Question about Intel 486 CPU Cooler CPU Cooling Kit
I can't instal windows 95
When i put boot up cd in my cd rom he not reconaise
In BIOS not exist options "boot up from cd"
  • 1 more comment
  • Misterixas May 11, 2010
    have you checked whether your Windows 95 CD is really bootable? Some Windows 95 CDs are not bootable, so you need to make a system floppy disk to load DOS first, then locate your CD drive letter (for exmaple D:\ ) and run setup.exe then
  • DEKR
    DEKR May 11, 2010
    did you solve your problem
  • deangov92 May 11, 2010
    some bios's you change the order of boot devices by using + -
  • 21 Answers
IIRC the very early Windows 95 installation required CD-ROM drivers prior to Win95 set up, this was achieved using the supplied diskette.
The work-around for this issue is to do the initial install on a different system and transfer the HDD to your 486 system, this must be done BEFORE windows configures the driver set OR setting the drivers to MS default is required following completion of setup (on surrogate system).
Posted on Jan 26, 2009
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
HI, i can not boot from usb cd-rom. My internal cd-rom dont work but i need to install windows again. Can you help me? Thanks
press F2 when you restart your laptop but for desktop press DEL when your computer is starting up to get it to the BIOS then look for BOOT OPTION the make the USB CDROM on top to make it the first boot.
or
insert your Windows Operating System CD and restart your computer then press F8 multiple times and it will give you option to select CD ROM to boot from
Sep 11, 2011 | ASUS A2H (A2HOB) Barebone
I deleted win 95 then iwant to install win98
Indeed. If you have the windows 98 disc then just insert it into you CD rom drive and restart the computer. You should have the option of pressing any Key to boot from the CD. If not you need to hit delete a number of times when the machine 1st turns on to enter the Bios set up. In here you can change the boot order. Give your CD ROM drive the highest boot priority. Save & exit. Now you will have the option to boot from CD.
From here you are very much guided by the onscreen prompts. It's a straightforward process.
Jul 03, 2009 | Microsoft Windows 98 for PC
How do i
Put your system restore disk in your cd rom then restart the computer. It will give options for repair or restore.
Jan 19, 2009 | Sony VAIO F340 Notebook
Toshiba a205 laptop wont boot
try to boot the windows from external DVD or CD ROM on USB if you have acces to your BIOS set the bios to boot from USB. i think your CD/DVD rom is not working properly, or is no booting from it bios is not setup corectly.
Jan 17, 2009 | Toshiba Computers & Internet
Blue Screen of Death
You'll need to setup the Acer laptop to boot from CD-ROM. Push either the F2 or F10 button when booting your laptop and it should bring-up the configuration management interface. Go through the options and confirm that Boot From CD-ROM is at the top of the list on bootable devices.
Next, you'll need your original Windows XP CD that came with the Laptop. Put it in the CD-ROM Drive and reboot your laptop. You will be given two options: 1) Re-install Windows or 2) Repair the existing Windows Installation. I recommend that you repair the existing Windows Installation as this will not destroy and data or device drivers that are install on the laptop.
Good Luck!
Dec 16, 2008 | Acer Aspire 5050-3242 Notebook
Acer 3690
Could be various causes just follow the information below and you should solve it.
Good luck
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  3. Corrupt NTLDR and/or NTDETECT.COM file.
Solutions:
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
  1. Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
  2. At the A:\> prompt type:
    sys c: <press enter>
  3. After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Oct 31, 2008 | Acer Aspire 3690-2196 Notebook
My pc was doing this but now it's doing something different but simular
Try telling it to boot the CD instead of the disk for now, since you need to install from that...or perhaps a newer OS.
Jun 23, 2008 | E-Machines eMachines T3830 PC Desktop
I found a pc that has windows 95 installed in it . how can the old windows be replced by new windows
if you want to remove win 95 just remove it ... or else if you want to install new version .. try upgrading ..
Sep 30, 2007 | Microsoft Windows XP Professional With...
Intel 486 CPU Cooler CPU Cooling Kit Logo
390 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
