Question about Vacuums
I have a hoover windtunnel u5757-900 and the motor stops in the mittle of the operation, no restrictions
  • 1 more comment
  • ldangond Jan 19, 2009
    Question, is there a motor thermal protector on this vacuums? and
    if yes where is it located, is there a troubleshooting manual that I can dowload?
    thanks...
  • ldangond Jan 21, 2009
    Thanks, the problem was corrected apparently the thermal protector for whatever reason was to close to the motor and it was sensing the heat and shutting it down, relocated the sensor away from the motor and closer to the cooler area in the chamber and that did the trick, thank again...
  • 294 Answers
When the motor stops, this is usually caused by an restriction in air flow...caused by a full bag, dirty filter or blockage. do you wait for about 30 minuites and it you can turn it on again? have you changed th dirt cup filter in the last 2 years? have you ever washed the dirt cup filter? if you have washed it, you should not have, however, once washed and dried the fibers would have expanded and will cause a restricted air flow condition.If all of this check ok, you may still have an electrical issue, and would recomend bringing that to a trusted Vac shop.
Posted on Jan 17, 2009
  • Robert Pagliaroli Jan 19, 2009
    Yes, there is a thermal protector. located in the motor cavity. it is wired in series with the motor. Should be serviced by trained technicians with electrical problems. No, there are no troubleshooting manuals available.
The brushroll stops turning.
Hoover Windtunnel Self-Propelled Vacuum Belt ... - YouTube
? 2:54
www.youtube.com/watch?v=AJL9McF7MAU
May 22, 2012 - Uploaded by Crucial Vacuum Fits: Hoover U6423-900, U6425-900, U6425-920, U6429-900, U6430-900, ... U6616-900, U6617-900, U6625-900, U6626-900,U6630-900, ...
Aug 06, 2015 | Hoover U6630-900 WindTunnel Bagless...
How to stop main belt from comming off motor shaft on a windtunnel model u6634-900
Need to replace both drive and roller brush belt. Can't just replace one even if the other is fairly new.
Jun 21, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Vacuum shuts off while in use
There is a thermal reset inside the motor that shuts it off. There may be a clog.somewhere or something restricting the airflow, it could be clogged filters. If there are no clogs or restrictions it is possible the thermal reset is bad in which case you will have to replace the motor.
Jan 26, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Why doe my hoover mach3 stop during operation? I have to wait until the moter cools down.Then i turn on the switch normal way.Then a few minutes latter it stops again.
Your Hoover is stopping because it is overheating. This is a sure sign that there is a blockage somewhere. Find the blockage and clear it, and that should solve the problem.
Mar 20, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover S3639 Windtunnel Vacuum not on after burning smell
how old is it ?maybe the motor went south.take the cover off and see if you see any burn marks ,maybe you can narrow down the burnig smell.i don't charge people for helping i just enjoy helping.314-628-9153
Apr 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel..runs fine for 5 minutes then stops?
OK - sounds like your machine has a blockage somewhere. Follow manufacturer's instructions for clearing blockages and all should be well. If you no longer have the manual, you can download it from the Hoover website.
Mar 08, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover windtunnel U5753-900 will not start
The most likely problem is the on off switch. but it could also be related to the motor or a connection.But definitely electrical in nature. suggest to take it in for service.
Feb 21, 2009 | Hoover U5753-900 WindTunnel Bagless...
Vacuum shuts off
It sounds like the hose from the bottom part is plugged. The motor has a high temperature protection that will shut the motor off if it overheats but will come back on once it cools. The motor will overheat if any restriction of airflow occurs. If the overload sensor reacts too many times, it will eventuall start to shut off before it should, so you should address the problem asap. Check the area behind the roller and the hose leading up to the connection to the attachment hose for blockage. Also, make sure you are not setting the machine height adjust too low. This will make the bottom plate sit down too close and cause a restriction in air flow to the motor.
Nov 17, 2007 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
110 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
