Wall heater not running. The pilot is lit but will not turn on.
    President:
  • 1,214 Answers
With the pilot light lit, and if this is a older valve (no electronic ignition) then make sure the valve is turned to on (knob on valve.).
If knob is on, or system uses electronic ignition, then make sure the thermostat is calling for heat. Also make sure if the unit is 120 VAC powered, that power is on.
If electronic ignition, then the flame sensing circuit has failed.
Reply specific make and model number for more information.
Posted on Jan 16, 2009
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Glo warm gas wall heater
Sounds like a bad thermocouple. When they go bad, they won't open the gas valve when switched from pilot to on.
Dec 04, 2013 | Heating & Cooling
I have a Mr Heater infra red propane wall heater. My problem is it turns itself off (pilot light) after running for an hour or two. I have no problem getting it turned back on but for some reason it d
Your pilot flame should be blue with a small yellow tip, and it should cover the thermocouple (a small rod in front of the pilot light). If the flame is too small and doesn't cover the thermocouple, it may be adjusted too low, or you have low gas pressure or you have a leak in your gas line coming in to the heater. If the flame looks like a lazy yellow flame, you are probably not getting enough air to the flame. Check that your air openings around the pilot are not clogged up. If the flame looks like a waving blue flame then you probably have excessive draft at the pilot. If the pilot flame looks good and covers the thermocouple, then the thermocouple might be bad. Best of luck. I hope I have helped.
Nov 23, 2013 | Heating & Cooling
My wall heater is a williams gas wall heater and I just had a question is the pilot always suspose to be lit the main is not lit but when it is off there Is still a flame that's on Ithink its the pilot is...
All gas appliances have a constant on pilot light.This keeps you from having to light it everytime it goes on. The pilot flame is small, and usually mostly blue in color. If there is any yellow or orange color in the flame then the jet is dirty, which can cause a malfunction ( just thinking this could be handy to know!).
Thanks for using Fixya!!
Nov 09, 2013 | Heating & Cooling
My gas wall mount heater works a while then shuts down. why?
When it is running check the flame. It's triggering a rollout switch.
Feb 27, 2013 | Heating & Cooling
How to light the pilot light on a natural gas wall heater
SEt to pilot, Push knob, push pezio ignighter until pilot lights, hold for 30 seconds. if it stays lit turn to on, if it doesn't stay lit, you have a bad thermocouple
Mar 24, 2011 | Vulcan Heating & Cooling
I HAVE A wILLIAM wALL hEATER. tHE PILOT LIGHT IS
The blower is heat activated, it takes more than the pilot. If the burners are on, verify power to the unit.
Jan 01, 2010 | Williams Heating & Cooling
Williams wall heater
It can be shut off, but do not just blow it out.
Mar 02, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heater goes out after 10 to 30 seconds.
sounds like a blocked pilot when you turn on the main gas takes the gas away from the pilot and goes out
Nov 08, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
