group Super Bowl Party. Basement has concrete walls - 10ft ceiling with a window at the top 2ft the entire length of the room.
I was told I could get an indoor digital TV antenna if it had a digital tuner.
Went to Radio Shack - they sold me an amplified indoor antenna
Radio Shack #15-1892. Will try antenna tonight. What about the digital
tuner? Does it exist in this model? Is that the best way to get non-cable reception?
Sony Technician confirmed that that the TV has an analog tuner
2 options - outdoor antenna with digital converter --- or cable service
Posted on Jan 17, 2009
How do i see digital tv with my sony kp-53v75
If its an older set, it probably wont accept digital TV programs. You will need to get a set top box to convert the digital signal to work with your TV.
May 26, 2015 | Sony Televison & Video
Have isolated problem to vhf/uhf connection point. white lines flash in pic. w/a popping sound & if they stay for very long there is a buzzing as in over white or over modulation. problem shows when...
Problem seems with main tuner in this tv as other AV inputs working fine so please replace main tuner (TU2) to solve this issue.
There are two tuners mounted on A board TU1 and TU2, please replace TU2 and part number would be written on tuner itself.
TV is approx 10 years old so I would recommend that do not spend lots of money on it.
Thanks.
Feb 27, 2011 | Sony KP-53HS30 53" Rear Projection...
Main screen showing "no signal"
KP-43HT20 has 2 tuners, one is main (TU2) and 2nd is called sub tuner (TU1). Both tuners are mounted on A board located on right side of TV.
In my opinion, main tuner (TU2) is not working and causing No Signal message.
Let me know if you want to repair tv by yourself.to provide you more technical info.
Feb 21, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony KP-43T90 43 in TV only works with DVD but not with cable or antenna
Connect cable at RF input and please perform Auto Search in TV Menu to search available TV channels transmission and still no signal reception means Tuner is defective in TV.
Sep 04, 2008 | Sony KP-43T90 43" Rear Projection...
Screen goes black and resets during HD shows
Are you on Cable service or Direct TV. Have you tried the analog signal? HDTV ready monitor can use a standard analog signal. Most HDTV ready tv's have analog tuners built into them, meaning you can use standard cable/over the air signals on them. They will not be high definition. You can use the analog hookup by hooking it to the coaxial antenna hookup, or, if you have a cable box, it may have a set of audio/video outs (the red-white-yellow rca plugs on the back) that you can use to hook up for a slightly sharper picture.
Aug 31, 2008 | Sony KP-53HS10 TV
No signal
Good day. Try to check the tuner section. You mention that it functions good in auxilliary functions. check tuner section and system IC.
chris
Mar 28, 2008 | Sony KP-61HS30 TV
Sony KP-53XBR200
check cable grounding, does it do it with a dvd?
Feb 01, 2008 | Televison & Video
Black screen
my sony kp-61hs30 displays that there is no siginal, also the red indicator light blinks when the power is turned on but goes out i have dirct cable pluged into the set and up until about a week ago it worked fine.All of the other tv's in my home work fine so i don't understand what the problem is . I have a dvd player connected to the set and it works great for viewing dvd's please assist with me with some trouble shooting points
Jan 24, 2008 | Sony KP-61HS30 TV
Sony KP-53V75 53" Rear Projection Television Logo
196 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
