Question about Whirlpool LER5636P Electric Dryer
My electric dryer will turn on but once it get hot after 3 minute
It cutt off automatically.
  • Bill Dickerson
    Bill Dickerson May 11, 2010
    Can you restate what it is. The problem is not clear. It sounds like it cuts off. There may be a problem with the thermal fuse. You may want to look at it first. Does your breaker trip when it gets hot?
  • 1,214 Answers
What cuts off automatically? Stops heating , or the drum stops turning?
Please reply your findings and we can help you further.
Posted on Jan 19, 2009
Why does my fryer cutt off in 10 minutes
Could be overheating. It just may need a good cleaning. and make sure the dryer vent is clear with no obstructions. You may need to take some panels off. Also may be the gas valve solenoid.
Jul 21, 2014 | Maytag MEDC200XW 7.0 cu. ft. Centennial...
I have a kenmore dry that seems to hum very load once it heats up. If you turn it off and rest for 30 minutes it will sound fine again until it is 15 minutes into the cycle. What would be the likely...
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
Sep 12, 2011 | Kenmore 84072 Electric Dryer
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Dryer Miele T9800- 3 years old Lately the air doesn't get hot, it will be warm and it will take over 90 minutes to dry clothes that before were done in 15 minutes.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
Sep 13, 2010 | Miele T9800 Electric Dryer
Dryer works but does not get hot
Number 5. Check for blockages or you will keep buying em. You gotta remove that filter chutefa531d8.jpgto get it clean, more HERE5a0f26c.jpgf0e50c2.jpg
May 25, 2010 | Roper RES7646KQ Electric Dryer
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
Shutting off every 20 minutes
Your thremal fuse is getting hot. OR There are overloads attached to the element housing and one of them is getting hot and automatically resetting itself once it is cooled.
Apr 17, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
Electric dryer shutting off
most likely cause is the air duct is blocked with lint, some always gets past the screen and builts up in the exhaoust line. not enough air flow, the air gets hotter than normal and trips the over temperature cutout.
for most dryers
clear the fan, and exhaust ducting all the way to the wall, and the outside vent hood, of lint
Sep 22, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
