Question about Asko D1716 Built-in Dishwasher
Stopped working altogether
Checked wires, wire connections, plug and fuse box, all seems fine. I know this because the microwave is plugged into the same outlet. I loaded the dishwasher turned the dial to cycle 5 and nothing, except when i turned the dial the orange light came on and then faded out. I tried a few solutions off your site but still nothing. I kicked it once, tried electric shock but to no avail. It may have gone to dishwasher heaven.
  • 175 Answers
Check the door switch, it may have gone bad or maybe isnt connecting with the catch, making it look dead. They wont do anything when the door is open, as you know. Also remove the lower panels to get to the inside of the dishwasher. Check for power where the cord is plugged into the machine. If you have power, unplug it and look at the terminals to the heaater element. They are on the right side, facing down out of the dishwasher tub. Just look inside the dishwasher to see where the heater goes through, then look in the same place underneath, Check the condition of these connections. The timer gets power through the heater element (strange but true) so if the heater is bad or these connections have heated and melted, it will cause a dead dishwasher. if tis just the connectio, pu t a new terminal on it and you should be good to go. Hope this helps
Posted on Nov 06, 2007
Testimonial: "Thanks Doug this fixed my problem"
My radio sound just stopped working, everything else was fine so I've come to check my connections and the one of the ISO plugs which controls the speakers is faulty but I don't know what side.. The pins...
If it were mine, I would just crimp the wires together and do away with the plug altogether. You could try using some lithium grease but that probably won't do much good. Go with the crimps. A cheap crimping set with crimps and tools are easy to find at $10 or less. Just crimp the wires as they are connected at the plug.
Feb 26, 2015 | Audio Players & Recorders
I would guess, I do not know for sure that the fa motor seized and blew the fuse, during the process the internal protection device on the fan motor opened giving you exactly what you are describing.
Nov 27, 2014 | Samsung Microwave Ovens
The "under the microwave" light was on. All of a sudden, the light and clock stopped working. We have checked the plug and checked our fuses. Are there any troubleshooting suggestions out there? Thank...
There can be several fuses. Some on the board and some encapsulated in white plastic along wires. Do the buttons work (beep) when you press them? Is there any sign of life?
Oct 08, 2013 | Whirlpool WMH2175XVS Stainless Steel 1000...
12 volt in dash power outlet 2001 dodge dakota
The power outlet uses a 20amp fuse marked D in the box near the battery.
The cig lighter uses a 15amp fuse in the inside fuse box.
May 09, 2013 | Cars & Trucks
Windshield wipers on 1986 Ford Ranger stopped working
unplug the wire at the wiper motor and then turn the key on and then turn the wiper switch on and test the wires at the plug with a 12 volt tester . if u dont have any thing then ur wiper switch is bad , if u have juice at the plug then it sounds like its the motor.
Jul 13, 2012 | 1986 Ford Ranger 2WD
Nothing works.I can't even get the display to come on. It's as if the darn thing isn't even plugged in! It was working fine and then it just went blank.We checked the house fuses and the...
After it was plugged, check the end of the wire for any voltage. If there is no voltage, cut the wires 3" away from the plug and replace the plug.
Sep 10, 2011 | Goldstar Microwave Ovens
Microwave stopped working, no power. Checked
There are two thermal fuses.
One is located on the magnetron and another one is located on top of the left side of the cavity under the air duct. The microwave has to be removed from the cabinet to access the second one.
The problem turned out to be a 20 amp fuse that I was able to replace and the unit is working fine. Sometimes a blind squirrel finds nuts.
Aug 24, 2009 | Kenmore Microwave Ovens
Fuel pump will not work
theres prolly 3 to 6 relays and fuses both under the hood and dash
Jun 27, 2009 | 1999 Ford Windstar
Hi Yes I have a Whirlpool MIcrowave Oven Model # MH7140XFB-1 And It was working fine this morning I went to use it this afternoon and the panel is not working no lights work nothing the fan under neath...
check for a blown ceramic fuse behind the panel. If the fuse is dark in color it is probly bad. you can get one at radio shack store or on line
Apr 16, 2009 | Microwave Ovens
Dead microwave oven
If you have a multimeter and are comfortable with testing "live" circuits, measure to see if there is voltage from chassis ground, to both ends of the fuse, or to each wire connection on the fuse holder.If no voltage, then the problem is very likely the wall plug does not have power (could be a wire broke inside the wall box.).
If there is power, chances are there is a controller board problem. You should have seen a wiring diagram/schematic when you disassembled to replace the fuse.
Jan 20, 2009 | Microwave Ovens
Asko D1716 Built-in Dishwasher Logo
215 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
