Question about Canon Rebel XT / EOS 350D Digital Camera
Flash delay When I take a photo the flash will go off about 4-5 seconds after the picture has been taken. I recharged the battery and reset the camera to all of its orignal settings. Please help. pictures were great about a week ago and now they are dark and fuzzy.
  • 36 Answers
Your camera is set to 2nd curtain sync. You will have to go into your cameras custom functions, and disable it.
Hope this helps,
/Chris
Posted on Jan 19, 2009
On the easyshare m575 what does the self timer/burst feature do?
Self-timer
(10-second delay) it will have a 10 on it
Time to get yourself into the picture. Place camera on a tripod or flat surface.
Self-timer
(2-second delay) it will have a 2 on it
Allows for a steady, auto-shutter release on a tripod.
Self-timer
(2 pictures) it has a 2X on it
Capture 2 shots (one picture taken after 10 seconds and another picture taken 8 seconds later).
First Burst
Flash forced off.it has like 2 folders in front of the camera
Camera takes up to 8 pictures (2 per second) while the Shutter button is held. The first 8 are saved. (Capture an expected event e.g., baseball swing)
Last Burst
Flash forced off. it has 2 folders behind the camera
Camera takes up to 30 pictures (2 per second up to 15 seconds) while the Shutter button is held. When the shutter button is released, only the last 8 pictures are saved. (Capture an event when the precise timing is uncertain e.g., a child blowing out birthday candles.)
Mar 03, 2011 | Kodak Cameras
When using the flash is takes 4/5 seconds before I can take another picture. The taken photo appears for about 1 second then the screen goes black for 4/5 seconds before I can take another picture
Friend,
You are using a 10 MP camera. Imagine the size of the picture taken. It is massive. And so would the size in megabytes. To save those many MBs is a time consuming affair. that is what takes 4 to 5 seconds. And during that time the camera can do nothing else.
Do not worry. The camera is fine. Just that you have a very good camera and do not realize it.
As regards the photo being visible for a second only, you can change the settings and have the picture on display for a longer duration. That would be fine as while you are viewing the pic, the camera is busy saving the pic file. You would not feel those 4 to 5 seconds at all.
Dec 28, 2010 | Canon Powershot A2000 IS Digital Camera
Camera will not take pictures when the flash is on
You may have a weak battery. If the flash doesn't have enough power, it will continue to try to recharge thus preventing you from taking a picture. Turning it off allows the pic to be taken.
Feb 17, 2010 | Olympus Stylus 710 Digital Camera
Digital rebel XS - flash delay
Your camera is set to syncronize the flash on the second shutter curtain. Check your custom functions/custom settings, and disable it. It's called "second curtain sync" or "2nd curtain sync". Nikon call it "Rear Sync".
Hope this helps,
/Chris
Jan 16, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Delayed shutter
Here as in some other posts, you can try to RESET the firmware in the menus. Go through the menus and find where it says something like reset all.
What this does is to reset it back to factory settings.
Then set the options you like, and then try the camera again.
Check the diff. modes for the picture taking. See if the flash can be turned off.
Aug 07, 2008 | Samsung Digimax D53 Digital Camera
Power key doesn´t work
There must be a problem with your batteries. If you have recently charged your batteries and it happens again, you should try a new set of rechargeable batteries.
You can try conserving charging power usage on camera by turning the flash off so that it doesn't precharge for the next shot.
Jun 04, 2008 | Samsung Digimax i6 PMP Digital Camera
Recharge of flash
Sony H1 camera has a delay to recharge the flash and I hope that you know that as you are using it for the last three years. If the time delay is a new issue check the MAH of the battery to ensure that it will be above 2200 at least. If the MAH is below 2200 it is natural that the time delay will be more to recharge the flash. If my solution proves good please rate it. Regards.
Mar 06, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Flash won't fire
charging flash:-
POSSIBLE CAUSE:The camera is recharging the flash.
SOLUTION:It takes longer to charge the flash when the battery is low. If this message appears a lot, replace or recharge the battery.
Dec 28, 2007 | HP Photosmart R607 Digital Camera
Polaroid a520 doulble flash
The first flash is to lessen red eye in picture when 2nd flash goes off.
Nov 22, 2007 | Polaroid PhotoMax PDC 4055 Digital Camera
It wont take a photo on regular flash
Sounds like your batteries are stuffed, or not of sufficent ma capacity, should be alkline or rechargeable of at least 2500ma
Sep 20, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
