Question about Toshiba 50HX81 50" Rear Projection Television
No pic or sound with power on my Toshiba 50HX70 Tv
The tv will turn on but no sound or picture! does this tv use 2 or 3 prong plugs?
  • Toshiba Master
  • 5,568 Answers
The plug configuration shouldn't make a difference; the third (round) pin is only an earth/safety ground. The two primary plugs supply the AC. You probably have a failed power supply which may be a separate board. Check to see if this is the case, look for a part number and see if you get any hits on it on search.
Posted on Jan 27, 2009
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
I have a Toshiba 50HX70... I fixed the convergence issue around 6 months ago. Now the sound does not work... I turn it all the way up and you barely hear anything... I did move it recently, did I know...
Best best would be to try the following:
Start with taking the back cover off of the tv.
1) Verify if you can hear any sound whatsoever out of the speakers. If so, that would indicate that the speakers are still connected to the circuit board. If not, then trace the wires from the speakers to where they plug on to the board.
2) if you hear sound (hiss) in the speakers, but not the audio signal from your program you are watching, then look to ensure all connecters are fully seated around the RCA jacks in the back.
If those two do no produce results, then could be a solder joint on the board finally failed after moving the tv, or the amplifier for the speakers has failed. If you hear sound though as in step 1 above, i would doubt it is the amplifier IC.
Feb 20, 2011 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50hx70 sound but no picture
NORMALY SOUND BUT NO PICTURE IS THE LAMP YOU SHOULD CHECK THAT TO SEE IF ITS BLOWN
Mar 07, 2009 | Toshiba 50HX70 50" Rear Projection...
Toshiba projection tv
check for solder bridging between the IC pins. also make sure the wire connections are back in the proper locations
Feb 14, 2008 | Toshiba 50HX70 50" Rear Projection...
Picture & Color Distorted
Convergance IC replace.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50HX70 - red blinks but TV will not turn on...
Hi, you`ll need to call the tv guy then, you have a short in one of the power supplies, or possibly broken solder connections, either way the board has to come out and board repaired or parts changed, BMW Rider
Dec 02, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 62hm14 TV turns on with no picture but has sound then green light blinks and it shuts off
This isn't gonna help you, but I have the same problem on my 62HM15A, think we have about the same tv, widescreen DLP,?
My TV does the same thing powers with a blining lite then powers off. First it powered on with sound no pic, then would shut down and power up again with pic and sound , now i gots a nothing just powering on and off until i shut the thing off manually.
thanks, just posted here in case some answers bipea's question and it relates to mine.
Jul 23, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
TV picture shaking!!!
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Tv repair
This happened to mine. It was a fuse that cost $3.42 but the service call was $200! If I knew how to do the freaking work I'd be rich!
Apr 09, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50HX81 50" Rear Projection Television Logo
140 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
