Question about GoVideo VR4940 DVD Player/VCR
How do you start with it i tried but it says it was the wrong type of dvd and it is the rewritable one
  • 55 Answers
Make sure the dvd +rw or -rw are compatable with your unit. Some do one or the other and some do both.
Posted on Jan 16, 2009
Wat to do if an empty dvd shows no free space
it means thers something wrong with your dvd it may happen if you abort writing after it started if its rewritable you can erace all the files and try again if its not rewritablw you must buy a new dvd
Jun 17, 2011 | Computers & Internet
Brought 5 maxell 1.2x rewritable 4.7 gb data dvd-rw tried to record a film keeps saying no disk what am i doing wrong? kind regards ken moore
if the other 4 dvds are still wrapped take it back (in exchange for 4x 4.7gb dvd-rw)...you picked up 1.2x your player maybe looking for higher speed..these recorders are very sensitive for the type of dvds it use..(i can only use maxell /panasonic + dynex (online))..cant use some of those on sale ones.....my recorder wont just eject it it rejects,,,,
hope this is your case, feel free to rate the help
Jun 16, 2010 | Maxell MAX635114 Rewritable Single-Sided...
Laptop doesn't recognise DVD rewriter - LG
If your laptop dont recognise dvd rewriter it may be due to many reason it may either due to Ide cable or a registry issue or a hardware issue .Try following steps :
1 make sure you have correctly inserted the IDE and Power Cables. Fault of putting the IDE cable in the wrong way around make this happen.
2 Make one drive the the Master and the other the Slave, don't set both to Cable Select.
Is it not recognizing the drives in the BIOS or Windows? Try changing IDE cables?
If BIOS, have you gone into the BIOS and verified that the drives are detected? Try changing the BIOS settings for the IDE Channels from AUTO to CD_ROM. At least then, from a hardware viewpoint, you are forcing the system to recognize.
3 If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players.
4 If its a registry issue then try following steps but remember first take back up of your registry
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters....
RESTART YOUR COMPUTER THEN THERE YA GO!!!! HOPE THIS HELPS
Mar 24, 2010 | Computers & Internet
How many times can I burn information on one DVD+R disc? I burned it about 3 times after the initial burn, and I can only find the two files from the first burning session. (I'm using the CyberLink DVD...
someone correct me if i'm wrong, but i believe you cannot rewrite onto dvd+r nor dvd-r. you need dvd+rw. then you can rewrite and add on to it. there is also
dvd-rw which you can rewrite on to. most dvd burners accept both types. you'll need to check your burner's info to find out. it might be on the front of the unit itself if it's not covered by the computer's burner door.
May 17, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
How do you use the combo I tried but I did it wrong it says wrong dvd and it is a rewritable one Thamks
The Go Video VR 4940 can only record to DVD -R and DVD -RW discs. It cannot record to +R or +RW discs. It can play back many types of discs, but can only record to the -R and -RW ones.
JFFields
Jan 16, 2009 | GoVideo VR4940 DVD Player/VCR
Unable to copy dvd's
Most dell machines do no come with dvd rewriting as standard. They only come with cd rewriting capability. Unless you specifically requested it as an add on to the spec it probably just has the ability to pay dvd's.
Most internet cafe's will have a machine with a dvd rewriter if you really need to copy a dvd
Val
Dec 15, 2008 | Dell Inspiron 6000 Notebook
NEC ND-6650A
well, sounds like common error promblem have you tried looking and seeing if mite have bought the wrong kind of dvd's I have done this before i bought dvd's instead of Cdrw's discs.? or try dowloading www.slysoft.com thier cd player plays and reads and rewrites almost anything .. lala linda
Jun 03, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
Problem with dvd rewriter
You're probably using the wrong format dics.
Feb 14, 2008 | Computers & Internet
GoVideo VR4940 DVD Player/VCR Logo
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
