Question about Maytag Atlantis MDE7400AY Electric Dryer
Plastic rib or bar inside tub came loose
I am trying to access the outside area of tub to screw the part back on the tub. How do I get to the outside of the tub?
I had this same problem. The screws fasten to the tub from the outside of the tub. There are screws on the left side of the dryer (doing this from memory) and screws that hold the door on.
First of all, unplug your dryer before working on it. Common sense right?
Next, remove the door. It is easy to take on and off. Unscrew the screws at the hinges. From there you can remove the front panel by lifting up and out.
Next get a flashllight and small/short screwdriver. You will need a short screw driver as there is not much room inside. You can reach in and either tighten or replace the screws.
I found this to be a good time to vacuum out any loose lint that found it's way in the interior of the dryer.
Tighten it and then put the front back on and replace the door. There you go! Hope that helps.
Posted on Jan 21, 2009
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
I have a maytag top load washer (Bravos quiet series 300) that has stoped working. it flashes a code of "F51". It did this before and the repair man opened it up and found small clothing items...
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
Jun 16, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Can you remove the plastic ridges inside the drum of a Maytag dryer? There is something caught and makes a noise.
usually the screws for these are actually on the outside of the tub screwed into the baffle device... will require you to gain access to outer portion of tub.. good luck to you.
Jan 27, 2011 | Maytag Dryers
Drivers side front door will not open from inside or outside even using the key
Sounds like the clips that hold the rods, that operate your inside/outside door handles have come loose. You will have to get the door panel off...but first...you'll have to get the door open. OK...where your inside door "lever" is located....there is a plastic cover behind that lever.....also, there might be a small plastic access cover... over the screw that holds on this larger cover in place. If so....pop the little access cover off and there will be a screw behind it. (keep in mind...this is behind the inside door lever you pull on to open the door) remove the screw...remove the cover...you should now be able to see where the rod has come loose. if you cant grab it with your fingers, get a pair of pliers and pull forward ( toward the front of the car) to open the door. Make sure the door lock is off also. You may find the clip that holds the rod to the lever is broken or the rod has just fallen out of the clip. Sometimes, you can wire the clip into place so it dosnt come loose again. At this point, you will want to remove the door panel....because the "outside door lever...rod...is also loose...in which case you will need access to the inside of the door to fix it. Just remember, you only want to this once...so while in there...fix it right....
Theroadisalover
Try to post back and let me know If I helped you solve your problem. It will help me with my rating....! Thanks
Jan 01, 2011 | 2001 Saturn L-Series
Turned washer on started to agatate made loud squilling noise
Hi, Check inside the drum for loose plastic bars that help tumble the clothes. If you can shake them, open the cabinet top and tighten the bar screws on the outside of the drum. If any appear stripped and don't tighten, remove the bar from the machine and inspect for cracking around the screw holes. If found, replace with new parts. Otherwise, try breaking off matchsticks in the holes and see if the screws will tighten. The top is either held on with screws in the back--then slide the top backwards to remove, or there is a pair of spring clips in the front corners that require a thin putty knife to be slid into each clip and pushed until the clip releases. The back end of the top usually has plastic hinges and won't come entirely free of the cabinet. Hope this helps!
Take care
Jun 13, 2010 | Maytag SAV2555A Top Load Washer
Removing gold toned grab bars and fixtures from old whirlpool tub
sometimes a plumber leaves an access panel to get at the drain and jets under the tub---it's usually small and may not be enough to get a body in---usually the grab bars are permanently glued or siliconed on a fiberglass/plastic tub....a cast iron, or other non-plastic type tub may have removable grab bars...look for access area, or you may just have to cut out a piece of the wall to look----or if you do find a small access panel, and can get a telescoping mirror to look back at the back of the grab bar underneath the tub, you will find your answer----or you could contact the original manufacturer of the tub, and they can tell you if the grab bars are removable....another solution is to coat/paint/sandblast the metal bars however you'd like them to be
Mar 13, 2010 | Home
Loose rib in barrel of Maytag dryer How to fasten it back?
These ribs are made of heavy plastic and are screwed on from the outer portion of the drum. Remove the top and the front of the dryer to gain access to this ribs bolts and tighten
Mar 13, 2010 | Dryers
One of the 3 "ribs" inside the dryer drum fell off. How does one go about getting to the outside of the drum to reattach the rib with its screws.
older models you take screws off around the top, check for them by lint filter too. then you pry the front(spring clips) and swing it open, back usually has a cheap hinge mechanism.
Oct 07, 2009 | Dryers
We washed a small rug and we got an E-20 code. what should we do, its having problems draining!
Drain pump screen is clogged. If its makeing a bad grinding sound the pump will need to be replaced. Otherwise disasembly of the machine is required to access pump area to clean out screen. Dextrous people can probaly do this from the back or underneath unit. Its difficult and I don't recomend it to beginers or people who arn't handy. Easiest/prefered method: (This is the one I use.)
Method A units that have a bottom access panel. ie: front panel not one seamless peice.
-unplug unit
-lean back against wall for easy access.
-remove two #2 square screws form access panel.
-Loosen clamp holding hose to tub. (Big black one around 2" in diameter.)
-remove and clean screen.
-reassemble machine and test pump operation.
Method B units the have seamless front panel.
-unplug unit
-remove top. 3 screws @ back, slide top away from machine to remove.
-remove 2 screws holding console onto chasis.
-remove disp
-remove 3 screws @ and behind disp area.
-Remove console. ( tab may be holding to front panel @ middle bottom use putty knife to pry up.)
-remove 4 screws holding front pannel @ top to chasis.
-remove 2 screws holding frong pannel to chasis inside machine. Acess from top. (some models only.)
-remove bottom screws either 4 or 2 usally 4.
-remove two screws holding door lock to front panel
-remove spring from around bellow.
-remove bellow from front pannel
-remove front pannel. Tilts forward and lifts up off supports. (some models only.) or pannel ifs up and off from white tabs in side of chasis.
-unhook wires to door lock from front pannel. (plastic molex tab)
-may now access pump like in method A.
Pump Replacement
-access pump area
-remove drain hose to pump by looseing clamp and pulling off.
-remove hose to tub by losseing clamp and pulling off.
-remove power connection at back left of pump.
-unscrew two philips screws holding pump too base plate. (only one is really required.)
-replace pump
-clean pump screen or add one if not present.
-reconnect hoses.
-replug in power
-reassemble machine
-test pump operation
Jul 12, 2009 | Frigidaire GLTF2940ES Front Load Washer
My Kenmore under counter ultra wash dishwasher model 665.15825691 has started leaking at the lower corners of the door. The leaks seem to occur during the final rinse while the water is being heated. I...
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Jun 27, 2009 | Kenmore Dishwashers
Maytag Atlantis MDE7400AY Electric Dryer Logo
74 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
