Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Pin out for t5720
Can any one tell me the pin outs of the handsfree jack for Motorola T5720 ? I want to make my own Vox for it. Thanks
  • warrenjabal Jan 10, 2009
    I have same question. I have an original pair of Motorola Talkabout T5720 two way radios, their NiCad batteries, and even the original manual -- but lost the AC charger that plugs into the base unit. Base unit does not indicate what voltage/polarity is required so I haven't been able to replace the lost transformer. Do you know?
  • 123 Answers
The Plug is a 2.5 mmm the tip is mic, middle speaker, the end is gnd.
Posted on Jun 19, 2007
  • Ernesto  Garcia
    Ernesto Garcia Jun 19, 2007
    I think the mic line handle the mic audio and the ptt at the same time.
  • A. Riehl Apr 23, 2012
    Hey,
    That's the pinout for a standard 2.5mm plug, (2.5mm x 11mm (on most older cell phones). Talkabout plugs are 2.5mm x 13mm (2mm longer), and the pinout is tip=speaker, middle=mic, end=ground.
SOURCE:
BAGAIMANA CARA MENGUNAKAN MOTOROLA TALKABOUT T5720
Here is a link to the user guide for the Motorola TalkAbout T5720. I only could find it available in English. You will need to translate into Indonesian.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Aug 17, 2012 | Motorola Talkabout T5720 (7 Channels)...
Can motorola talkabout T5720 FRS/GMRS talk with Motorola GP338 UHF?
Your GP338 would need to be reprogrammed to one or more of the frequencies available in the T5720. If you are using the interference code eliminator, it would also need to be programmed into the GP338. Take your GP338 to your local Motorola dealer for reprogramming.
Here is a link to the user guide for the T5720, where you will find a list of frequencies: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf See page 19.
Best regards.
Feb 23, 2011 | Motorola Talkabout T5720 (7 Channels)...
Where can I buy repair parts for my Motorola T5720 Talkabout radio?
So sorry, parts have never been available for the TalkAbout line of radios (other than TalkAbout Distance & DPS). If you are looking to repair an existing T5720 unit, your best option would be to locate a like-model for parts. eBay can be a good source.
As for replacement batteries and accessories you can use the Motorola TalkAbout Accessory Store.
Best regards.
Mar 20, 2010 | Motorola Talkabout T5720 (7 Channels)...
I have a motorola t5720/ please , where can I find a table of pl codes?
You can find a chart for PL code settings at http://en.wikipedia.org/wiki/Continuous_Tone-Coded_Squelch_System The numbering system for the T5720 will be the number in the left column, and the PL code in MHz is listed in the right column.
Best regards.
Jan 07, 2010 | Motorola Talkabout T5720 (7 Channels)...
I have a TLKR-T3 and a T5720 radios. can they communicate? Thanks
No, they have no frequencies in common. The TLKR-T3 uses the PMR446 frequencies common in Europe. The T5720 uses FRS freqeuncies common in the USA.
Dec 19, 2008 | Motorola Talkabout T5720 (7 Channels)...
RPL & TPL tones used in T-5720
The T5720 user manual does not list the TPL codes possible in the radio. However, they are the standard list, with zero being "open squelch" (no code). Here is a link to a Motorola manual which has a list of the PL codes in order on page 43. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
On the T5720, another item to what for is the Qt noise filter. Be certain to set it to zero unless using the T5720 with others of the same model. It can also block transmissions. Here is a link to a user manual for the T5720 http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
Sep 22, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 circuit schematic
We are a M dealer and the schematics for the TalkAbout line were never released to the dealer channel.
Jul 13, 2008 | Motorola Talkabout T5720 (7 Channels)...
Talkabout T5720 Frequencies
Hello Ruaal,
The frequencies in the TalkAbout T5720 are not adjustable. The radio operates on the designated Family Radio Service channels located at 462 and 467 MHz. There is no way to change these channels to be at 463 and 464 MHz.
Best regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | Motorola Talkabout T5720 (7 Channels)...
Earbuds
If you are using vox (voice activated transmit) go into the menu and make sure you don't have the VOX setting too high. You should be able to put the headset on... hit the "push to talk" button on the radio and transmit you audio. Turn the other radio on and make sure the radio is "keying" (tx with no auio) then make sure there is audio. If you don't have audio but the radio is transmitting.. you might have the wrong type of plug on your headset for the audio..... there are 2 plugs... 1 for transmit audio....1 for recieve audio. It could be the wrong type of plug for the jack in the radio. Regardless.. the way the headset works is either you push the "push to talk button" onj the radio OR you use the VOX function... with the vox function you just have to talk into the mic to transmit. This is what your headset is designed for. You will have to go into the menu and set up the radio for VOX. If you still have problems follow my directions at the top of this page ( check mic jack and stuff) I think you just have to set the radio up for VOX operation and set the VOX setting. You should be able to push the push to talk button and talk through the mic on the headset. If you don't get any audio that way there is a problem and you should check the jack and plug on the headset.
Aug 25, 2007 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
390 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
