Question about Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player
After replacing a dead car battery, the unit will not turn on
I replaced the car battery after leaving the lights on and now the DH-2000mp will not turn on. The clock display is also not showing, like there's no power. The fuses of the vehicle are OK and there is 12 v on the vehicle radio circuit. I'm puzzled as to what it is. Anyone have any ideas?
Roland
  • Anonymous Apr 09, 2009
    i left my lights on and now the deck will not start up. i have a 91 hinda accord
    Brigadier General:
  • 5,158 Answers
Locate the fuse panel in the engine compartment near the battery... there is also a fuse panel under the dash... replace the relays for that circuit.... likely burned out.
Robert
Posted on Jan 16, 2009
How do I reset the computer on 2001 Mitsubishi after replacing the alternator it is a petrol 4 x 4 a 3litre
Not sure what your meaning of why need to reset the computer, the alternator has nothing to do with a check engine light so if that is the issue with check engine light need to scan vehicle find what code is fix that if what to know how to dead boot computer 1.pull + battery cable leave off 2. Get in vehicle turn lights on yes I know there not going to come on we are draining the capacitors in computer 3. Leave light switch on depress brake several times 4. Insert ignition key turn like cranking vehicle couple times. 5. Turn everything off lights key an reinstall + battery cable start vehicle check engine light should be off. Basically that is a dead boot for computer draining all power for it.
Oct 29, 2016 | Mitsubishi Cars & Trucks
Charger works unit when switch is on. When disconnected it will not show any green light to go no throttle engagement.
I have no experience with the E-300 though the circuits are similar,
as shown by the link below.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
Yahoo Image Search Results Page
Apr 27, 2015 | Razor E300 Scooter
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
2005 Dodge Truck 2500 / Brake lights flashing while truck turned off / dead battery
i don't know why but dodge trucks back feed threw the trailer lights and leave light on
Aug 31, 2012 | 2005 Dodge Ram 2500 Truck
Charging Black and Decker Simple Start
okay people... this is a long one, but I just did it for two units that were having this problem and it worked both times.
The problem is the unit sat on the shelf and doesn't have enough power to operate its charging cycle.
Take an extension cord and plug in the outlet charger while you also plug it into your cigarette lighter... now attempt to charge it (you will hear the familiar alarm). Now, turn on the LED light... after a short time, turn off the light and the unit will begin to charge regularly. You can then use one of the chargers to finish the job.
By doing this you are providing plenty of power to the battery while the light drains it at a slower rate... kinda forcing the battery to condition/cycle; it's just allowing the battery to take the charge. Hope this helps.
Apr 28, 2009 | Black & Decker Simple Start Car to Car...
Clock
The manual was even wrong on this one. What you have to do is:
1. turn the key to the run position
2. push and hold the volume knob in until the unit turns off.
3. push it in again and hold it, the unit will turn back on and if you keep holding the button in the hour will start to flash
4. use the up/down, left/right buttons to set the time
5. push the button one more time and its all set
Feb 15, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Battery will not take charge from wall unit
Remove the battery for several minutes, replace the battery and plug the wall socket in, leave it for several hours. The battery is probably too dead to do anything, and recharges very slowly. If this doesn't work, try a replacement battery, before you send the unit in for repairs.
Jun 15, 2008 | Garmin zumo 550 GPS Receiver
Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player Logo
813 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
