Question about Intel D845GVSR Motherboard
No display board on but no display on monitor
    Problem Solver:
  • 15 Answers
Your video card is failing of your motherboard neads cleaning or your motherboard and or power center is witched to a high volt change the voltage in the back of power supply warning!! disconect computer from the electrical plug.
Posted on Jan 17, 2009
Flatron W1943 sb monitor goes into power-saving mode. Does not display data.
If the monitor is displaying the "Power Saving Mode" signal to the monitor, then the monitors internal VGA board is functioning, so you can rule out a broken monitor. However I have seen monitors blow the internal fuse to the VGA board which causes a false "SLEEP" signal. If this be the case then it will require replacement of the fuse (usually a microfuse soldered onto monitor internal board) or most likely a monitor replacement.
To test:
Option A: you can connect another monitor to the monitor output on the back of the computer and see if you get a display. If this monitor goes to sleep, then it is likely that your Video card is malfunctioning. If you get a display, then it is definately the monitor.
Option B: If you have another computer, you can attempt to connect the monitor to another computer. Also most modern laptops will be equipped with monitor output, so if you have one you can check it. If the monitor sleeps, then it is definately the monitor. If you get a display, then it is definately the computer video card.
Hope that helps,
G
Sep 17, 2012 | Computers & Internet
No display
The Viewsonic VG1921wm monitor uses the same power supply board that the Optiquest Q19w uses. When that monitor has display problems like you are having the most common cause is bad capacitors on the power supply board. When the capacitors go out the power board does not put out the correct voltages to drive the back light circuits and the driver circuits so you get no display. There is a very good chance that this is the problem with your unit and it would be worth having a look at the power supply board. Here is a link to a repair guide for the Optiquest monitor and since they use the same power supply board it should help you check you board and show what needs to be replaced to repair it.
http://www.ccl-la.com/blog/index.php/how-to-repair-a-optiquest-q19wb-monitor/
I hope this helps.
Jun 20, 2012 | ViewSonic VG1921wm 19" Monitor
My samsung LCD monitor display blank but blue light is blink.
Check to ensure all connections are in good place and are properly connected, if they are and yet no display, the picture board on your monitor is faulty, since the power light is on, it means the picture board of your monitor has developed fault.
take the monitor to a local repairer within your vicinity to help with the replacement of the picture board.
Dec 10, 2010 | Samsung SyncMaster 740N (Silver) 17 inch...
No Display on Mother Board
Have you try troubleshoot with working monitor, display card or your matherboard and processor,
Usually no display problem occur becouse of one hardware between monitor, ram, motherboard, displaycard and can be your processor problems.
You can try troubleshooting one by one of your computer hardware to get problem occur
Jul 21, 2010 | Intel Desktop Board D845WN Motherboard
My lt865b doesn't display anything and the display functions of the monitor do not respond at all i love the monitor and need help.After 3hrs use the display starting going all white then blacked out. I...
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Mag Innovision InnoVision LT865s 18" Flat...
I have no display o9n screen or monitor
It could be one of two things. First thing your display is faulty and will ahve to be replaced or the second thing is your system board is faulty. To know if its your system board use an external monitor via the vga port on your laptop if you can see and use your computer using the external monitor then just your screen is faulty if not then its your system board
Feb 22, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
I have asus p5p800-mx mother board morboard working fine and also start but on monitor no display and i also try to install additional graphics card then also no display
Have you tested the monitor to see if it is working? Is the vga cable good? Are you getting the BIOS start-up display screens when computer is booting up or no display at all? It is odd that both the on board video and video card would be bad I would double check the cable connection and the monitor. If the cable is good and the monitor is working properly than the board might be bad. You should at least get the BIOS start-up screen display.
Sep 07, 2009 | ASUS P5P800-MX Motherboard
Monitor will not maintain display
Power board or inverter board are shot. contact manufacturer if in warranty for replacement, or get a new monitor. If you are so inclined, you can probably get these boards cheap on ebay.
Aug 08, 2009 | Computers & Internet
HCL LCD Monitor display problem
NO Bad Capacitors on the power board i have some problem in my HCL lcd monitor, my monitor display is on but at a time the display is gone. when i swicth off and on monitor power the monitor display is on ofter 2 sec the display is gone so that is the problem.
Jul 05, 2009 | ViewSonic VA702b 17" LCD Monitor
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Intel D845GVSR Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
