Question about Amana NAV5800A Top Load Washer
Washer (Amana NAV 5800) vibrates vigorously on high spin cycle. I have tried the following: Adjusted the load, did the self leveling, and put my own level on machine. Everything checked out okay. Another person recommened increasing the front legs by the width on my middle finger. I did this and tilted the washer forward to adjust the self leveling mechanism in the back of washer but it failed to engage. Please explain why it failed.
  • thomaslc23 Jan 30, 2009
    Called authorized Amana repairman said he could fix the problem for $180.00 but it would still vibrate somewhat and problem could return. Amama washer 5800 is low grade contractor type washer. I replaced both washer and dryer. Never again with Amana.
We purchased an Amana NAV5800AWW top-loading washing Machine which ran fine for about 19 months, then it began to vibrate violently when it went into a high-speed spin. I went thru the "leveling" procedure, although it didn't need it; and when that didn't help called the appliance repair man.
The repair man tightened screws, checked that my floors were solid, and then checked the tub itself. He found that the inner (stainless steel) tub was loose, and upon closer inspection found that the stainless steel tub was severely "cracked" around around each of it's 4 mounting bolts. This was allowing the tub to move around, thereby creating an out-of-balance condition.
He indicated that the "fix" would be to replace the tub, which was still under warranty; but I would have to pay the labor for installation ($90 + tax). He suggested I might call customer service and see if they would pay the labor.
I called Whirlpool's customer service dept (Whirlpool bought out what used to be Amana). I spoke to the customer service agent and after explaining the problem suggested that since the problem was clearly either a manufacturing defect or an engineering design flaw, that the customer shouldn't have to pay anything. He (although courteous) said that the warrantly clearly stated that only the part (and not the labor) was covered, and that Whirlpool would not pay for the labor charges.
That's when I pointed out that it didn't project a very good image of a company (Whirlpool) when it would not bear the cost of fixing a problem clearly not of the customer's making. Moreover, I assured him that I would never purchase a Whirlpool product again; and that I would make certain that my experience found it's way onto the internet.
Posted on Jan 30, 2009
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
Washer in high spin cycle "walks" slightly away from the wall although when I put a level on it it appears to be level. The floor vibrates when it is in this high spin cycle. Feet are not raised very much...
make sure all the pegs are touching the ground. You may have the vibration dampner going out or the weight on the wheel is loose. You can find all that by unscrewing the back of the machine
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 06, 2009 | Washing Machines
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Front Load Frigidare washer bouncing on spin, very bad!!!
Hi, not sure if you have solve this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
Jun 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Hi, not sure if you have resolved this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Major shaking during spin cycle
I have the exact same washing machine with the same problem. It is a poor design and Maytag knows it. We should be entitled to a refund. This was a very expensive machine.
Apr 13, 2009 | Maytag Neptune MAH6700A Front Load Washer
Washer moves during the spin cycle
Due to strong vibration during spinning definitely the machine will stop. All you have to do is to check your load if equally distributed from the tub. To eliminate the vibration and the movement of your washer you need to align the four legs of your washer using level tools. Just put the level on the top of the four sides (front side, left side, right side and backside) then make necessary adjustment if needed on the 4 leg of the washer. Also check the water level of the balancer and the mounting position from the top of the tub.
Jan 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer vibrates vigously on high spin cycle.
I don't know what kind of washer you have (make, front loader, top loader, etc) but it sounds like your basket is definately out of balance. I have replaced bearings on a front loader Frigidare, but I have heard of some of them having broken arms on the inner basket. Something like that would definately cause a condition like you describe. Bearings usually give plenty of warning due to noisy operation.
My washer has no "transmission" , just a motor and drive pulley and a belt.
What kind of washer is it? Also, I know you said the washer was level, but are all four feet solid on the ground? Sometimes a washer can be level, but still rock on its feet if one of the feet is short.
Jan 15, 2009 | Amana NAV5800A Top Load Washer
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Amana NAV5800A Top Load Washer Logo
602 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
