Question about Samsung PS42P2S 42 in. Plasma Television
Samsung, 50" new 2008, 1080i
My Samsung TV died in December (barely nine months old) I have the Samsung warranty and extended protection from Circuit City. The power supply was replaced and now there is a terrible electrical buzz coming from the tv that lasts for one to two hours. Noise occurs with every imputted device. Samsung will not replace the TV but suggested the repair was not conducted properly. Circuit City, they have the opportunity to repair it three times (now bankrupt and closing all stores). I feel this TV has been impacted from whatever event happended. What is causing the buzz? Now the repair place wants the TV. So much for the Superbowl.
  • Anonymous Jan 16, 2009
    i have new telivition 50inc samsung and i cant get no chenal no singnal
  • 98 Answers
It was power board related problem.
But, sometimes need to replace the Y-main or X-main as well.
better to contact samsung call center again, ask to replace both of them.
Posted on Feb 09, 2009
14 month old samsung 32in 530 series lcd tv will turn on fine, then after a few minutes start turning on and off repeatedly for ever...until i pull the power. What do i do, call samsung?
its possibly dry joints on the power supply-the heat generated causes the solder to crack,and when warm creates a "crater" on the affected joint and expands with heat,and loses contact until cool.(retraction).should be easy if you are handy with a soldering iron!.failing that,take it to a repair shop as its out of warranty,and samsung will not want to know! (unless you got extended warranty,of course!)
good luck,steve
Sep 12, 2011 | Samsung LN32C530 32 in. TV
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
A SAMSUNG WINDOW AIRCONDITIONER WAS GIFTED TO ME BY A DEAR RELATIVE. HE PURCHASED IT ON DATED 7/8 DECEMBER 2008 BUT BILL OF SUCH NOT GIVEN AND RETAINED BY HIM AND FURTHER LOST.IN THE MONTH OF MARCH 2011...
Unfortunately, there si no way to do it under warranty, without a dated Proof of Purchase. However, it sounds like your relative may have purchased an Extended Warranty. As 60 months sounds extremely long for a window unit. But, here again, without proof of that, there's not much, if anything that you can do under warranty. If Samsung quoted you a price of several hundred dollars or more, it would be less expensive in the long run, to buy a new window unit. That way, you would have full warranty coverage.
Apr 07, 2011 | Heating & Cooling
Volume in the tv is not working, and you turn the tv on or off it comes three to four minutes later. The tv was bought nine months ago, it's an LCD 42 inches MODEL #42MF439B/F7
If it is nine months old the set must still be under warranty, the problem you are describing is an intermittent audio problem and can be difficult to locate. I recommend getting in touch with the people you bought it from and get the satisfaction you deserve.
Dec 31, 2010 | Philips Televison & Video
I replaced the lamp after only a 14 months but it will not light up, then I put the old lamp back in and the lamp comes on momentarally but then shuts off and the TV never lights up. Why will the TV not...
Lamps last between 5,000-8.000 hrs Keep in mind every hour you play TV ,thats an hour lost on Lamp and its also possiable to receive a defective Lamp even new doesnt mean it works.
Lamp Fan if defetive can also prevent lamp from lighting. This happens to protect lamp from running and getting way to hot and therfore buring lamp up .
Ballast Board that connects to lamp is what turns the lamp on,if the ballast board is defective Lamp will not firer,meaning you either have bad lamp fan or new lamp is defective. Heres another Tip Sony had alot of problems with their Light Engines prices for that part range from $650.00 up to $2,799.00 depending on which light Engine you have? Since your TV is Still under warranty take it in quickly and be sure to ASK about warranty on YOUR Light Engine!!!
Jul 03, 2010 | Sony KDS-50A2000 50" HDTV
Black haze covering picture after "pop" noise
That's a very old model to be only 1 year old?
It needs a Z-Sustain PCB anyway.
Thanks.
Sep 08, 2009 | LG DU-50PZ60 50 in. Plasma Television
I have blue botches ( ghosts ) appearing on the tv
This problem is caused by a bad optical block. Sony has extended the warranty for this problem but the extension is only valid until December 2008 so you must act now. You can find instructions for obtaining service and additional information here:
http://ciscdb.sel.sony.com/perl/news-item.pl?news_id=206&mdl=KDF50WE655
Be sure to rate this solution. Thanks!
Oct 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a samsung 50 inch plama no audio....
Have you checked the connections to your speakers and if they are connected correctly from the TV and to the speakers. Also as it is only two months old the product should still be covered by its warranty so contact your supplier if you have no luck.
Oct 14, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Sony KDF-E50A10 50 inch LCD
your optical block requiers replacing.not a cheap job.around £600.00
Oct 03, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Another Zenith TV Pops and bites the dust!
I can just imagine how you feel. Sorry. Our TV, same make and model, just did the same thing today 9/19. Luckily we purchased an extended warranty but however are waiting two weeks for them to show up and who knows what is wrong and how long it will take to fix it?
Sep 09, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Samsung PS42P2S 42 in. Plasma Television Logo
149 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
