Network Key (WEP, WPA, WPA2 Encryption key) To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: ipod wi fi conection
Wi-Fi Functionality
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon () in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
Choose Settings > Wi-Fi and turn Wi-Fi on or off.
When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon ().
If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
Choose Wi-Fi, then tap the arrow () next to a network.
SOURCE: my ipod shows that i
1.check to see if you are using the correct network password Key.
2. make sure you are either WPA or WEP network security.
3. Check to make sure your phone can access the Wireless G network if not check Manufacturers troubleshooting to see how to correct this.
4. here are the instructions in PDF format for your router.
save to hard drive
SOURCE: I forgot my user name
Hi well this isn't too much of a problem. What you need to do is simply reset the router, then simply log in via a browser and then set the WAP/WEP security codes again,or simply read the existing data?
broadband.motorola.com/noflash/customer_docs/user.../506705-001.pdf
broadband.motorola.com/noflash/customer.../507755-001.pdf -
www.retrevo.com > ... > Motorola Wireless Router Manuals -
Hi above are the links for your manuals.
There should/may be a small hole at the rear of the unit, (If NO hole etc, please see manual for how to factory reset) press the button in the hole for a few seconds this will reset the router back to Default settings, just as if it came straight from the factory. Then you can log in via a browser by typing in the address, like, 192.168.1.245... or whatever YOUR one is, it will be in the manual, then use the Default logon and password, then you can do whatever you want, once you are "In" the router.
This time copy/paste the data to a notepad document and save it for use later.
SOURCE: cant conect to wi-fi with phone using the password
Make sure you choose the right protection.
WPA
WPA Personal
WEP
etc.
etc.
SOURCE: i press the reset buton
(Copy and paste to browser)
b>
Please, we need to know how we are doing! Please rateour help to you and leave us a comment so we could go on helping people likeyou that need our assistance and expertise!
Thankyou for using FIXYA!
Bestregards,
Junior
