Question about Memorex MT2206 TV
Memorex MT2024 I have had this tv for about 6 months but have rarely used it. maby 6 times total. I just set it up in my living room and the volume doen't change when I push it up or down. It just stays at the same level unless I go to 0.
  • Anonymous Aug 07, 2008
    TV volume is very loud and doesn't change when I turn the volume up or down, it only does mute when I put it down to 0
  • dommo_g Dec 12, 2008
    I had that same problem. It went away when I unplugged the TV's power, then plugged it back in. Now the problem I have is that none of the buttons on the TV work. Still trying to figure this one out.
    Genius:
  • 1,074 Answers
If you have warranty on that tv take it back to the supplier for an exchange or refund.eerprom for that tv or the audio out put is defected.if your warranty for the tv is done then you will have to take it to a tech.good luck
Posted on Jun 19, 2007
6ya staff
SOURCE:
I neid go know how to reprogram one of the controls for the tv in a room but i lost the control for the tv in my living room, in the living room i have the cable box.
jc4lifes3as
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
Remotes: Basic (Television Only)
1. Turn the Television On.
2. Press and hold the TV Power button for three seconds until the LED flashes.
3. Enter the three-digit code using the buttons on the number pad.
4. Press OK. Note: The LED will flash three times.
5. Test functionality with the TV.
6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Power Scan:
Remote: Basic Remote (Television Only)
3. Press and release the TV Power button.
4. Press and release the Up or Down Arrow on the remote until the television turns off.
5. After the television turns off, press and release the OK button.
6. Test functionality with the TV.
7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network"
Apr 16, 2011 | DISH Network IR Remote Control
What is the best setting to use for the volume leveler?
No, best volume setting,but raise to 20-25 it average setting for good volume for a living room or bed room.
Mar 15, 2010 | Panasonic Viera TH-50PZ800U Plasma TV
Changes channels by itself and turns off and on
Believe it or not, most common problem is dirty, faulty remote. Remove remote from room, if TV still does it, unplug TV, push and release power and volume buttons multiple times each and wiggle while doing. Try letting them "pop" out after you push in. You may be able to feel a "bad" one. Plug back in and do each several more times. If no difference, problem is internal circuitry (very rare).
Ghost or someone/neighbor playing games(must be very close)
Sep 26, 2009 | RCA TruFlat 27F520T 27" TV
Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
Dec 15, 2008 | Proscan 32LA30Q Television
I have a Denon 2308CI. I use the 7.1 suround. I have my sony STR DE995 to use as a second amp for zone two hook up. My goal is to watch a movie in the living room and listen to the radio or any other audio...
the mani surround room should be connected to the front speakers A, Center, sub pre-out and surround.
for the other two rooms connect them to surround/back, go into settings and in power amp assignment assign the surround back speakers to the multi room.
once this is complete with your remote in the zone2 control mode you can play your sources in zone2 and control the volume also, if you have inwall volume controls set the zone2 volume to -10 and use the room controls.
To listen to the same source in both zones you will have to select that source in both zones
Nov 16, 2008 | Denon Audio Players & Recorders
Remotes no longer work
I had this exact same problem. After a week or so it started responding to the remote control again. Then after a couple of days it stopped responding. This problem came and went for about a month, then one day the entire TV went dead. When I powered it on, the green light appeared for 2 seconds followed by a sequence of 6 flashing red lights that repeated. I brought my set in to a repair shop and they replaced the power supply board. That fixed the problem and now the TV powers up and responds to the remote control again. Total charge was $250. That was very disappointing for a $1,500 TV that was only 18 months old. I'm going to let Philips know how disappointed I am in their product!
May 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv is unresponsive
Does your set have a reset button on it? It sounds like we had the same problem from the beginning. In fact, we have bought and exchanged the tv 3 times because we thought maybe we just had a lemon. The picture would freeze and no buttons would fix it. We read in the owners manual about the reset button -- a tiny hole in the top of the power button on the right side of the tv. You can use the end of a paper clip and stick it in the hole to reset the tv. The tv powered off and then the remote and all the other buttons worked. Ours is still in the warranty but for the first month, it seemed like this happened at least 5 or 6 times. Haven't decided if we want to try to exchange it again or just live with it. Other than this, we love it!
Jan 08, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Multiple tv sets
With the multiple TV's what you are looking to do is called "IR routing" There is not exactly a "pre-packaged" solution.
Try one of these companies I think all of them can handle this:
http://www.crestron.com/
http://www.universalremote.com/
http://www.amx.com/
http://www.rticorp.com/
I would have it professionally installed. You can find a professional in your area using the locater on the websites.
Hope that helps!
Nov 20, 2007 | Apple WIRED REMOTE 4 ZEN MICRO Remote...
Memorex MT2206 TV Logo
239 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
