Question about Canon CNM9829A003AA ImageClass ICD860 Digital Copier/Printer COPIER/PRINTER,LASER,D860
Systems Error reading
There is a systems error reading. There is no paper jam. I checked all the areas. Alarm light remains blinking.
  • jtkim5051 Jan 17, 2009
    Suggestions provided do not work. No paper jam, stuck papers, etc.
    Sergeant:
  • 221 Answers
Unplug the power cord.press the start menu button and keep it pressed and plug in the power corn and switch ON the unit.it will reset and solve the error code problem.
Posted on Jan 16, 2009
  • 66 Answers
What was it doing when it happened.
    Sergeant:
    Scholar:
  • 199 Answers
Unplug the power cord for sometime and reconnect ity and check out.also check the rollers that cling the paPERS.
  • 679 Answers
What was the error code?
  • 1 more comment
  • rockfixya
    rockfixya Jan 16, 2009
    Try some cleaning….. clean the printer rod and cartages head,
    and let me know if problem persists
  • rockfixya
    Open the printer and see inside might be there is some paper gets jammed inside.
  • rockfixya
    rockfixya Jan 20, 2009
    please let me know if problem solved.
    Thanks for using FixYa.
Had paper jam which have cleared. Getting support code 6001 saying turn off and restart which we have done but still keeps coming up with same error
The 6001 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
Aug 24, 2016 | Office Equipment & Supplies
How to fix code 6000 mx922
The 6000 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
If the above procedure does not resolve the error, the unit would require service:http://www.usa.canon.com/cusa/page.action
May 03, 2014 | Canon Pixma MX922
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Alarm is blinking and computer is stating that
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 16, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Getting a alarm and error reading after paper jam
Wow theres a lot of information in that question. Thought long and hard about what you wanted to ask huh?
Like what model printer is it?
Feb 03, 2010 | Office Equipment & Supplies
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Brother HL-1440 LASER PRINTER requires ''Service Call A''.
currently, the error you have is not a service errorl, ready and alarm blink means that you have either a paper jam, no paper, or a paper misfeed.
do you get this error only when you try to print?
according to the service manual the lights can not alternate in blinking.
May 30, 2009 | Brother HL 1440 Laser Printer
Canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Nov 24, 2007 | OEM Systems PIXMA iP3300 Photo Printer
Canon CNM9829A003AA ImageClass ICD860 Digital Copier/Printer COPIER/PRINTER,LASER,D860 Logo
101 people viewed this question
old marine
old marine
