Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
How far can the condensor be located away from ice machine
I have a Hoshizaki Modular ccrescent cuber Model KM-900MRH3 which is designed to have a remote condensor. My question is how far can the condensor be located away from ice machine?
  • Hoshizaki Master
  • 1,238 Answers
Their web site has all your answers. Their tech support line is worth the wait. 1-800-233-1940.
I usually don't exceed 25 feet. If it is a straight up install, that is, the remote is on a roof, you may have to install traps to ensure proper oil return to the compressor, Otherwise, it will lockup on ya.
Posted on Feb 13, 2009
  • Dennis Boxerman Feb 14, 2009
    I have look alittle deeper and could not find the exact model number you have but I did find 2 units that are probably very close to what you have. The instruction for the KM-800M and the KM-900MRF3 both indicate that the condenser should not be more than 33 ft above or 10 ft below the ice maker. These measurements are from fitting to fitting. There are no indicated distances as to length, as in far away. Just how high or low. Hope this clears this up some. It also indicates that Hoshizaki sells precharged line sets in 20,35, and 55 length sets. So that should be a further indication as to what you are looking for.
Hoshizaki ice machine model km 900mwh low side suction line has ice building up on it all the way to the compressor
Is it making ice? Frost on this line is not that uncommon as it is colder than the air around it. Make sure you have good water flow over the evap plates. machine may just need a good chemical cleaning.
Jun 14, 2014 | Hoshizaki Commercial Freezer KM-500MAH
Stopped working, checked power supply, which is fine. but wont turn on.
The micro switch that is activated when switching from wash to refrigerate is most likely worn. Try jumping it out.
Aug 03, 2010 | Hoshizaki Commercial Freezer KM-900MRH3
I need a new part for Hoshizaki Model # KM-500MAE. Help!
Rick at Restaurant Parts and More can get Hoshi parts. Just have model and serial numbers. He takes credit cards. Usually can it parts in about 3 days to your door.
Aug 02, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-500MAH is making sliver/chip ice. I
just to let you know you need to use nickel safe ice machine cleaner. and i hate to tell you this but if you are seeing silver chips in your ice your evaporator is shot. even if it is under warranty they will not give a new plate just for the reason of not using nickel safe cleaner. hope this helps you. i have seen this many times as im a service tech. alot of restaurant owners use coffee cleaner and also destroy their plates
Jun 05, 2010 | Hoshizaki Freezer Commercial Ice Machines...
I have a hoshizaki km-250bwf and it the comprsser
Check the control board for a "output" test switch.
If it is "ON",turn it off.
Nov 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki condensor fan motor is not working
Too long to explain sequence here. but in the harvest mode the fan will not be running. go to hoshizaki.com you will find every thing you need very helpful site . and a clean machine is a happy machine. hope that helps Tom
Jun 28, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine model no. KM500MAF
go to their web site. lots of good info. too much to get what you need here. lots to concider when installing. self contained? remote condenser? location of unit. and lots more. tech support 1-800-233-1940 may shed some light too
Jul 02, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
96 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
