Question about LG LRFD21855 Stainless Steel French Door Refrigerator
I moved, and now the water no longer comes out the door
I recently moved and when I hooked the fridge back up the water no longer comes out and the ice is not being replenished. I did have to take off the door in order to get the fridge out of my house. I have also verified that water is being supplied to the fridge. Please help!
  • Anonymous Dec 20, 2007
    Ice not being made in our new LG refrigerator.
  • 489 Answers
The electrical connector at the top of the hinge cover is not connected properly.  Pull the left hinge cover and make sure that the electrical connections are secure.
Posted on Apr 27, 2008
SOURCE:
My GE Adora side by side makes ice but the water dispenser barely dispenses.
Did you recently move the fridge? One possibility is that the supply line in the back of the fridge is kinked. Usually it is coiled so you can move the fridge out and back damage but if it gets kinked, it would limit the water supply like a hose does when kinked. Also, the supply line is usually tapped from under the sink. Make sure the valve that supplies the line (usually 1/4 inch line) is fully opened. If that fails to help, then you're back to the solenoid valve for water that is not fully opening. Should give a solid clunk when actuated. G
Jan 27, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Water accumulates underneath freezer Neff k4664
I've found this when the door seals aren't sealing correctly and also I have seen it when the rear panel of the freezer has moved out of place.
Jul 10, 2013 | Refrigerators
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Water build up under crispers the fridge is a maytag & has been moved here recently could it be that the fridge in not level or that the drain for the defrost cycle in possibly plugged please give me...
check door to make sure it is sealing correct warm air might be causing condensation in fridge area or check drain freezer -may be clogged causing water to trickle down thru vent at back wall by fan
Sep 26, 2009 | Maytag Refrigerators
Msd2756geb water tube coming out door not hooked up?
Check diameter of pipe. Suspect its quarter inch. You will then probably need to purchase e.g. from ebay etc a 1/4'' to 3/4'' adapter which will allow you to connect your fridge pipe to a typical water pipe connector (i.e. similar connecting a washing machine), assuming you already have an available water conenction in the lcoation of the fridge!
Jun 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge door problem
There probably were spacers. Also be sure that the refrigerator is level, side to side and that it is leaning just slightly back. If not leveled, it can actually throw the cabinet off and it will be out of square.
Apr 05, 2009 | Refrigerators
Water & Ice dispenser quit on Kenmore 106.9535110
recheck the electical connection at upper frz door hindge sometime a wire could be pushed out but check to see that the control lock was not set by accident
Dec 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
LG LRFD21855 Stainless Steel French Door Refrigerator Logo
75 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
