Question about Nikon CoolScan V ED Film Scanner
Unable to scan b/w neg's correctly using Digital ICE
I am unable to scan black/white negatives correctly using Digital ICE.
Any C-41 Neg's work great, but when using older b/w neg's (ie: Koday Tri-X), the finished scan comes out looking like a bad xerox copy.
When I uncheck the Digital ICE, scan looks fine...except all the dust & scratches really stand out. which leaves a lot of wasted time trying to correct in Photoshop.
Any tricks to scan b/w neg's with Digital ICE???
  • burkie6 May 09, 2009
    I just realize that I have the same problem using Nikon Coolscan V ED: gray shades are not shown properly, and it looks like a hard B+W copy. Naturally have to mention, that I used all B+W adjustments available, but useless. Any advice available?
Unfortunately, you cannot use Digital ICE on B&W films due to silver particles contained within the film. The Digital ICE future only works with C-41 (negatives) and E-6 (slides) processed films, but not B&W films.
Posted on Jun 03, 2009
Wiring a DVC 10 inch sub to 2ohms
RED IS USUALLY POSITIVE
RED-WHITE IS MORE THAN LIKELY NEGATIVE
TO CHECK SPEAKER POLARITY:
1. HOOK LEADS UP AS I DESCRIBED
2.TAKE A AAA,AA,C,OR D BATTERY
3.CONNECT POSITIVE SIDE TO POS ON BATTERY...NEGATIVE TO NEG END......
4. IF SPEAKER "CONE" PUFFS OUTWARD..POLARITY IS CORRECT. IF IT PULLS INWARD..POLARITY IS REVERSED
Jul 21, 2013 | Cars & Trucks
Trying to install kenwood kcd mp238 cd player into a 1996 Ford Expedition. I need to know wiring data to connect the wires of cd player to harness, which colors should I match wires up to, so I can just...
Black Ground, yellow, battery, red switch battery, blue not used, blue white power antennea/amp, brown tel mute, white black front left neg, white front left pos, gray black front right neg, gray front right pos, green black rear left neg, green rear left pos, purple black rear right neg, purple rear right pos
Oct 24, 2012 | Car Audio & Video
I have an urban audio works 7 band equalizer. i have a spx pro audio amplifier and an alpine cd reciever model cde987. the equalizer is not installed. could your please tell me where to wire in the blue,...
INPUT: Yellow (left front), violet (left neg), green (left rear), Blue (right rear), Brown (right neg), Gray (right front)
OUTPUT: Front Left pos (green/red) neg (green), Front Right pos (gray/red) neg (gray), Left Rear neg (brown) pos (brown/red), Right Rear neg (white) pos (white/red)
dfsanchez@yahoo.com
Mar 14, 2011 | Car Audio & Video
Scanning 35mm negs on my Epson Stylus PHOTO RX620
Try using a slightly off-white background sheet behind the negative (glass-negative-sheet-scanner lid) first, or a "frame" around the negative that is anything but white... some scanners have an auto-detect feature that may be skewed for one reason or another.
Another trick, from a photographer friend, is to take saran wrap or another transparent but non-reflective material and place as a filter between the negative and glass, thus reducing glare. The sharpness may be lessened, but the glare is also lessened...
Hope this helps!
-- RT
Aug 28, 2009 | Epson Perfection 4490 Office Flatbed...
8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
May 08, 2009 | Audio Players & Recorders
I have a 3490 scanner but have lost the neg holder to scan negs.
You really cannot scan a neg without a special holder. I recommend paying $90 to Costco and buying their special USB Scanner which scans one neg at atime! They are great!
Thanks,
Mark
Dec 31, 2008 | Epson Perfection 3490 PHOTO Flatbed...
PIONEER SUPERTUNER 3 KEH-P4200
tdohnke-So you need a wiring diagram,well lets see what we got
red-accessory-12volt key switched
orange-12volt constant-memory
black-ground
white-left front speaker-positive
white with black stripe-left front speaker negative
grey-right front speaker-pos.-
grey w/black stripe-right front-neg.
green-left rear-pos.
green w/black stripe-left rear-neg
purple-right rear-pos.
purple w/black stripe-right rear-neg.
blue- remote turn on
orange w/white stripe-dimmer-optional
Try out this diagram,they are pretty much all the same now,if I missed any let me know. cooltek Mar,4/08
Mar 04, 2008 | Audio Players & Recorders
Description of Wires
318lawless- these wires are the speaker outputs,the white is left front positive and the white with the black strip is left front negative. grey right front positive, the grey/black is neg. the purple is right rear,purple black neg.green is left rear,green black isneg. If you have any further questions let me know. cooltek Mar,3/08
Mar 04, 2008 | Pioneer DEH-P2900MP CD Receiver...
Canon AE-1 with Program
Have you change with a new battery?
Or check the battery with a DVM(digital volt meter).
Or get some batteries and connect in series to equal to that voltage and use two wire leads. One lead to -negative side of the battery, other lead to +positive. Now, -neg to neg of camera and +pos to pos of camera.
You now have power to the camera to test. This will save money rather than buying the camera's battery for testing. AA, C or D will work, just look on the camera's battery to see the right voltage.
Examples: with two batteries (1.5VDC + 1.5VDC = 3..0VDC). So -(negative) of one battery to + (positive) of the second battery with solder.
-(-neg, battery, pos+) solder to -(neg, 2nd battery, pos+)+
left side , use black wire on -(Neg) and solder
right side, use red wire on +(Pos) and solder.
Now you have two leads, use those to connect to camera.
Do you get data from viewfinder?
Dec 10, 2007 | Canon EOS-AE-1 35mm SLR Camera
Wiring a pyramid 903G
red - power
Black - Ground
Blue/Black - rear Left Speaker Positive
Blue - Rear Left Speaker Neg
White/ Black - Front Left Speaker Positive
White - Front Left Speaker Neg
Brown/Black - Rear Right Speaker Positive
Brown - Rear Right Speaker Neg
Yellow/Black - Front Right Speaker Positive
Yellow - Front Right Speaker neg
Green - Left Input Positive
Green/White Left input Neg
Gray Right Input Positive
Gray/White - Right input Neg
Nov 16, 2007 | Pyramid 903G 10-Band Car Equalizer
Nikon CoolScan V ED Film Scanner Logo
654 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
