Question about Uniden Atlantis 250 Marine Radio
On-off switch for alantis 250 is broken
Need new switch! Will install if necessary.
  • kazaa309 Feb 15, 2009
    Where do you buy them at?
You can order a new switch from uniden, however it's nineteen dollars for the switch and requires quite a bit of soldering, I just changed one out for my dad and it was not that easy. but it beats the 65 bucks they wanted to fix it.
Posted on Feb 11, 2009
2005 kymco moongoose 250 won't start, replaced battery and starter solinoid i have lights but won't turn over.it will turn over if its jumped> ideas??
Hi, Jenni and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Having issues atv starting staying started
Part 1 TaoTao 250cc ATV not starting Think it may be the CDI
KYMCO Mongoose KXR 250 Service Manual
http://www.motopartsmax.com/index.php/main_page/vehicle/tID/1/bID/25
KYMCO Mongoose 250 Owner Manual
Mar 14, 2017 | Kymco Motorcycles
1998 250. Why won't it start?
Hi, Tonesetter and the usual suspects are:
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
https://www.tradebit.com/filesharing.php/search/0/1998+yamaha+250
Oct 28, 2015 | Yamaha Motorcycles
Wont start backfire
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Won Start Just Turns Over And Backfires Fixed
ViragoTechForum com
2008 YAMAHA STAR 250 XV250 SERVICE REPAIR SHOP MANUAL Download Manuals...
OEM parts for Yamaha
http://s.productreview.com.au/products/manuals/1282_563aea4f677d6.pdf
May 02, 2014 | 2004 Yamaha Virago 250
Fix backfire at idle TZR 250
http://www.rcramer.com/shop/backfire.html
http://faq.f650.com/FAQs/BackfiringFAQ.htm
Yamaha TZR250 1987 Service Manual
http://mybikemanuals.com/yamaha/yamaha-tz-owners-manuals
Feb 09, 2014 | 1990 Yamaha TZR 250
Where is the air/ fuel mix screw on a 2006 yz250f
6. Faulty spark plug cables, leaking or broken, internal damage.
Easy Carb Tuning Installing Fuel Screw
YZ 250 runs but backfires
YAMAHA YZ250 LC Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jan 17, 2014 | Yamaha YZ 250 F Motorcycles
2001 f-250 brakes lites don't work. fuses good and installed new pedel switch still no brake lites
Could be as simple as bulbs died. Second I would check if lights have good grounding (these things tend to corrode over time. Usually black wire and have connection to vehicle's chassis). Or could be broken wire/shorted wire.
Nov 06, 2013 | Motorcraft 2001 Ford F-250 Super Duty Fuel...
2008 v star 250 will not start
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha Vstar 250 won start need to diagnose and fix possible fuel battery...
https://www.perthstreetbikes.com/forum/showthread.php?t=78121
Yamaha XV250G Supplementary Service Manual
YAMAHA XV250P Owner Manual
Sep 22, 2013 | 2008 Yamaha V Star 250
1987 Honda NSR 250 MC 16 backfires
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
94 fourtrax backfiring
Severe backfire no acceleration
Honda NSR250R SERIES Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-ns-owners-manuals
Jul 02, 2013 | 1987 Honda NSR 250 MC 16
1993 Honda CB 250 Nighthawk no spark
Hi, Damoke83 and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
1993 Nighthawk 250 has no spark
How to diagnose no spark situation on motorcycle
Honda CB250 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB250 Owner Manual
Sep 20, 2012 | 1993 Honda CB 250 Nighthawk
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Uniden Atlantis 250 Marine Radio Logo
187 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Greg Cann
Greg Cann
Mike Marcotte
Mike Marcotte
Are you an Uniden Boating Expert? Answer questions, earn points and help others
