Question about Asko 24 in. 1585 Built-in Dishwasher
Top Rack always slides out fully
A friend has an Asko DW, 9-years old, model 1585 or similar, it operates fine. But, when you open the front door, the top rack always slides out all the way -- whether full or empty. It slides out by itself, stopping in the fully out position. This makes loading the lower rack difficult since you have to hold the upper rack closed with one hand. Guessing that the unit was not level, I adjusted the front leveling legs under the unit, so that now the unit is slightly unlevel -- slightly higher in the front, lower in the back (if measured with a carpenters level). The top rack still just comes flying out when the door is opened. Using the level, I have also confirmed that the metal rails that the rack's wheels ride in are still lower in the front, even though the DW unit itself has been adjusted to be slightly unlevel in the opposite direction (per above). The rails are as assembled by the mfg - we haven't modified them and I'm assuming they are not adjusted during installation. The friend/owner says this auto-slide out has been happening since the unit was new. Can you advise on an adjustment or faulty part that could be replaced to stop this nonsense or suggest why this is still happening? Many thanks! lnor
  • Anonymous Mar 22, 2014
    Have taken dish tray off to expose side rails. Can see that there is part of the rail that comes out past the end do the rail that slides, this does not come out on the slide tracks that are still OK. How do you remove the side rails.
    Thank
  • 175 Answers
Well, you are right on about the level. It is tilted just slightly forward. The only parts to go bad are the plastic ball bearing guides, and usually when they go, you get a rack that wont come out and gets jammed. You 've got the problem, you just need to remove the screws hidden in the holes that are sometimes coverd with rubber plugs so that the dishwasher may move freely, andjust it till it no longer rolls out, then screw it back to the counter to hold it in place. There are no springs in that rack, so either its still tilted forward, or the tank is bowed or bent somehow, and that would mean new dishwasher. Hope this helps!
Posted on Jul 18, 2007
ASKO 1375 Dishwasher top rack keeps rolling out
Your dishwasher may have sagged since being level when installed.
May 20, 2016 | Asko 1375 Dishwasher
Asko 1755 dishwasher. The pump keeps running We need to replace a new PCB P/N: DW955 8057931-05 Is it available?
My Asko Model 1585, Type DW 95.4 Circulation pump just died. I have the following parts available (All in working condition):
* 8057931-05 Control Board (this is the replacement part AFTER the recall)
* 8057083 Drain Pump
* 8057085 Fan circulation module (the one in the dishwasher door)
* 8057077 Heating Element
Photos and motor/coil/element resistance values available on request. I have no prices listed as I am still trying to determine their value. I am an old Boy Scout & NOT out to screw anybody.
Feb 20, 2011 | Dishwashers
Top drawer
Hello, Welcome to FixYa. Based on the info you provided it's likely a pretty easy fix. The machine is leaning forward slightly and it shouldn't be. Remove the top screws fastening the machine to the counter...if applicable, some are on the side if granite counters or similar exist etc. Then take off the lower kickplate/access panel and screw the front leveling legs down ( which will cause the tilting of the machine back slightly ) and screw the back legs up, hence the rack should no longer slide out on it's own. There are also locking nuts for the legs so make sure you loosen amd re-tighten them in the process. Let me know how you make out. The most difficult part will likely be the removal and replacement of the toe panel/kickplate. Good luck, Macmarkus :)
Aug 02, 2010 | Asko D1706 Built-in Dishwasher
Asko dw 95.2 model 1705 after 6 years of use the dishwasher top drawer rolls out. Will not stay inside when main door is open.
Check the level and tightness of the slide rails--they may have come loose after the years of use. Make sure the dishwasher case itself is level. Hope this helps!
Jun 29, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Top rack slides out of its own accord when I open the dishwasher.
Your dishwasher most likely needs to be re-leveled.
Remove the toe-kick plate at he bottom front of the DW. Use a wrench to lengthen the front leveling legs to raise the front of the dishwasher.
Feb 01, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
The top rack on my Asko D1796 dishwasher is defective
call manufactuerer and ask or a good appliance parts and repair they usually are on a spring clip and you just replace the whole roller
Dec 25, 2009 | Asko 1385 Dishwasher
Asko 1805 - inside light is on, none of the operation (front panel) lights turn on
Quite simple after all. If the main power button on the top left hand side of the door is pressed in (on). Whenever the door is openned their is a light in the DW which comes on like the fridge or oven.
Keeping the power button off turns the light off. For us this is good as we usually only close the door fully (catch catches) when we run the machine.This way we are not wasting electricity.
Nov 14, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Top rack will not pull out all the way
Replace the upper basket wheels - these are available as spares. If the metal runners look angled - it may be the wheels on the side of the dishwasher that need replacing. These are also available as a spare part.
Ebay is actually a good place to shop for spares of this type.
Aug 04, 2009 | Asko 24 in. 1585 Built-in Dishwasher
Asko D1996
Peace friend,
ngfam1 at your service
It is the stops .
You can call this parts house and they will help you figure out the part #'s. If they have them in stock they will sent them usually in one day.
or you can see the parts in the user manual too!
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
How old is the appliance?
If it is 9 years old or more it may be putting god money into bad!
The new ones pay for them selves in a few years on the savings of energy, and water because they clean better with less water!!!!!!!
A much better n you electric bill!
If you need a good repair Here is who I recommend nation wide.
A&E Factory service open 24/7 for appointments!
1-800-905-9505
Ngafm1
PLEASE GIVE ME THE BEST RATING BEFORE YOU SIGN OFF! BLESS YOU
Aug 31, 2008 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
1,107 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
