Install color wheel in samsung hlp tv model #hlp4663w
What do i need to do it   do the plugs just pull out?
    Champion:
  • 453 Answers
Yes u need to take the optical block out is hold by screw umplug the hdvi cable and 2 small cable caming from the anolog board , now take the top black cover wicht is protecting the color wheel now remove the only 2 screw for the color wheel , becare full when remove the 2 smaller cable for the color wheel and when put it in the color wheel back in place
Posted on Jan 17, 2009
After replacing the color wheel the picture is mostly blue and sometimes the TV goes to green. Trying to understand jumper cable that may need to be removed, I have the HLP 5663WA. Any help would be...
yes u need to remove this jumper , if u look ur tv from the back the jumper is on the board that is attach to the optical block it is cover by a shield plate if look closer there is a small hole u may need a fine plier to take this jumper out
Apr 13, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My Samsung HLP 4663wx makes a loud humming noise. what can I do to repair this?
it is probably the color wheel going out. this is something a technician should do. can call 1-800-samsung or go to samsung.com for nearest service center.
Dec 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Replaced my Samsung HLP4663W color wheel and the
The jumper if it has it usually causes the color to look funny blue instead of normal.
It is located on the DMD board--the metal box on the light engine where the two plugs from the color wheel are.
It will be in a small opening on the metal shield that covers it--small and rectangular in shape--it has a small metal tab across it--it jumps two pins--
if it is there with a hemostat or small needle nose pliers pull it carefully out and see what you have--The CCA adjustments are done in the TECH MENU--look to see first if the jumper is there and remove it.
A lot of places that sell the wheel do not tell people about this.
If this has helped you rate this solution, as I do this here for FREE.
sd tech
Nov 11, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HLP-4663WX/XAA. Colors green after wheel replacement.
I have Samsung DLP HLP-5063WX/XAA. I have the same problem. I did change another color wheel, but not any help. Please help! I appreciate
Sep 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Installing a color wheel
These are set at the factory so no adjustments should be required. The part will come with the installation instructions.
Dan
Mar 22, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Jan 22, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W color wheel replacement
yes its true grt your self a pair of needel nose pliers and pull that jumper.
I had a tv set in my shop for weeks till i lerend that one
wat it was is that the new color weel motors are air cor and spin faster that the originals, so pull the black jumper it looks like a small hard drive just remove it
your set will auto ajust.
ther are sum small settings to add in the service menue to fine tune it.
but first pull that jumper..
seting can be found on google... i think i found it on tech assist.
and enterd model number.
Jan 12, 2009 | Samsung DLP HL-P5663W 56" TV
HLP 4663WX/XAA
sounds like the color wheel has gone out
Dec 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
My DLP TV wont turn on.
As part of the power up sequence on the Samsung HLP-4336W the lamp isn't turned until timing pulses are detected from the color wheel. The color wheel motor is powered through the flat brown four conductor ribbon cable and the timing pulses are detected over the the three conductor ribbon table.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
When I removed the jumper wire the screen color problems I experienced after changing the color wheel were fixed completely. I did not need to reset the CCA values (which came with my color wheel, on a separate sticker). If you have a black bracket blocking access to the jumper wire, as I did, you can access the jumper wire by removing the fan shown just to the left of the yellow and white sticker; there are two screws attaching the fan to the chassis below it. Next, remove the two screws that hold the silver clamshell (the housing for the circuit board) halves together. These screws are right behind where the fan just was, on either side of the protruding fins. They each have a spring under the screw head. You can then pull the visible half of the silver housing forward (with the bracket attached). You will then have access to the entire circuit board. Look for CN810 - it is located right behind where that bracket just was when it was all put together. Pull the tiny black plastic part (that has the jumper wire) off of the pins. Then reassemble the housing and put the fan back on.
Jan 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
