Question about Frigidaire GLER331A Electric Dryer
Dryer gets hot to the touch
I recently moved to a condo and discovered that the existing dryer hook-up is a 3 prong plug. My dryer has a 4 prong plug. So i swapped out my dryer's 4 prong cable for a 3 prong cable. I took care to hook it up correctly per the instructions. I made sure to ground the dryer frame to the center post ETC... I went to use it and the top right back corner and the backside of the dryer get extremely hot and... the clothes take for ever to dry. The venting is fine (good air flow all the way to the outside of the condo) and the drum is turning fine. Any suggestions? thanks
  • mitdrum Jan 16, 2009
    OK, I'll try the venting test first.
    Scholar:
  • 160 Answers
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
See "how to take apart" first. Don't forget to check fuses in house fuse box and confirm that you have 240 volts to the dryer main connection. Test for 240 volts to the heating element, 240 volts to the element and no heat = bad element. The element must be physically broken to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color of the wire that has no power, remove power to the dryer and check the wiring diagram to find out where that color wire goes to. Example: - wires might be black and purple, if the black wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. If live volt testing scares you, try the ohm check instead
Posted on Jan 16, 2009
    Sergeant:
  • 221 Answers
Q - Dryer takes too long to dry or multiple times to dry a load
A1- Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat orpocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
Going from thre prong to four prong what goes
Under the new Codes2_bing.gif...all dryers (and stoves/ovens) must now be 4 wire....having a seperate neutral and ground wire in NEW construction. In decades past, the neutral was allowed to serve as both - the neutral and ground - typically by means of a solid metal strap or wire strap that bonded that connection to the metal frame of the dryer. This sounds as if it is the case in your existing dryer...which was typical.
But...the old arrangement wasn't always reliable...and a seperate dedicated ground provides a greater safety path in the event of a fault inside the dryer (lowering the chance the user may get a shock when touching the frame of the dryer).
To modify your existing 3 prong dryer over to 4....you'll need to remove the 3 wire - disconnect the ground strap (or wire) that bonds the neutral to the frame of the dryer...and install your 4 wire so that you'll have (from left to right) one hot, one neutral, one hot connection...and connect the ground directly to he frame of the dryer (there is usually a green screw near the dryer connection block for this ground)
For more on this - with an illustration, see:
http://www.american-appliance.com/service_pages/electric_dryer_cord.htm
When done properly, you can test for correct wiring and connection with an ohm-meter (continuity check)...by checking for continuity from the ground prong on the plug to the frame of the dryer...you should see continuity. Then check for continuity from the neutral prong on the plug to the frame...you should NOT see continuity....nor should you see any continuity between the neutral connection at the wiring block to the metal frame.
The whole purpose of the Code change to the 4 wire is to seperate the two.
Hope this helps,....if you need more details, please follow-up.
May 02, 2010 | Speed Queen AES28AWF Electric Dryer
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool Dryer - Model LHE 5700. My Dryer had a 3 prong plug. I recently built a house which has a 4 prong plug. I changed out the plug and connected the wires according to color. The center wire is white...
Hello David_Teresa,
Under the new Codes...all dryers (and stoves/ovens) must now be 4 wire....having a seperate neutral and ground wire in NEW construction. In decades past, the neutral was allowed to serve as both - the neutral and ground - typically by means of a solid metal strap or wire strap that bonded that connection to the metal frame of the dryer. This sounds as if it is the case in your existing dryer...which was typical.
The whole purpose of the Code change to the 4 wire is to seperate the neutral from ground to provide additional safety for the user.
Nov 29, 2009 | Whirlpool Dryers
I was switching the electrical cord from a 3 prong to a 4 prong and grounded a hot wire. there was a big pop and now i cant get it to start. would i have blown it up?
WHy are you switching the cord from a 3 to a 4? If the dryer came with a 3 prong cord and its a 3 prong terminal block, then i dont think you can change it to a 4 becuase you will short circuit. DOes the terminal block where your cord was hooked up have 4 terminals. Each termial can only have one lead/wire to it. check your circiut breaker panel? Is the circiut breaker tripped?
Jul 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Need to install a 4-wire/ prong dryer cord strain relief assbly
The green wire attaches to the dryer cabinet. There should be a green screw in the cabinet for attaching the wire. If not, you can always drill a hole for a ground screw.
The loose green wire you see is the reason the code was changed to a 4-wire cord.
May 06, 2009 | Kenmore 62602 Electric Dryer
Changing my dryer cord from 3 pronge to a 4 pronge. how do i hook the cords to the baqck of the dryer. brand name is a frigidaire
on 4 wire, red and black is hot, white is neutral and green is ground. On terminal block out side terminals are hot and center is neutral, ground connects to green screw on cabinet. if your current connection has a white or green/yellow jumper on the ground term move this to the center/neutral connection with the white wire. only wire to be on gnd term in gnd wire. hot does not matter which side as long as it doesnt touch anything else and not on center term.
Difference in 3 and 4 is a dedicated ground, on 3 wire dryer was grounded through the neutral.
May 03, 2009 | Dryers
If you didn't install new venting I'd start by checking the vent hose from the back of the dryer to the outside vent hood to make sure there is no blocked airflow. Could be something else but that is where I'd look first. Good Luck.
Jan 15, 2009 | Frigidaire GLER331A Electric Dryer
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Frigidaire GLER331A Electric Dryer Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
