Question about Garden
Gx160 my engine runs for 30 secons then stops \after a couple of pulls in stars up and then stops ...is driving me c#%$
  • baileypope Mar 24, 2009
    I have the same problem on a lawn mower with the same engine. It starts, then runs for about 20 seconds and cuts out. have cleaned the carb on several occations and the fault still exists. fuel tank is clean and the hose from tank to carb is clear. when it stops have checked for spark and always found one. its driving me mad.
  • Tom  Barnes
    Tom Barnes Apr 19, 2009
    We have a the above mentioned Honda engine attached to a 2" water pump used to pump out the holding tanks of boats. For a while now when we start it will run for about a minute, start running rough and then stall out. It can be restarted again, right away, and the same thing will happen. We have installed a new filter in the tank, replaced the carburetor, removed the head to clean and inspect the valves (they look great) reassembled everything and the same problem exist. I don't know where to go from here. This problem started out slow and has gotten progressively worse to where it is today. After a few starts the spark plug is fouled black like it may be running too rich.
    Novelist:
  • 126 Answers
I'd pull the fuel hose leading to the carburetor and see how well gas flows out of this hose. if it just trickles out, the either something in the tank is obstructing it or the vent is blocked. the tank has to vent to allow air in as gas flows out to the carb. most vents are built into the gas cap by little hole(s) on it. see if the hole is blocked on the bottom side of the cap with ****. if unsure, start the pressure washer with the cap off and see if it runs for longer than 30 seconds. if it does, either clean the cap or get a new one.
also, some pressure washers need water flowing to the unit before you start it. if it senses no water, it may turn its self off to protect it. not sure how smart this washer is, but just another suggestion.
good luck
Posted on Jan 18, 2009
Check to see if the spark plug cap is grounding to the engine. Look for a spark where the cap is closest to the engine.
Posted on Jun 01, 2009
1988 bronco2 run for about 30 minutes baugh down it stops
That much time running sounds like the catalytic converter is plugging off and stalling the engine.
Oct 18, 2015 | 1988 Ford Bronco II
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Jan 16, 2014 | 5.5 HP GX160 Engine
Honda gx160 will not run on idle
There are a few things i can think of that would cause that problem. #1 clean out the carb, some times when an engine sits for a little while the gas will gum up in the carb. #2 check the tuning on the carb, It is possible that the idle screw needs a bit of adjustment. #3 The gas could have gone bad. Again if it sits for a while and the gas cap doesn't seal properly your gas will go bad in a hurry.
Hope this helps.
Sep 20, 2013 | 5.5 HP GX160 Engine
GX160 pull start spring broken how do I get the bolt loose??
Unscrew clock wise.in reverse to normal procedures.
Jan 12, 2013 | 5.5 HP GX160 Engine
Honda GX160 firepump runs good than dies starts first pull after and repeats
Check that the fuel tank is venting properly, sounds as though the tank is not venting therefore creating a vacuum that the carburetor cannot over come. Try running the engine with the fuel cap loose to see if that alows the engine to continue to run.
Dec 16, 2012 | 5.5hp 6:1 Gear Ratio GX160 Engine
Honda GX160 starts runs dies
How about the carb was it cleaned ???? It's definitely a fuel issue
Honda gx 160 runs for 30 minutes then shuts off and wont re-start
Try checking the fuel filter and or line. Sometimes dirt is drawn in to plug the line, then settles back down later.
Nov 28, 2012 | 5.5 HP GX160 Engine
Low output on 110 when using power tools
Take and plug in a variable speed drill now when your generator is powered up slowly hit the trigger on the drill start it at low speeds run it for 30 seconds then give it half speed for 30 then full speed fo 30 seconds then try your chop saw
Nov 25, 2012 | 5.5 HP GX160 Engine
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
693 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
