Question about Iomega Zip 100MB (31714) External ZIP Drive
100mb zip disk not reading
I have a 100mb Fujifilm zip disk and it's not reading. I've tried the disk in a new iomega Zip 250 and iomega Zip100 with no luck.
You can hear the disk spinning and after 2-3 minutes the Autoplay window appears with a status bar. After 1 minute of this the window dissapears and the following error pops up.
"The semaphore timeout period has expired."
Any help would be appreciated.
My pendrive size is 1 gb & i am using only 500mb please solve this problem
Posted on Feb 14, 2009
  • 298 Answers
These are pre-formatted and servoed at the factory.
Awhile back I was researching the 'Click of death" fault and found a guy in Belgium or Germany that coded a repair program for bad disks. Googlee for it
sometimes when it formats, it hoses the servo information (which the drive uses to keep track of things) and the disk becomes useless. This is why I stopped using ZIP disks and won't even buy a drive when I see them for 9.99 ;-)
Posted on Jan 17, 2009
Download needed
Hello
Thank you for using
FixYa for your problem
Download the driver from here;
http://www.softwarepatch.com/utilities/zip100.html
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | Iomega ZIP 100 Internal ZIP Drive
Zip disk
do a hard reset and then try it again
it may work.
else try some sharp obhect to move the lever carefully
Jun 23, 2008 | Iomega Zip 100MB (31714) External ZIP...
I had a computer with a slot for reading iomega ZIP 100 disc. My new computer does not have this. Is there a device to read my zip dizc and send the contents to a USB port?
IOMEGA make a USB ZIP drive that reads and writes 100 and 250 Mb disks. Don't know if this is available any more, you might be able to pick one up 2nd hand.
If you still have your old computer, try networking your old and new computer together so you can transfer data from the ZIP drive on your old computer to your new one.
Mar 21, 2009 | Iomega Zip 100MB (31714) External ZIP...
Can't read specific Diskette
It sounds like the one diskette has gotten corrupted. If there is no problem reading the others then it is not a drive problem but a diskette problem. Sorry.
Jan 22, 2009 | Iomega 100MB ZIP Media Disk (ZIPMEDIA)
Can't read specific Zip 100MB Diskette
Its probably a bad disk. The only way I have been able to fix these is to First launch disk utility THEN put the disk in. THEN run the utility. You have to do it in this order. The key thing here is utility has to be running first and then insert the disk "HOT"
Hope this helps!
Jan 22, 2009 | Iomega Zip 100MB (31714) External ZIP...
Iomega 100MB zip drive
i think it is damaged. because of the bad sectors . try to use third party recovery app
Jul 16, 2017 | Iomega 100MB IDE Black Zip Drive...
Cant figure out how to use zip drive when i have added a pass to my zip dr 250
1. Insert a blank disk into the zip drive
2. Give this disk a password (it can be any password, as long as you
remember it)
3. Using the Ioega toolset, set the zip drive's sleep time to a large
value (such as 1 minute)
4. Wait a while until the drive "spins down". You will hear the drive
stop spinning.
5. Take a pin or a straighten paper clip and stick it into a hole in
the back of the Zip drive. This will manually eject the blank disk.
6. Insert the disk you want to access (the one you don't know the
password to)
7. now use the IoMega toolset to remove the password. When prompted
for the password use the password from step (2).
This is just a word of warning in case you store any important information like I used to on zip disks. Perhaps move to a more secure medium.
May 09, 2008 | Iomega Zip 100MB (31714) External ZIP...
Disc won't read
what type of zip disk are you trying to read? if it is larger than 100MB, the drive will not be able to read it.
can you read other disks? can you see the drive in my computer?
what operating system are you using, and how does does this drive connect to the computer? USB? Firewire?
Mar 29, 2008 | Iomega Zip 100MB (31714) External ZIP...
Iomega zip port
First of all, make certain you are only using 100 MB disks in a 100 MB reader.
If the problem is more complex than that, I have several questions:
Can you read different disks?
what type of connection is the zip drive using with the computer? USB?
does the zip drive need an external power supply?
will the zip drive successfullly read disks when connected to a different computer?
does the zip drive appear under my computer at all? even as an empty drive?
what operating system are you using?
Iomega Zip 100MB (31714) External ZIP Drive Logo
560 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
