Question about HP Scanjet 3300c Flatbed Scanner
Make it work with Vista
No drivers from HP yet. Any other known way to make it work, even partially (simply scan a doc). Regards, Lupomich
  • Anonymous Mar 11, 2008
    how can i use this scaner with vista
  • cherysejonas Aug 15, 2008
    need hp 3300c driners 4 vista
I solved the problem of getting the HP ScanJet 3300-series scanners working on Win 7 beta, so it should also work on Vista. Because of the obsolescence of this software & hardware, I will not support the following. You’re on your own.
First of all, Windows XP and later have a service called Windows Image Acquisition (WIA). Because this scanner was developed before XP, it has no WIA support — and in fact, the HP PrecisionScan LT software that is provided with the unit conflicts with WIA. So, the procedure to install it is as follows:
1. If plugged in, unplug the USB cable at the back of the scanner. Uninstall any software you may have tried to get it to work. Start System Restore (Control Panel | System "System Protection" — requires Administrator privileges) and Create (bottom button in the dialog) a custom restore point named "Installed HP PrecisionScan LT," so you can easily undo any aftereffects of the following, if necessary.
a. If the scanner is present in Computer | Properties | Device Manager’s "Imaging Devices", right-click and delete it. You may need Administrator privileges to do this — see Windows’ Help.
b. You may have to edit the Windows Registry to delete the scanner manually from the HKLM | SYSTEM | Current Control Set | Enum | USB key, but this is highly technical and takes advanced privileges and techniques beyond most users. The 3330c’s usual key name here is VID_03F0&PID_0205.
2. Install PrecisionScan LT. This is usually accessed from the folder SJ650 created by executing the downloaded file SJ650.exe, and running its program Setup.exe — or the one off the HP scanner-setup CD for Win2K.
a. BUT YOU MUST RUN IT IN WINDOWS 2000 COMPATIBILITY MODE. To do this, right-click Setup.exe and pull up its Properties dialog, and click the Compatibility tab. In the Compatibility Mode group box, click "Run this program in compatibility mode for:" box to check it: The selection drop-down field will become enabled. Click the down-arrow icon at the end of the field and select Windows 2000. Then click the OK button. Windows will add PrecisionScan LT’s Setup.exe to Windows’ compatibility database to be run in a synthetic Win2K environment.
b. Now, just to be sure, when you run Setup.exe, also right click it and select "Run as Administrator." This is to ensure that it and all processes it spawns will have rights to do the system stuff they will do. Make sure that no non-essential programs are running. In fact, temporarily disable your network connection, and then temporarily kill your antivirus/antispam and firewall, to preclude their blocking your installation — although running as Administrator will minimize this problem.
3. After the process completes, Setup will spawn a dialog that tells you to OK any messages you may get about the driver being non-certified, etc. Accept it. DO NOT plug the USB cable into the scanner yet. Reboot your machine and OS first.
4. When you’ve rebooted and all the dust has settled, you have to disable Windows’ native WIA service, or PrecisionScan LT will hang. This procedure will recquire Administrator privileges.
** NB: This has the side effect that standard Acquire operations from some programs won’t work (because they rely on the WIA service you disable here). You have to explicitly scan from PrecisionScan LT, and send the scan to the destination from its Send menu. Afterward, test your programs to see whether Acquire works or not. It does in Corel WP Office X4, for me.
a. Right-click Computer, and select Manage. The Computer Management tool will pop up after a few seconds. Select its Services and Applications snap-in at the bottom of the left pane, and then click the Services item in the right pane. A screen showing the services running on your machine will appear.
b. Click in this pane to give it focus, and then hit W to index to that region of the list. You will see Windows Image Acquisition a ways down. Right-click it and select Properties. First hit the Stop button to kill the service; then, in the "Startup type" drop-down box, select "Disabled," and click the Apply button.
c. Exit Computer Management by hitting dialogs’ top-right-corner X boxes until you’re out.
5. Now, reboot again. When OS-start dust has settled, clear any dialogs that may pop up, and plug in the USB cable to the scanner. You should now be able to run PrecisionScan LT to scan, and send output to destinations available on its drop-down.
6. There is yet another update from HP, SJ700, that might be necessary to enable destinations such as Word and MS Office, and you might have to run that as Administrator, too.
7. If the preceding doesn’t work for you, you’re on your own. This hardware and software is obsolete and no longer supported by HP or MS. To undo what you did above, run All Programs | HP PrecisionScan LT Software | HP ScanJet Uninstall (this pre-XP HP install does NOT create an uninstall entry in Programs and Features), then run System Restore and select the point you created in step 1. You may have to manually re-enable the WIA service, but shouldn't have to.
8. If you HAVE to have WIA for something on a one-time basis, just re-enable it, reboot, do what you have to do with it, and disable it & reboot again to use PrecisionScan LT.
9. On some systems PrecisionScan LT will randomly go incommunicado & have to be uninstalled & reinstalled. Sorry. Try creating a restore point when it IS working, and then revert to that to see if you can avoid having to go through the whole rigmarole.
Posted on Jan 22, 2009
  • 196 Answers
This is from the HP site, and seems pretty definitive: "We are sorry to inform you that there will be no Windows Vista support available for your HP product. Therefore your product will not work with Windows Vista. The majority of HP products not supported in Windows Vista are beyond seven years old. If you are using the Windows Vista operating system on your computer, please consider upgrading to a newer HP product that is supported on Windows Vista. HP has numerous products on the market that support Windows Vista".
Posted on Jun 20, 2007
    Problem Solver:
  • 17 Answers
Eventually if your lucky, the drivers might just work if u look on windows update the optional updates the driver update might be there, just the waiting game, its a long shot but u neva no
Posted on Aug 23, 2007
    Genius:
  • 2,985 Answers
OH yes Vista- There are issues with Vista like no one is making driver drivers - Peripheral makers reckon its Microsoft's Job and MS reckon the other way Try the Standard XP setup that came with your scanner then try to roll back But I suspect your are out of luck HPwebsite technical Support team may have an idea or two. That is E-mail them
Posted on Jun 19, 2007
Working under Vista, SP2, but can't find driver for HP Scanjet 4470c. Should be A answer to the problem ??????
the only drivers for this are availalbe here - no vista drivers listed!
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&tool=&product=57956&
Apr 11, 2011 | HP Scanjet 4470c Flatbed Scanner
Need 2 things: A way to scan a document into Word with a HP PCS-2355 and a Vista OS and, a cheap way to convert a doc. to a .pdf file. Thank you
Get an old PC, install Ubuntu Linux with Open Office.org, export as PDF.
This may even work under Windows with Open Office.org.
Sep 27, 2010 | HP PSC 2355 All-In-One InkJet Printer
Whenever I connect my HP Photosmart C3183 to my laptop HP Pavillion tx2000 with Vista Service pack 2 ,the system cannot scan and it crashes with blue screen.
that simply shows that the drivers u are installing might not be able to work with vista, try download a good driver from a better source for your OS
Oct 19, 2009 | HP Photosmart C3180 All-In-One InkJet...
I am having prob with ma HP laser Jet 3055
firstly restart the printer and put the blue wire into the red pocket vice versa it should work
Aug 13, 2009 | HP Office Equipment & Supplies
I have a problem installing hp officejet 4200 all in one series
hey there,
pretty sure the software you have was for xp, and you'll need to download newer drivers from HP that work with vista. MANY products need newer drivers to work on vista-- youre not alone.
generically, try this. the download is big, but newer
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47767-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=351106
there are several sets of drivers that install when you do this (all part of the one printer driver). the drivers that print are different drivers from the ones that scan. what's happening is that it sounds like your driver is only partially installed, probably due to some incompatibility between the driver version and vista. you could also try windows update through vista, and it will check to see updated drivers for your specific printer....
Jan 31, 2009 | Office Equipment & Supplies
HP PSC 1510 Vista issues
what happens whenever you are trying to scan.... any error message or any error number?
try scanning from the printer to the computer using the scan to option on the front panel of the printer.
try scanning from hp solution center installed in your computer.
try scanning from mspaint. to do so, open paint and click on "file-->from scanners and camera".
how did you installed the driver. have you got the correct cd to install the printer in windows vista???
if not that may be the problem. the printer can print and copy well as you are having the drivers which will work in win vista. but for the scanning functionality you need to get the cd to install the printer in windows vista. you can download it online.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47767-1&lc=en&cc=us&dlc=en&product=428800&os=2093&lang=en
the above link will help yu to download the win vista software and drivers for this particular printer.
Thanks and regards
Agnel
Mar 10, 2008 | HP PSC 1510 All-In-One InkJet Printer
Can not install hp psc 1317 printer
You can't install the printer cuz the driver of it wont work on any versions of vista it can only run on windows xp.
I have even checked if there is any driver available for download on vista but unfortunately it isn't..
Goodluck,
dont forget to rate me as fixyaa..
Jan 03, 2008 | Microsoft Windows Vista Ultimate Edition
HP Deskjet F380 All-in-One Compatible with vista
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
Nov 21, 2007 | HP DeskJet F380 All-In-One Printer
HP Scanjet 3300c Flatbed Scanner Logo
1,381 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
