Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
Kenmore 25615 won't shut off.
Kenmore vacuum will not shut off. Disconnected wand and hose but vaccum continues to run. Handle will control motorized powermate.
  • khmauldin Feb 12, 2009
    the switch on the handle does not seem to be working, the only way to stop the cacuum is to unplug it. Do I need a new hose?
    Sergeant:
    Champion:
  • 318 Answers
Power switch needs replacement
Posted on Jan 16, 2009
Kenmore Progressive vacuum cleaner head continually shuts off when wand is turned. Seems to be a short in the connection between wand and vacuum head?
go to wallmart and get new one take the old one put in new box get your money back drive back home and get some vaccumeing done
Feb 04, 2013 | Vacuums
The powerhead on our kenmore progressive canister vac (model 116.25615506) turns on and off as the yolk handle is raised and lowered. what is the most likely cause and is it repairable? thanks,
Wires (pins) are burned in the handle connection, usually the top section by the switch, unhook from the metal wand and inspect the connection, look for black sooty looking pin holes or pins, check both sides. This means the pins have burned slightly and now have a loose connection with little or no continuity. Very common, you will need to repair with a wire Kit or have a professional do it. Horrible design flaw been going on for years with these types of vacuums.....ACE
Dec 15, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
My Kenmore 116.25812508 power nozzle motor will not run unless I tilt the handle. I checked the connectivity from the circuit board in the power nozzle base to the telescoping wand with an ohm meter and...
I have had this vacuum for about 3 yrs and nothing but issues with it. It's been in the shop already once and it needs to go again. No power in the power head. A wheel came off of the powerhead too .. keep snapping it back on but it always comes off.
I am disgusted with this vacuum
Jan 19, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 25614/25615 Progressive bagged canister vac won't start
sounds like there was a loose connection or loose wire that came in contact with another wire. check your cord for small burn holes, also could have shorted out in the hose or the wand. If you are comfortable to disassemble the vacuum i can walk you through the troubleshooting process so we can find out what actually went bad. id start with the cord though. let me know if you have any questions or need more assistance
Jan 04, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
No spinning in the power head
First, check the red reset button on the power nozzle head. - if it's popped out, push it in. Also, if you have a switch on the handle, make sure you're pressing it while you're vacuuming. if those obvious solutions are already remedied, you may need to check the power outlet on the canister for voltage with a voltmeter while the vacuum is running, and then check your power hose and wand for continuity (checking for a broken wire) while the hose is disconnected from the canister. If all this checks out and the power nozzle still doesn't power on, you may have a bad motor in the power nozzle. If you're good at taking things apart, then it's a simple fix to replace the power nozzle motor.
Jul 03, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Performance indicator light is on and suction is not strong
You do have a clog! trust me. Check the wand and the yoke which is on the brush assembly. its the part that connects with the wand.
if thats not it then it has to be in the hose. the only way to get it out of the hose is to take one or both ends off and push a broom stick through it
Feb 03, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Brush does not turn on my vaccum
When you attach the hose to the wands, there is a connection made between the hose electrical receptacle and the cord from the powerhead. On the Kenmore, it is common for the receptacle on the hose to break away from it's seat and slide back into the handle. When this happens, the receptacle is not positioned far enough forward to make the plug-in connection. Look at the end of the hose and check the receptacle and see if it is sitting flush with the plastic opening that it sits in. If it is pushed back, that's your problem. Also check the re-set breaker on the powerhead. If you got something caught in the brush roll, the breaker will have kicked out to protect the motor.
Jan 20, 2008 | Vacuums
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
124 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
