Question about Sony KP-57WS510 57" Rear Projection HDTV
No picture started out i had curved blue lines that never went away had them for quite a while then the other night my tv faded to blue then went black and still has sound. i can turn the tv off and back on and it will repeat it all again in a matter of seconds. any ideas thanks chad
    President:
  • 3,130 Answers
Yep, the convergence IC's to start with. If you keep using this set the way it is, you will make the D as well as the G board go bad. Have the set repaired asap and do not use it like this. Good Luck
Posted on Jun 19, 2007
SOURCE:
No picture with a curved green line on screen when tv is on
Replace Bothe of your convergence ICs They will be big black ICs will have Part number on them
STK392-570s Mats Electronics Has Them 1-800-628-1118
Mar 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Blue screen sony
blue crt shorting use crt restorer to lift short or replace picture tube /crt
Aug 19, 2008 | Sony KP-46WT500 46" Rear Projection...
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Blurry Curved Picture
Convergence IC's need to be replaced...change them both..
part # STK392-560.....Check soldered-in fuses...........T.
Dec 25, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Sony KP-57WS510 57" Rear Projection HDTV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
