Question about Whirlpool WFW8300SW
WFW8300SW (Whirlpool) It started with an F21 error cleaned out the pump and now I get an F28 error and the drum is moving slowly
  • 8 more comments
  • Ghost1341 Jan 16, 2009
    I have unplugged checked all connections, The drum starts to turn in dianostic mode but after a couple of spins it goes to flashing F28, and as I said this only started after I cleared the F21 code
    I think this is futile the machine spins it rotates it spins in different amounts of time. One it will rotate for 2 minutes the next for 5 minutes, the time after that maybe a minute what a piece of junk.
    Again AS I SAID the drum rotates
    This is a front load Machine not a top load
    Could this problem have been caused by tipping the machine forward to access the pump from the back???????
    I have also tried that and even left it unplugged all day while I was at work still comes up with F28 at varying time intervals
    Is there a fuse or breaker inside the machine?
    I do not have the owners manual how do you re program the ccu
    Is there a way to re-program the CCU? Someone posted that this could be done but I do not have the manual.
  • Ghost1341 Jan 17, 2009
    I had the whole pump assy out and cleaned it and reinstalled.
  • Whirlpool Master
  • 19,396 Answers
There is no way to reprogram CCU in an easy way, you need image that is not available, and an eprom programmer.
Just replace ccu if it is faulty.
find parts and diagrams by entering model number here.
Posted on Jan 23, 2009
    Top Expert:
  • Whirlpool Master
  • 77,202 Answers
U will need to replace the central control unit.
Posted on Jan 17, 2009
  • 818 Answers
I took off the front panel of the machine and opened the drain pipe. There was a sock clogging the pipe. I removed it, cleaned everything, and then put it back together.
Posted on Jan 16, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Error F21 means long drain time. When you checked the discharge stream during pumpout, was it the same diameter as the hose and forceful?
Also, pull out the pump cleanout and look in at the impeller. It should be clear or debris, with nothing wound around it. Should have four impeller vanes. These can get broken off by coins.
Finally, remove the discharge hose from the pump, pucker up and blow. If, after clearing the initial slug of water, the hose doesn't blow free and clear, then you have something in there.
  • Rylee Smith
    Rylee Smith Jan 16, 2009
    You need to tip the washer back a little and remove the three screws on the front bottom cover. There would be a large white drain value, turn and open the drain (make sure you have a pan or something to catch the water and any junk inside) to remove the water. Attached to the drain would be a black hose with an expanded section, squeeze this to find any loose socks, under clothes etc. This error is a drainage problem, it is easy to fix yourself. I hope this helps!
    Ask for any clarifications
  • Rylee Smith
    When you take the bottom front cover off, there is a SERVICE MANUAL in a bag attached to the backside of the bottom cover which explains what all of the error codes mean.
    Thanks
    Rylee
  • 66 Answers
CCU Has to be reprogramed if you have the book that came with it in there how to do it. Mine lost program one time.
    Sergeant:
    Novelist:
  • 326 Answers
Yes its quite possible.what you r thinking of.Check to see whether power or exact voltage is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?if its getting power but the low voltage then this proble can be possible.needs to be checked with a voltmeter.to locate the loose connection on the board of the machine.
    President:
  • 1,214 Answers
I'll suggest this as I didn't see it when scanning quickly above, but, unplug the complete unit for awhile, if 5 minutes doesn't work, try 30, then maybe an hour. If it doesn't reset after that, make sure you did not break any wiring connectors or connections when you cleaned the filters/pump (assuming you had to break into the unit from the back.).
  • Mark Egan Jan 16, 2009
    For a Operation Manual, go to www.managemyhome.com . You will need to register, but it's free.
    Only thing is, it will probably only tell you how to use the washer, not service or reprogram it. I am trying to download now just to check.
    I am going to be real suspect that there is a broken connector, or a bad door switch in the unit as someone else had suspected.
    From the manual -
    "Rinse," "Cycle Complete" and "Add a Garment"
    illuminated or "F21" on display (Drain Problem)
    Select PAUSE/CANCEL twice to cancel the cycle. Unplug
    washer or disconnect power.
    Check the following:
    Is the drain hose kinked?
    Is the drain hose frozen?
    Is the drain hose clogged?
    Is the drain hose more than 96" (2.4 m) above the floor?
    Any other Status light combination (Electrical Problem)
    Select PAUSE/CANCEL twice to cancel the cycle. Select
    DRAIN/SPIN if there is excessive water in the washer.
    Re-select cycle and press START. If the problem remains, call
    for service.
    I am going to suggest the Pause/Cancel twice routine, as well as the Drain/Spin routine if there is water in the tub. You've got to get it empty of water before the controller will reset (if there is water in it.).
    Otherwise, and Pause/Cancel reset might just reset the controller, period.
    Sergeant:
  • 378 Answers
Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
Door not locking - if the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the consol.
Broken wires at one of the out off balance switches or a bad switch itself.
A fairly common trouble maker has been a burnt diode on the main control board. See diode R11.
If this has happened to your main control board ( in the consol ) , the wax motor in the door lock assembly is drawing too much hydro and must be replacing at the same time as the control board. The wax motor can check, appear and test ok but will fail when working throughout the cycle.
 Appliance Repair Aid does not recommend repairing this board, replacing the board along with the wax motor or the entire door lock assembly is the best way to ensure a proper repair. Some info on the burnt part(s) of the board is linked here if you decide to try to service the board itself.
    Sergeant:
    Scholar:
  • 199 Answers
  1. Lid open.
  2. Lid switch defective. ( Very Common problem )
  3. Lid switch disconnect plug open/burnt.
  4. Clothes between basket and outer tank.
  5. Lint filter caught between the wash basket and outer holding tank.
  6. Wiring harness.
  7. Bad motor capacitor ( How to check )
  8. Weak clutch.
  9. Timer switches. ( possible not allowing the pause required for the transmission to set up to spin )
  10. Motor.
  11. Cam driver on basket drive broken or basket drive weak.
  12. Spin tube.
  13. Notches in drive block worn out and not engaging basket drive shaft.
  14. Broken motor coupling. See Replacing Motor Coupler Page
  15. Read a bit on how the washer works as well.
  • mrrightt Jan 16, 2009
    It doesn't pump or spin
    It pumps, but doesn't spin
    It spins only with the lid closed
    If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
    • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
    • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    If your washer pumps out the water but doesn't spin, check these:
    • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
    • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
    • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
    • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
    Genius:
  • 1,199 Answers
The belt that drives the barrel is broken or off track replace drive belt in unit!
    President:
  • 2,110 Answers
You can call whirlpool for service but the tech sheet f28 has a communication problem from you computer to the motor..
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
Check connections of the CCU board within the housing.
Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
    Sergeant:
  • 221 Answers
F28 error is means its :--------
Possible for its causes and the solutions to resolve the problem
– Check connections of the CCU board within the housing.
– Make sure all grounding switches are engaged.
cycle.
the MCU connectors
If it is new call for service
and for F-21 ERROR   remove the front panel, draine the water, clean out the filter, replace everything and run a test load,if  it still fails  to drain.  take everything apart again and check the pump motor (just to the right of the filter, it twists off). The motor had a small sock tangled in it. remove that clear it.and the error will get cleared. thanks.
  • nadakund Jan 16, 2009
    F28 error indicates that the communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.check and replace the faulty component
  • 679 Answers
Unplug the unit for an half hour and plug it back.
  • 2 more comments
  • rockfixya
    rockfixya Jan 16, 2009
    F 28. That would be a SERIAL COMMUNICATION ERROR
    see at the link>>
    http://www1.epinions.com/review/Whirlpoo...
  • rockfixya
    did you check the provided link.
    Thanks
  • rockfixya
    check tham using a multimeter (if you know how to use a multimeter).Thanks
  • rockfixya
    rockfixya Jan 20, 2009
    please let me know if problem solved.
    Thanks for using FixYa.
I have a whirlpool duet sport that is displaying F28 code. I have replaced the ccu unit now what do I do. It fills but will not wash, drains but will not spin HELP PLEASE!
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is the CCU to order.
Here is the MCU to order.
Nov 03, 2012 | Whirlpool WFW8300SW
Whirlpool f28 error code and door lock light
Here is a link to the CCU.
Here is a link to the MCU.
Oct 13, 2012 | Whirlpool WFW8300SW
F21 error
This is a Long Drain Issue. Likely that something is stuck in the pump trap. Take off the mottom tree screws under the drum panel. This will remove the drum panel on the front. From under neither you can see the drain pipe trap. Unscrew the trap cap in the from. Clean out all debrieF and re-install. This should do it.
Jul 22, 2012 | Whirlpool WFW9400S
Whirlpool Duet wfw9250ww will not drain F9E1 code is displayed. How do I toubleshoot this?
F9E1 or F21
  • When users observe the F9E1 or F21 error code in their Whirlpool washer's display, it indicates a drain pump system error. The drain hose should be checked to ensure that it has been installed properly and not having a blockage.
Read more: Code List for Whirlpool Washers ' eHow.com http://www.ehow.com/list_7735284_code-list-whirlpool-washers.html#ixzz1wPUs4Ry6
May 31, 2012 | Washing Machines
I have a whirlpool washer & dryer Duet and my washer keeps getting an error code F21 and recently got F28. I had some work done in the laundry area which caused the washer to be moved and then put...
https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:AjaxMiniWishListView
Above find a link to your Manual and below find a link to a Video which can assist you in fixing the F21 Error Code
The F28 Error Code could Just be a Fluke But it is supposed to mean that there is no water entering so to be sure before running another load be sure hoses are connected and turned on.
Thumbs up if Helpful and Feedback is Appreciated!!!
Jun 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Starts cycle with add a garment light on. after few min f-21 code on with all lights flashs .cleaned drain pump filter. wirlpool duet sport model #wfw8300swd
Whirlpool F21 (and 16, 18, 20 and 22) states 'control unit failure'. Could be poor connections but requires a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 16, 2011 | Whirlpool WFW8300SW
My washer stopped and was flashing F21 (drainage issue) so I called a plumber. He checked the hoses and removed the panel and cleaned the drain trap. It didn't fix the problem it's still won't drain. It...
The SUD message relates to overdose of detergent detected during the Wash Cycle.
This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked. this seems to be the reason as to why your unit is not fixed even after trying to solve F21......
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
Good luck
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
Start the wash cycle, water starts to run in,F21 displays and a humming noise begins and the door will not open no matter what effort you make to try and open. Reset cycle to rinse and water will not go...
f21 is no drain error code,you have to take off the bottom panel,you'll need a shop vac or something to catch water,put some towels down under the pump,the middle of the pump unscrews so you can clean it out,turn the center part counterclockwise slowly,when the water starts leaking out vac it up as it leaks out,doesn't take long to drain it,when it's drained remove the center piece and you'll find some lovely things in the catch,feel around inside the pump to make sure you get everything out and nothing is hitting the impeller or stuck on it,if it doesn't drain after that and the pump just humms you'll need a new pump,good luck,if i can help you with anything else let me know
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW8300SW Logo
Dan Webster
Dan Webster
Sal De GO PATS
