Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Trio Bottom Freezer-Ice in Freezer
I have ice in the freezer on the food and the walls of the freezer and the refrigerator seems cold even though its set to 38 and freezer temp is 0 I called Sears. but of course the warranty has expired. My husband says to raise the temperature and see what happens.  What might be going on.  Could this be very expensive to fix?  Sears has an option to pay a certain amount for the year or pay for one time plus parts and labor.  Thanks,
    Problem Solver:
  • 11 Answers
Check the freezer walls . the roof of the freezer falls at times trapping moisture and caUSEING FROST . MAKE SHORE THE DOORS ARE CLOSEING PRIOPERLY .. ALL THE WAY .. ALL OF THEM SOME TIMES THE PCB BOARD FAILS AS WELL . CAUSEING THE VAP MOTOR TO RUN DURING DEFROST CAUSEING MOISTURE IN FREEZER .
Posted on Feb 04, 2009
Both fridge and freezer are turned up to maximum cooling but they just aren't cold enough even though the weather is mild. Icecream is very soft - barely frozen and fridge temp is about 8 degrees...
Sounds like a failure to defrost.
Look on the freezer rear wall inside the freezer for ice bukdup.
If there is ice the defrost components ,must be replaced.
Dec 01, 2010 | Fisher and Paykel Active Smart® E522BR...
The freezer is forming ice on back wall and all around the ice bins where the ice storage is, plus forming on food boxes, what could be the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Kenmore TRIO 77314 Side by Side Bottom...
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
Ice on back walls and in freezer-Trio 596
Look for frost on the backside of the freezer wall. If you have some then you probably have a bad defrost heater. Remove the rear access panel and inspect for ice. Get a hairdryer and remove the ice and replace defrost heater assembly.This is a fairly easy job.
Jan 16, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
