Question about Napoleon Auburn Pellet Stove Heater
AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
SOMETIMES THE AUGER TURNS AND OTHER TIMES IT WILL NOT. NOTHING IS BLOCKING THE AUGER AND THE GRAVITY FEEDER HAS BEEN KEPT LOW SO IT WON'T JAM UP.  SUGGESTIONS?  THE BLOWER MOTOR IS.
  • Allison Hulbert May 11, 2010
    is it quitting? The augers are on a timer so they dont feed to many pellets
    President:
  • 1,723 Answers
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
Posted on Jul 01, 2009
    Problem Solver:
  • 10 Answers
Take the side panel off so u can see the auger motor shaft ther is a bushing wit a set screw in it tighten set screw
Posted on Sep 28, 2009
My auger wont feed the pellets - I can hear it turning but nothing is feeding
Have you checked to see that the auger is not blocked? Or the pellet hopper is not blocked ? if the auger is turning then it has to be that something is blocking the pellets from getting in to it.
Dec 18, 2017 | Heating & Cooling
Stove will run for 5 to 15 mins and the auger will stop feeding.
Are the pellets getting stuck or jammed in the auger? Take a look at this website and perhaps it will give you some ideas to look at:
http://www.pelletstovefires.com/pellet-stove-problems.html
Nov 22, 2017 | Pool & Spa
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
How do i fix ager on my pellet stove?
Hello Ethan, First I would uncouple and remove the auger motor from the auger shaft. Next turn the stove on to see if the auger motor turns. If it does turn, try to hold the motor shaft with your hand to determine if the motor has sufficient torque to turn the auger. If motor seems to be strong enough , use a pair of pliers or a vise grips and try to rotate the auger shaft. If the auger will not turn, it might be clogged up with pellets or pellet dust. The clog will have to be removed. If that is the case, I think the gears in the motor are stripped and a new motor is in order. Note: Damp pellets swell up and turn hard as concrete when they dry out.
Dec 06, 2013 | Home
Pellet stove
vacuum switch helps all to work and power supply if more than 2 bends in the exhaust can b a problem to there is a intake air lever on the back of some that allow more or less vac pressure in to the chamber auger will not turn if door is open to create the vacume
Dec 02, 2013 | Heating & Cooling
Auger not working on Blaze King Pellet Stove
depending on how the manufacturer set up the system, there may be pellets wedging the auger. most augers are geared low enough to snap the pellet but if its something else blocking it (stick or rock etc) it may have blown a fuse for the auger drive or the drive mechanism itself. if you are going to work on the auger. UNPLUG THE STOVE AND USE TOOLS TO CLEAR BLOCKAGE as there may still be some pressure to spin auger
Aug 07, 2017 | Pool & Spa
The auger is not turning to fill the burn pot with pellets. Can hear the motor run but it will not turn it.
Have you recently changed the brand of pellets form what you have used in the past? If so, please understand that no two wood pellet manufacturers make their pellets the same way. If this is the case, you will have to retweak your stove to that brand of pellets you're now using. Also, check the auger to make sure it's not jammed and that auger shaft is properly fitted into the auger drive motor coupling..
Hope this helps solve your problem.
Feb 15, 2011 | Heating & Cooling
Cozy model 100 pellet stove.auger seems to be jamming sometimes ,removed motor and it turns,could problem be in gearbox?have motor in a vise and it has been turning for 4 hours
How about the pellets getting trapped between the auger and case? Look to see that the auger is down and seated correctly, not saying that the gear box is not the problem. I just think that you should look at all of the simple things first. Does the auger spin freely with out pellets in it? How are the bearings on the auger? Does it require lubercation? Does the gear box turn easily with out the motor?
Dec 23, 2010 | Cozy (W352E) Heater
Auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Jul 08, 2009 | Napoleon Auburn Pellet Stove Heater
My pellet stove will start but the auger will not drop pellets. What should I do.
You need to replace the auger motor. Go to fasco .com they may have one. Or enco.com I have a pellet stove and i have replaced both the auger motor and the motor that turns the hopper.
Nov 20, 2008 | Kitchen Ranges
Napoleon Auburn Pellet Stove Heater Logo
1,385 people viewed this question
Top Napoleon Pool & Spa Experts
John Rodgers
John Rodgers
Craig Butler
Craig Butler
Paul Carew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
