Question about Xerox DocuColor 12 Color Copier
Docucolor 12 no print
Hi, When I send a print job using color or black/white, nothing comes out. There is no error code. I get a blank sheet of paper. Do you know the cause?
Thanks,
Keith
  • howsimple Jan 16, 2009
    Hi, If I copy from the glass, it works. Do you know the problem? Thanks, Keith
  • oooimstuck May 11, 2010
    is it the same when photocopying from the glass?
    Sniper:
  • 54 Answers
If its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
Posted on Jan 21, 2009
DOTS pattern and WHITE LINE along the page
The Problem is your Copy Print Module it has a scracht on it if you replace the module it will desapear the dots and lines.
Nov 26, 2009 | Xerox DocuColor 12 Printer
Docucolor 2045 print White areas
a number of reasons can cause this. have you tried each colour individually? after this swap drums and see if fault moves with the drum. otherwise its probably developer
Jan 21, 2009 | Xerox DocuColor 12 Color Copier
Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
Jan 18, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print color & B/W
the only thing apart from software corruption is that you could try printing a configuration sheet. If this prints then black printing is working. If it won't then print a test page then you need composite patch 1-7QU5B.ps from the xerox "drivers and downloads" site. If none of this works it is a software reload.
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Calibrating Doc 12 without a platen
I am to take it that the Platen cover is missing? If this is the case what you need is Ledger (11x17) or just bigger, bright white paper. Make sure that you use about 6-8 sheets (stacked) on to of each other. Place your color calibration test page on the glass and then lay the sheets over the calibration sheet. This should work as well as the platen white back.
Jan 04, 2009 | Xerox DocuColor 12 Color Copier
White lines Xerox docucolor 12
do an emergency stop on the machine as the paper is just coming into the main path, and you will catch the inage on the IBT. with a bit of luck on the drum as well. Is it not in 1 colour the white lines? Also are they thick or pencil like lines and from lead edge to trail edge?
Jan 01, 2009 | Xerox DocuColor 12 Color Copier
Doc 12 error code 9-343
i had similar problem a week ago running black only job on extra heavy card stock.
there is black toner built up. when you run black only copy with little toner use, it builds up toner in black developer and motor could not run.
always mix black and color jobs and run alternate, so there is no excesses in any color. or cheaper way how i did without paying color clicks.
i got rid of excess black in following manner.
took 11x17 white sheet, copied as negative (solid black) and ran 30-50 black copies, which drained all excess black and then continued with job.
hope it works for you or get professional help or you will lose motherboard and motor if you just follow instruction as it tells you on error screen... switch off and switch on. do not keep on repeating.
Oct 23, 2008 | Xerox DocuColor 12 Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Color Copier Logo
209 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
